REM Expert Assist SDK for iOS - video and voice doesn't work
gsalazar1
I'm trying to make a simple project on iOS using de REM Expert Assist SDK.
When I tried to start a Support Session like the Developer's Guides says (https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/remote_expert_mobile/remote_expert_m…)
it worked when connecting to the agent but I can't get audio and video on the application.
This is the code I used to start the session:
- (IBAction)startCall:(id)sender {
     NSDictionary *params = @{
                             @"acceptSelfSignedCerts": @YES,
                             @"destination": @"<sip_url>",
                             @"videoMode": @"full"
    // initiate support
    [AssistSDK startSupport: @"<my_server>" supportParameters:params];
This is my info.plist:
These are some logs:
I test the sample included on expert_assist_iOS_SDK-11.6.1.10000-7.zip downloaded here Cisco DevNet: Remote Expert Mobile - SDK and it presents the same problem, as shown in the following picture
Could someone help me, please? Did I forget some configuration?
I'm using 11.6 version.
Kind regards,
Génesis
neetagup
Hi Génesis,
Looking at symptoms, i,e, no audio video in either direction. I suspect that network you connected to does not allow UDP traffic.
Media (RTP) is sent over UDP.
Neeta
Hi Neeta Gupta,
Sorry for the delay in response.
I'm not sure, but I think that the problem could be other. I tried the 11.5 version in the same way I tried the 11.6 and everything worked great.
However, thank you so much for your response.
Kind regards
Hi Génesis.
Thank you for your response. Are you happy to go ahead using 11.6 in that case?
Cheers,
Rach D
Hi Rachel,
Yes, I have no problem to go ahead using 11.5. I was referring to 11.5 version
Kind regards,
Génesis
