eUnknownFailure in sample.html
jmennear
Trying to get the sample.html to work and I am having problems. Attaching my softphone.log and a picture of my ect/hosts file
172.18.106.82     mac-wiki.com
10.10.30.1        pub-remote.psdtemea.cisco.com
System is Windows 7 Enterprise 64bit SP1.
Trying to connect to sandbox 10.10.30.1.
Unable to login: Login Error eUnknownFailure
I am following the instructions at: https://developer.cisco.com/site/collaboration/jabber/websdk/develop-and-test/testing/shared-jabber-sandbox/
And am able to get past STEP 4 - Run the sample app.
The screen then shows me my CSF device and I press "connect".
At that point, it appears that I am kicked out and I return to having to press the Login button again.
I can ping 10.10.30.1 and I can bring up the CCMAdmin page but not CCMUser.
tinghche
Level 5
Level 5
Hi John,
Did you have any firewall setting that could possibly block UDP/TCP port 5060/5061?
From the log it shows that the SIP invite never comes back with server's response.
I just tried the same user ID here and it works fine.
Howard
tinghche
Level 5
Level 5
Hi John,
Howard
I have Windows Firewall off.
How do I determine if there is something else blocking that port?
turns out I had my work Jabber that my company has us run on our desktops, when I signed out and exited that the sample program worked fine.
that make sense...
Thanks for the update.
