Hi Maciek,
I'm not quite understand your question here.
So, you will need to determine if the auto-recording is enabled on the device when the call comes into Jabber SDK.
If yes, you can show a picture/message as notification to the participant on kiosk?
If this call will always be record, you can bind to the event and display picture when call comes in.
ex:
if (conversation.callType === "Incoming") {
$callcontainer.find('.remotename').text(conversation.callingPartyDirectoryNumber + "This call will be recorded");
If the recording is been set on the kiosk side, I guess you can determine by detecting if "recordingDevicesSelect". Then display the picture/message.
Not sure if this is what you intent to implement.
Howard
