Hi everyone, We installed REM 11.5(1), now upgraded to 11.6(1) in a customer that is not using Reverse proxy, instead is using Fortinet FW that is doing SSL offloading and NAT, Connection from outside using Chrome and Firefox works fine, but with IE11 connection failed, stayed in "connecting" state, looking the plugin LOG file, we found that there is "tls handshake failed" error, do you know what are the requirements for the public certificate? The certificate is from Comodo, and works well for other applications and Chrome/ Firefox web browsers.
The certificate is loading in FW, from the inside network, we can connect with any problem with IE11
On the other side, customer wants to REAS node do the "ssl ofloading" and load the public certificate, is that supported? I did not find nothing about that in documentation, will this consume a lot of cpu resources?
Excuse me for my English...is not my native language.
Gustavo
