10-23-2017 06:26 AM
Problem delegate is not called. Connection is established. Input/output streams to host works. But delegates is not called. I have no idea why. I linked all frameworks just like in example app iOSFusionSDKSample and set "enable bitcode" to NO and other linker flags to "-ObjC -lstdc++" and I did try "AssistSDK" it works but i cant control style and size and other options in it.
Code "ViewController.m"
#import "ViewController.h"
@interface ViewController () {
NSURLSession *session;
@end
@implementation ViewController
- (void)viewDidLoad {
[super viewDidLoad];
// Do any additional setup after loading the view, typically from a nib.
- (void)viewDidAppear:(BOOL)animated {
[super viewDidAppear:animated];
NSURLSessionConfiguration *config = [NSURLSessionConfiguration defaultSessionConfiguration];
session = [NSURLSession sessionWithConfiguration:config delegate:self delegateQueue:[NSOperationQueue mainQueue]];
NSURL *url = [NSURL URLWithString:@"#####"];
NSURLSessionDataTask *task = [session dataTaskWithURL:url completionHandler:^(NSData * _Nullable data, NSURLResponse * _Nullable response, NSError * _Nullable error) {
NSLog(@"%@", data);
NSLog(@"%@", response);
NSString *responseString = [[NSString alloc] initWithData:data encoding:NSUTF8StringEncoding];
NSDictionary *json = [NSJSONSerialization JSONObjectWithData:data options:NSJSONReadingMutableLeaves error:&error];
NSString *sessionId = [json valueForKey:@"sessionid"];
ACBUC *uc = [ACBUC ucWithConfiguration:sessionId delegate:self];
[uc setNetworkReachable:NO];
[uc acceptAnyCertificate:YES];
[uc startSession];
[uc setNetworkReachable:YES];
[task resume];
- (void)didReceiveMemoryWarning {
[super didReceiveMemoryWarning];
// Dispose of any resources that can be recreated.
- (void)URLSession:(NSURLSession *)session didReceiveChallenge:(NSURLAuthenticationChallenge *)challenge completionHandler:(void (^)(NSURLSessionAuthChallengeDisposition, NSURLCredential * _Nullable))completionHandler
if ([challenge.protectionSpace.authenticationMethod isEqualToString:NSURLAuthenticationMethodServerTrust] &&[challenge.protectionSpace.host isEqualToString:@"####"])
NSURLCredential *credential = [NSURLCredential credentialForTrust:challenge.protectionSpace.serverTrust];
completionHandler(NSURLSessionAuthChallengeUseCredential, credential);
else
completionHandler(NSURLSessionAuthChallengeCancelAuthenticationChallenge, nil);
- (void)ucDidFailToStartSession:(ACBUC *)uc {
NSString *string = @"SDFSDF"; // Breakpoint
- (void)ucDidLoseConnection:(ACBUC *)uc {
- (void)ucDidReceiveSystemFailure:(ACBUC *)uc {
- (void)ucDidStartSession:(ACBUC *)uc {
@end
Code "ViewController.h"
#import <UIKit/UIKit.h>
#import <ACBClientSDK/ACBUC.h>
#import <ACBClientSDK/ACBClientPhone.h>
#import <ACBClientSDK/ACBClientCall.h>
@interface ViewController : UIViewController <NSURLSessionDelegate, ACBUCDelegate>
@end
Debug LOG output:
ACB client SDK version: 3.2.2.1.1
Scrambled Session ID:#####
Session ID:wss://#####
***WEBSOCKET*** setNetworkReachable: 0
***WEBSOCKET*** NTWK acceptAnyCertificate: 1
Created NSURLRequest: wss://### with timeout of: 7.000000
Waiting for network reachability before websocket is created.
***WEBSOCKET*** setNetworkReachable: 1
Creating websocket to <NSMutableURLRequest: 0x1c001c960> { URL: wss://#### }
SocketRocket: Allowing connection to any root certificate
[SR] Don't Use Cookies
10-25-2017 12:00 AM
Problem solved,
var ACBUC needs to be in class scope not in function scope.
After this little modification it seams to work.
Matous
