Support for Android 6 devices REM 10.6.2.0000-4
bcason
native apps created using the Android Expert Assist SDK 10.6.2.0000-4 appear to crash when run on devices running Android 6. Per the release notes for this version and device running android 4.1.2+ should be supported: "Cisco Remote Expert Mobile also delivers integrated communications in iOS 7+ and Android 4.1.2+ apps thru native libraries."
Can you provide clarification or troubleshooting assistance?
Brad
rdoyle001
Hi Brad,
REM 10.6.2.0000-4  was built 3 days prior to the release of Android 6 so I'm assuming the release notes were written without knowledge of it.
Android 6 will be supported in REM 11 but if you feel there is a ned for 10.6 support please raise it internally.
Rob
rdoyle001
Hi Brad,
Rob
Thanks, Rob. That’s that answer we needed.
Bradley Cason
ENGINEER.NETWORK CONSULTING
bcason@cisco.com
Phone: +1 206 224 4085
Cisco Systems Limited
500 108th Avenue N.E., Suite 500 City Center Bellevue
BELLEVUE
WASHINGTON
98004
US
Cisco.com<http://www.cisco.com>
Think before you print.
This email may contain confidential and privileged material for the sole use of the intended recipient. Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
For corporate legal information go to:
http://www.cisco.com/web/about/doing_business/legal/cri/index.html
