Undefined symbols for architecture x86_64
sashahan
I'm trying to integrate the framework to make a simple video call using the latest version (Jabber Guest for iOS - 11.0.2)
I've followed all the steps given in the dev guide (Cisco Jabber Guest SDK for iOS Developer Guide).
1. Building it for a simulator, I get 2 errors - ld: warning: ignoring file JabberSDKObjCDemo/JabberGuest.framework/JabberGuest, missing      required architecture x86_64 in file JabberSDKObjCDemo/JabberGuest.framework/JabberGuest (2 slices)
     Undefined symbols for architecture x86_64:
       "_OBJC_CLASS_$_CJGuestCall", referenced from:
      objc-class-ref in ViewController.o
     ld: symbol(s) not found for architecture x86_64
     clang: error: linker command failed with exit code 1 (use -v to see invocation)
2. On changing the Architectures and Valid Architectures settings in the Build Settings to support only 32 bit, I get the same, except      instead, now it shows 2 errors - missing architecture i386.
3. On building the same for the device, I get - 18 errors -
     ld: symbol(s) not found for architecture armv7
Also, Xcode (8.3.3) tells me to turn off Bitcode generation or get a new version of the framework from the vendor.
Can I not just run an app on the simulator at all ? Also, since it does not seem to support 64 bit architecture, will I not be able to run it on a device also ?
If possible, please upload a new version for the framework with support for all the required architectures.
dstaudt
It appears that the Jabber Guest iOS SDK does not support the iOS simulator (which is implemented using i386 architecture on the Mac )
https://developer.cisco.com/site/jabber-guestsdk/documents/guest-ios-dev-guide/v11_0_0/index.gsp#requirements
I believe this would explain the errors regarding missing components for 'x86' and/or 'architecture'
Thanks for the reference ! Yes, that should clear up the i386 errors. But I get the same errors when building for a device as well. Will check it out on the device once more and let you know.
