Failed to login to apic
zelbaz
I try to run one of the scripts but the login is failing I get
Traceback (most recent call last):
  File "create-tenant.py", line 19, in <module>
    session.login()
  File "/localdisk/acitoolkit/acitoolkit-master/acitoolkit/acisession.py", line 367, in login
    resp = self._send_login(timeout)
  File "/localdisk/acitoolkit/acitoolkit-master/acitoolkit/acisession.py", line 342, in _send_login
    ret = self.session.post(login_url, data=jcred, verify=self.verify_ssl, timeout=timeout)
  File "/users/zelbaz/.local/lib/python2.7/site-packages/requests-2.7.0-py2.7.egg/requests/sessions.py", line 508, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/users/zelbaz/.local/lib/python2.7/site-packages/requests-2.7.0-py2.7.egg/requests/sessions.py", line 465, in request
    resp = self.send(prep, **send_kwargs)
  File "/users/zelbaz/.local/lib/python2.7/site-packages/requests-2.7.0-py2.7.egg/requests/sessions.py", line 573, in send
    r = adapter.send(request, **kwargs)
  File "/users/zelbaz/.local/lib/python2.7/site-packages/requests-2.7.0-py2.7.egg/requests/adapters.py", line 415, in send
    raise ConnectionError(err, request=request)
"requests.exceptions.ConnectionError: ('Connection aborted.', error(104, 'Connection reset by peer'))"
When I use another apic it is working. What can be the problem?
I am using https passing https://ip as url , admin name and password.
I found the issue , In the APIC I enable TLSv1 and it is working now.
kecorbin
How are you passing the URL/username/admin?  are you specifying http or https?
Zehavit
