Unable to change logging level
Nathan Sowatskey
The attached image shows an error when I am attempting to change the logging level for the network-poller-service.
I am logged in as a user with the ROLE_ADMIN role.
Nathan
5 Replies 5
rnaggi
Nathan ,
Which build ? is it 1.2.0.1594 ?
I will also check internally and will sync up .
Yes, 1.2.0.1594.
Nathan
Even i am seeing the same error with latest build 1.2.1.x
I will open up the case with platform team keep you in loop . below screenshot from latest image 1.2.1.x. (fyi  image is not outService-error-417.jpg
Just to add,
for other services , i see it is working fine. Fyi... ( 1.2.1.x)otherservoce.jpg
Thank you Rohan. I am pleased to see that it can work under some circumstances.
Nathan
