32 Bit Application with 64 Bit TSP
bhoover02
I've recently migrated my 32-bit application from running on a 32-bit OS with the 32 bit TSP to running on a 64-bit OS with a 64-bit TSP. I know am getting "dwSize mis-match" errors when calling the devSpecific functions. I found a few items on the web that seem to indicate that in this scenario my application would have to be compiled as 64-bit. Is this the case? Are there any workarounds to get my 32-bit application to work on a 64-bit machine?
Ben
Geevarghese Cheria
Hi Ben,
    Most of the documents with similar issue " dwSize mis-match" recomends that the workaround is to deploy the 32-bit app on a 32-bit TSP/OS.
Reference - https://cdn.cisco.com/web/tapi/community/-/message_boards/view_message/6125309
Thanks and Regards,
Geevarghese
