atapi version for CUCM 10.5
My system is on windows 7 64 bit opearting system, and have used atapi dll in my dot net application to implement  atapi api.
I have used  ATAPI Wrapper  of vesrion 1.4.0 will it create any issue?
Or should I use atapi 64 bit? If yes then What would be the correct vesrion?
Geevarghese Cheria
Hi Bhushan,
   Moving your question under TAPI community for more visibility of support engineers.Please check this related url -Tapi development starting point
Thanks and Regards,
Geevarghese
