Cisco TAPI - SLDST_START_CALL_RECORDING expecting wrong parameter size
Eric.L.Johnson1
The call is expecting 16 bytes, the class in the header is 12 bytes.
Version: 10.5.1.10000-7
Using Cisco TAPI TSP 64-bit and the headers with that Applications \ Plugin
Error message in TSP debug log:
14:53:09.603 |   CSelsiusTSPLine::DevSpecific() [0x00000536] inside of SLDST_START_CALL_RECORDING
14:53:09.603 |   CSelsiusTSPLine::DevSpecific() [0x00000536] *ERROR* dwSize mis-match 0x0000000C (expected 0x00000010)
Classes in CiscoLineDevSpecificMsg.h
class CCiscoLineDevSpecific
public:
    CCiscoLineDevSpecific(DWORD msgType) :
        m_MsgType(msgType)
    virtual ~CCiscoLineDevSpecific()
    DWORD GetMsgType(void) const
        return m_MsgType;
    void* lpParams(void) const
        return (void*) &m_MsgType;
    virtual DWORD dwSize(void) const = 0;
private:
    DWORD m_MsgType;                                   // 4 bytes
class CCiscoLineDevSpecificStartCallRecording: public CCiscoLineDevSpecific
public:
    CCiscoLineDevSpecificStartCallRecording() :
        CCiscoLineDevSpecific(SLDST_START_CALL_RECORDING)
    virtual ~ CCiscoLineDevSpecificStartCallRecording()
    DWORD m_ToneDirection;                             // 4 bytes
    DWORD m_InvocationType;                           // 4 bytes
        return sizeof(*this) - sizeof(void*);
    } // subtract out the virtual function table pointer
Are there updated headers or TSP available?
Thank you
Eric J
Eric.L.Johnson1
Found Solution:
Add in the CiscoLineDevSpecificMsg.h, CCiscoLineDevSpecificStartCallRecording a dummy DWORD between the m_ToneDirection and m_InvocationType, setting it to 0.
As in:
    DWORD m_dummy;
START_CALL_RECORD succeeded and produced a recording.
Will still have to verify whether the Record Feature light is lit, i.e. is the InvocationType parameter working.
Question:
Is there a corrected CiscoLineDevSpecificMsg.h available?
Hi Eric,
Please make sure that application/TSP/OS are all 64-bit or 32-bit.  We only support fully 64-bit or fully 32-bit stacks. My understanding is that your application is 32-bit running on a 64-bit stacks. The workaround is ok for now but you may run into other issues so it is best that you recompile your application for 64-bit environment.
David
Hi Eric,
I just talked to our TAPI DE about this issue. We do not support cross platform (64bit TSP will only support 64bit app). Even if you have a workaround this issue, more issues can come in the future. In addition, LineDevSpecific class has virtual pointers and VP size varies from 32bit to 64bit.
Hope that helps.
David
