CiscoTransferEndEv randomly not delivered
thomaslorenz
I have a problem at a customer (related TAC service request number is 632123479) that randomly the CiscoTransferEndEv is missing.
Through the TAC analysis has gone already this far that in the working, as in the non working cases the "LineTransferEndedEvent" is delivered from the CTIManager towards the JTAPI library.
I did some closer examination and found out one main difference that in the cases with the missing event the following logfile entry is missing in the debug logs of the JTAPI lib:
95479: Apr 20 10:32:07.232 CEST %JTAPI-JTAPI-7-UNK:[ FinalCall=(P1-ASCRecStanna) GCID=(4,5400568)->ACTIVE]TransferManager:sendTransferEndEvent event.success=true
Means whenever the CiscoTransferEndEv is missing in our JTAPI application, then also this line is never seen in the JTAPI traces.
I can deliver a full set of logfiles, but the logs should also be linked to the mentioned TAC case.
Best regards,
Thomas Lorenz
mpotluri
Level 5
Level 5
Thomas,
   Can you attach the JTAPI log for the non-working scenario?
It seems that JTAPI is getting 3 start events but only 2 transfer end events from CTI. JTAPI is not delivering the end event due to this pending end event from CTI. I would suggest creating a case with developer services.
38822: Apr 20 10:12:58.697 CEST %JTAPI-PROTOCOL-7-UNK:(P1-192.168.16.20) received Event: com.cisco.cti.protocol.LineTransferStartedEvent {
  eventSequence                = 2442
  lineCallManagerID            = 1
  lineID                        = 70688
  transactionID                = 67453840
38830: Apr 20 10:12:58.697 CEST %JTAPI-PROTOCOL-7-UNK:(P1-192.168.16.20) received Event: com.cisco.cti.protocol.LineTransferStartedEvent {
  eventSequence                 = 2443
  lineID                        = 69858
38842: Apr 20 10:12:58.713 CEST %JTAPI-PROTOCOL-7-UNK:(P1-192.168.16.20) received Event: com.cisco.cti.protocol.LineTransferStartedEvent {
  eventSequence                 = 2444
  lineID                        = 69858
38881: Apr 20 10:12:58.728 CEST %JTAPI-PROTOCOL-7-UNK:(P1-192.168.16.20) received Event: com.cisco.cti.protocol.LineTransferEndedEvent {
  eventSequence     = 2455
  lineID            = 69858
38887: Apr 20 10:12:58.744 CEST %JTAPI-PROTOCOL-7-UNK:(P1-192.168.16.20) received Event: com.cisco.cti.protocol.LineTransferEndedEvent {
  eventSequence     = 2461
  lineID            = 70688
smupadhy
You can find information on DevNet Developer Services here - Cisco DevNet Support
jocreed
You DevNet Case is open and we are researching this issue.
