computer/telephony integration options
hiersd
Visitor
Is JTAPI pretty much the way to go to interface with CUCM for a CTI application?  It looks solid, but I want to be sure that I'm not overlooking a better option.
David
mpotluri
Level 9
Level 9
Depending on the type of integration you can choose one from Call Control list.
Another industry standard API for CTI integration is TAPI which is supported by CUCM.
