Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Resolved! PCM through CUCM
Hello,I'm using CUCM 9.1.The scenario: I'm making a call from my application to a Cisco IP Communicator and only testing the audio coming from my microphone and listening on the IP Communicator. The problem is, that when I'm using PCM 16bit 8000Hz fo...
I have added some devices as CTI devices, mainly IP CommunicatorsThese devices can call, answer call and perform all telephony commands.When i started to monitor these devices, I am getting TimeoutException.I am monitoring these devices as super prov...
Hi All, I request your in put on the following query. I could not see in the following URL whether VG350 is CTI supported? https://developer.cisco.com/site/collaboration/call-control/jtapi/wiki/cti-tapi-jtapi-supported-device-matrix/#wp1029269 In add...
jkalarit by • Cisco Employee
  • 748 Views
  • 1 replies
Resolved! TCL with CVP
Hi guys I have running on a gw the services tcls for CVP application... but I want the call to match first a TCL that check working hours... and then if its on a working hour send the call to a voip dial-peer which that has associated on CVP applicat...
I am developing JTAPI application for making call using super provider.I am using a device to call which is in good state. I can create terminal with provider.createTerminal().When i tried to make call using JTAPI application from that device, it giv...
Hi we have a TCL script which outpulses account number as DTMF to an 800 number and while this outpulse occurs the inbound caller hears music. The music file does not play continuously instead repeats itself every 1 secs sounding like a broken record...
preethamk by • Frequent Visitor
  • 4024 Views
  • 7 replies
