返信
Display of redirection information on phone
schloeglhofer
I have a question regarding redirect information in TCL scripts.
There is the following case:
- Caller calls to extension A via Cisco Gateway which runs a TCL script on an incoming dial-peer.
- Extension A does not answer within the specified period - ls_002 is received
- Now  extension B is called. Extension B should see on the display which extension did not answer.
I think it has something to do with callinfo(redirectNum).
Could please somebody help to solve this ?
Best regards
Reinhard
1件の返信1
yawming
I think it depends on the protocol, the best way it's to try it out.
