Showing results forĀ
Search instead forĀ
Did you mean:Ā
Need help on TCL scripting
shettyajey
Visitor
Hello Guys,
I am trying to create a TCL scipt  to play the greeting before the call reaches the destination.
I do not want to apply it to the incoming dial-peer but to the out-bound dial-peer pointing to the call manager.
Can any one help me out with a script for the same.
For script itself, we get the destination number from  set dest [infotag get evt_handoff dnis] (for outbound dial peer)
instead of  set dest [infotag get leg_dnis]   (for in bound dialpeer)
That's what we need to do for script in outbound dialpeer.
To place the app in outbound dialpeer we need to add "out-bount" at the end
            dial-peer voice xxx
                        service  <name> out-bound
But you need to manage your destination number to prevent looping
For example you have destination number 1111 that triggers the script, script will capture 1111 as destination number, then if you setup the call with 1111 it will create a loop. That's what I mean that will make it more complicated. So you may create a temp outbound dialpeer only for Tcl script then another real one to reach out and in script you will change the dest number to real one to prevent it come back to script again.
7 Replies 7
yawming
Just like to clarify your questions  before jumping to the solution.
Q. Play greeting to calling or called party ?
Q. Do you mean Tcl App to apply or you mean promt to play ?
If we are talking about Tcl app, is there a reason we have to apply to out-bound ? Not saying that we cannot do it but usually make it  more complicated.
Yawming
Hello Yawming,
Thank you for responding
Greeting should be played to the calling party. Ex: Your call will be recorded.
Yes. I want to apply the TCL application to the outbound Dial-peer. Because, incoming calls some are routed to UCCE and some are routed to Call manager. It would be easier for me to apply the TCL script only to the outbound VOIP Dial-peer pointing to the Call manager.
            dial-peer voice xxx
"I want to apply the TCL application to the outbound Dial-peer. Because, incoming calls some are routed to UCCE and some are routed to Call manager."
If you cannot break it into 2 dialpeers you can filter in Tcl script too.
For example one you need to play greeting one don't need then the no need one just "handoff" to IOS.
Got it.  Thank you so much
One more question. For incoming calls to play media I write the function
proc act_Media { } {
    global dest
    leg proceeding leg_incoming
    leg progress leg_incoming
    leg connect leg_incoming
    media play leg_incoming flash:recording1.wav
What should be the function for outbound call to play media ?
It's the same but you use different command to get destination number
and to be safe check lag status:
    set legState [infotag get leg_state leg_incoming]
    puts "TCL : Leg State is $legState"
    if {$legState != "lg_005" && $legState != "lg_008"} {
       if {$legState == "lg_001"} {
          puts ">>> TCL: legstate = lg_001 <<< \n"
          leg setupack leg_incoming
       } elseif {$legState == "lg_002"} {
          puts ">>> TCL: legstate = lg_002 <<<\n"
       } else {
         puts ">>> TCL: legstate = $legState <<<\n"
I will try this out. Thank you so much
