DTMF and TTS cisco cucm
santanudee
How to make DTMF and TTS work in cisco jtapi system. What are its settings so that my call goes from one phone to another phone. In what way can these two be used in my Java code?
santanudee
I'm not sure I understand your question. Can you provide your call control system information? (CUCM, CUCME, 3rd party) Also, what application are you integrating? And, then, if you can provide a more detailed description of what you are trying to accomplish we are better able to help.
Maren
santanudee
I want to understand that Dual tone multi frequency and text to speech how to integrate it in Java code? These two system requirements are more in the Java sample code. It would help if there is any sample code example as it needs to be represented to the client.
