Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to read TSI value with TCL on inbound fax to IOS GW
michalkaska99
hallo, I have configured a fax to email on my IOS GW.
All works, but one customer sends us a fax without ANI identification. We can see, that their fax machine have filled  the fax number acording to RFC 822 as originator TSI. This number is not part of call signalization. Cisco IOS adds this value into "mail from" when sending the TIFF file to mailbox.
I wonder, if is somehow possible to read this "originator TSI" value in TCL script during receiving fax and converting to TIFF.
This is GW config:
fax receive called-subscriber 283061280
fax interface-type fax-mail
mta send server 10.4.5.17 port 25
mta send subject "Novy Fax na lince 283 061 280"
mta send origin-prefix "Simac fax machine 283 061 280"
mta send postmaster michal.kaska@simac.cz
mta send mail-from hostname simac.cz
mta send mail-from username fax-280
mta send return-receipt-to hostname simac.cz
dial-peer voice 88888 pots
service fax_onramp
incoming called-number 283061280
direct-inward-dial
port 0/3/0:15
dial-peer voice 88889 mmoip
huntstop
preference 4
service fax_on_vfc_onramp_app out-bound
max-conn 1
destination-pattern 283061280
information-type fax
session target mailto:faxy-dosle@simac.cz
image encoding MH
image resolution fine
mdn
dsn success
dsn failure
Any experience with this can halp me.
Raghavendra G V
what do you mean by originator TSI, could you please give more details on this. if there is ani set you can get with below command.
infotag get leg_ani
Raghavendra
Hallo,
sometimes it is called CSID, cisco use originator TSI. Ussually fax machine has in configuration menu a possibility to type a string. It would be number of this fax machine. It is only string, transmitted between faxes. Receiving fax machine sometimes display this CSID number on its display. It is not part of ISDN or VoIP signalization. This string is transmited when connection between fax machines is established.
Michal
I don't think it is possible to get this in TCL Script if it not part of call signalization.
Raghavendra
