How to search for multiple CUCM huntPilot in Python?
Young2020
Community Member
I can get a single huntPilot OK with the following API call
resp = axl_service.getHuntPilot(pattern='70001920', routePartitionName='PT-INTERNAL')
But I got errors when trying to seach for multiple huntPilots by the following API call
resp = axl_service.getHuntPilot(pattern='7%', routePartitionName='PT-INTERNAL')
Traceback (most recent call last):
File "/Users/python/cucm/PILOT/hp.py", line 88, in <module>
File "/Users/opt/anaconda3/lib/python3.9/site-packages/zeep/proxy.py", line 46, in __call__
return self._proxy._binding.send(
File "/Users/opt/anaconda3/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 135, in send
return self.process_reply(client, operation_obj, response)
File "/Users/opt/anaconda3/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 229, in process_reply
return self.process_error(doc, operation)
File "/Users/opt/anaconda3/lib/python3.9/site-packages/zeep/wsdl/bindings/soap.py", line 329, in process_error
raise Fault(
zeep.exceptions.Fault: Item not valid: The specified the specified pattern or routePartition not found was not found
if I try
axl_service.getHuntPilot(searchCriteria={'pattern': '7%'}, routePartitionName='PT-INTERNAL')
I got the following error
TypeError: {http://www.cisco.com/AXL/API/12.5}GetHuntPilotReq() got an unexpected keyword argument 'searchCriteria'. Signature: `({uuid: {http://www.cisco.com/AXL/API/12.5}XUUID} | {pattern: xsd:string, routePartitionName: {http://www.cisco.com/AXL/API/12.5}XFkType}), returnedTags: {http://www.cisco.com/AXL/API/12.5}RHuntPilot, sequence: xsd:unsignedLong`
npetrele
The 7% wild card is not a valid search parameter for getHuntPilot. If you want to get a list of hunt pilots matching 7%, then use listHuntPilot, instead.
npetrele
Great! listHuntPilot works. But is there a way to tell retuenTags to return all the values?
Here's a tip that should help you with all your AXL work:  Try the request with SoapUI first (click on the link to download the free, open source version), and then apply what you learned to your Python code.
