Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi Guys,The script is running on remote site.I'm able to listen the "options" prompt and collect digits process is working perfectly. But, when I press 1 for example the script make a call to CUCM phone and I have no voice in both sides. Important, w...
Hi Team, Just wondering if anyone has the IP Phone Services SDK.zip to share? I'm after any versions from 4.x to 7.x. I've been looking for it for a few hours already but it seems not to be available for download anymore. Any help would be appreciate...
Nhan Ho by • Level 1
  • 1813 Views
  • 1 replies
https://developer.cisco.com/site/tapi/wiki/supported-windows-os/Hello looking to find out when the matrix from the link above is going to be updated. We are looking to find out when 2016 server will be supported as well as what OS's are supported wit...
Hello,We integrate cucm with the onsoft recording server.The calling number is 11 digits and it is normal.When the cucm sends invite to the onsoft in the from field there is x-farendaddr and the cucm writes calling number to this column but it is 9 d...
nurcan by • Frequent Visitor
  • 2554 Views
  • 3 replies
Hello, I have very basic tcl script that I have been using.Recently I noticed that if internal called number does not answer the call is stay off-hook situation. And external caller if forgot to close the call line will be off-hook as well. So How ca...
Bar1s by • Level 4
  • 8534 Views
  • 6 replies
Hi everyone!I want to integrate uccm with 3rd party system. When someone is calling to agent it will be created task in our ticketing system.(via post request)What should I use for deal with it?I read about jtapi and axl api for uccm, but I don't und...
Bohdan1106 by • Community Member
  • 1855 Views
  • 1 replies
We've had issues with an application that leverages Cisco TSP and found there used to be an issue with RDP and TAPI/TSP instability (see below).  Is this still an issue?  The server is Windows 2012 R2 (64 bit).  Access to the Cisco Unified Attendant ...
Scott Bailey by • Frequent Visitor
  • 4494 Views
  • 3 replies
I am working to integrate web dialer into an environment using SOAP. We currently use SAML ADFS for internal applicatins.  I am trying to figure out how to capture the taken that is needed, to pass to CUCM, for SSO to work with CUCM. CUCM is already ...
MMstre by • Level 5
  • 1345 Views
  • 1 replies
Hi, I have attached the last script version and the debug to check please. The script flow is working properly but the I don't hear the ring tone.. I press the options and stay a "mute" period until someone answer the call. thanks.
