Passthrough CallerID as paramater to SIP normalisation script
Signups
Hi, I have been using a sip normalization script I found on this website to modify the from header
M={}
function M.outbound_INVITE(msg)
  local from = msg:getHeader("From")  --Get FROM Header
  local b = string.gsub(from, "<sip:.+@", "<sip:xxxxxxxxxx@")  --New FROM Header
  msg:modifyHeader("From", b)  --Replace FROM Header
end
return M
however ive been trying to modify it to allow the caller ID to be passed through from the CUCM trunk configuration interface
I found an example of this online but the value being changed is not the one I'm trying to change
M = {}
local ccaid = scriptParameters.getValue("CCA-ID")
    if ccaid
    then
        local contact = msg:getHeader("Contact")
        local replace = string.format("%s;CCA-ID=%s>", "%1", ccaid)
        contact = string.gsub(contact, "(<sip:.*)>", replace)
        msg:modifyHeader("Contact", contact)
    end
end
return M
Can anyone suggest how to modify this so that the x's in the from header are replaced by the value of CCA-ID ?
Signups
Here is the solution another admin suggested
M={}
local callingnumber= scriptParameters.getValue("callingnumber")
if callingnumber
then
local replace = "<sip:" .. callingnumber .. "@"
local b = string.gsub(from, "<sip:.+@", replace)  --New FROM Header
end
end
return M
Tested and working hope this helps someone else in the future
Nice tip, thanks for sharing
