problem about extension mobility invoked by interface
chao guo
Dear Team,
I met a problem that when I using the interface to set the extension mobility on ipphone, when I using the call manager(10.0.1-10000-22) is ok. when I change to using the call manager of 10.0.1-13010-1,It can not be set on ipphone by interface.
the source code I used like the following:
public static int login(String workstationURL,String deviceMac, String userid, String seq) {
  HttpClient client = new HttpClient();
  System.out.println("WorkStation URL"+workstationURL);
  StringBuffer url = new StringBuffer(workstationURL);
  url.append("?").append("device=").append(deviceMac.trim());
  url.append("&").append("userid=").append(userid.trim());
  url.append("&").append("seq=").append(seq.trim());
  System.out.println("url :"+url);
  GetMethod method = new GetMethod(url.toString());
  int i = 0;
  try {
   i = client.executeMethod(method);
  } catch (HttpException e) {
   e.printStackTrace();
  } catch (IOException e) {
   return i;
public static int logout(String workstationURL,String deviceMac) {
  url.append("&").append("&doLogout=").append(true);
  int i = 0;
  try {
   return i;
Is there any changes between the two version of call manager ?
many thanks.
Geevarghese Cheria
Hi Chao,
   I was not able to find any bugs related to CUCM 10.0.1-13010-1 with extension mobility.  This is one bug which i found CSCup75683. Since it works for 10.0.1-10000-22 the issue could be some attributes may not be supported in the version 10.0.1-13010-1.
Request to refer the following url and see if it works to login (not programmatically) just to ensure all services are configured and up and running - Configuring Extension Mobility on CUCM 10.x | IP Telephony | Cisco Support Community | 5961 | 12210496 . Then try once again using interface to set the extension mobility .
Thanks and Regards,
Geevarghese
Hi gcheria,
Thanks a lot, I will try it follow your suggestion.
Hi gcheria,
I  try to configure the em on the cucm following the document you provided, the em can be used(not programmatically).then I using the interface to set the em, also failure.
the following is the request I push to the cucm:
http://10.124.18.23:8080/emapp/EMAppServlet?device=SEP000C29C01D3D&userid=vip1&seq=111111
Thanks.
