Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
I have been working with a TCL that opens a text file...The problem is that the TCL did not close it...So now when I do a sh file descriptors its full 127 instance of same file..Is there a way to clear that cached info without rebooting the gw ?Thank...
Team,Does anyone have LUA script sample for removing the video m-line from any inbound invite from a Jabber client that contains a RECV-ONLY attribute? We want to disable Jabber's ability to receive & send video due to limited bandwidth. Turning off ...
Tomoo Esaka by Cisco Employee
  • 1180 Views
  • 1 replies
Hi,I observed that adding an observer to terminal takes more than 1 second.Its quite a slow operation. I have thousand terminals in my setup.Initializing JTAPI application with these thousand terminals take lot of time.I am using two approaches here:...
Hello,    I have an app that conferences several calls together on one CTI port.   I have a CTI port with 2 calls conferenced.  When this CTI port answers a third call (from a transfer), the terminal connection state goes to HELD.   An attempt to con...
mstromske by Community Member
  • 1186 Views
  • 1 replies
Hello,On CUCM 9.0.1.1, I am getting error as below:Unable to create provider -- Timed Out while waiting for ProviderGetAllDevicesAndLinesCompletedEvent.Application works perfectly in Windows.But when I migrate my application to Linux, I am getting ab...
I am working with a vendor that I currently have setup with an application user that is able to pull names and extensions from CUCM 9.1.2.  What they are telling me is they cannot pull the MAC address information from the jtapi integration so they ca...
Need procedures on the JTAPI upgrade. Need top install new versions on  our Peripheral Gateways. CM recently upgradedAny help please
gaillard3 by Frequent Visitor
  • 743 Views
  • 1 replies
