Provider getTerminals returns null
razaali20
Community Member
After creating the provider and waiting for it to be up and running, I tried calling provider.getTerminals(). But this method returns null.
When I looked at the properties of the provider, I found "canobserveanyterminal" property having 'null' value (that is it is neither true nor false, just null).
Can you please advise what user permission is required to obtain a list of terminals?
mpotluri
Level 9
Level 9
Devices added to the "Controlled Devices" section of enduser or application user configuration on CUCM admin will be reported in provider.getTerminals(). How many devices did you configure?
I would recommend using JTAPI test tool to eliminate any configuration/ application issues.
mpotluri
Level 9
Level 9
Thanks Mohan. My Administrator created another user for JTAPI and I added devices to it which returned successfully via getTerminals.
The other user I was using earlier never showed the "Device Information" section for some reason. I assumed it was able to access all devices as the Roles and Groups clearly showed "control all devices".
Anyways, thanks for your help.
Hello guys,
I added terminals to "Device Information". After calling provider.getTerminals() I get list of configured devices but sometimes I get null and then again I can get terminals and then I can get only one terminal. Of what does it depend on?
For example:
- I write simple program where I connect to CUCM by ip and user.
- I call provider.getTerminals()
- Print list of terminals(sometimes it is null)
- Call provider.shootdown()
Starting this application from console gives me different results.
Please, help. I can't find information in the documentation and internet why list of terminals disappears.
Are you waiting for provider to get into in-service state before calling provider.getTerminals()?
Refer to makecall or jtrace sample app code on how to wait for provider to get to in-service state.
