Setting call precedence ?
paolo bevilacqua
There is an undocumented infotag (leg_precedence_info) to to get MLPP precedence of an incoming call.
Is there a way to directly set precedence for an outgoing call, like a callInfo element ?
Currently I set SIP headers via callInfo(protoHeader), but the limitation is that for calls made to FXS on the same router the destination will fast ring _only_ if the leg setup is done with autoconferencing to a leg that has precedence already.
5 Replies 5
paolo bevilacqua
Duplicate please ignore
yawming
leg_precedence_info is only used for MLPP IOS image.
There is no way to set precedence for an outgoing call.
Thank you for you answer. Are you responding as a Cisco employee ?
As who added those MLPP code.
Thank you yawchen.
