Setting Remote-Party-ID in SIP header ?
paolo bevilacqua
When an incoming call is auto-conferenced to leg setup the SIP header in subject is copied and relayed.
The result is that calling party sees the called name.
Is there a way to set the called name in a "leg alert" or "leg progress" command when the incoming call is handled by the script and not auto-conferenced ?
Raghavendra G V
I don't think it is possible to set the called name in a "leg alert" or "leg progress" command.
Did you try to issue leg setup command without passing incoming leg.
Raghavendra
My issue is passing a name when answering a call, so "leg setup" is not involved.
If you are not using leg setup then how do you place call, are you handoff call to IOS ?
Raghavendra
As mentioned twice above already, the script does not place call - it answers.
