06-22-2015 01:55 PM
Hi Guys,
I am wondering if somebody can provide me with a sample TCL script to be used in incoming dial-peer for SIP calls redirect on my CUBE gateway. I.e. I need to send SIP 3xx to ITSP, so they will redirect or divert this call accordingly and with that release both call legs on my local CUBE.
Thanks!
06-23-2015 11:55 AM
Actually I have created a simple vxml script myself
<?xml version="1.0" encoding="UTF-8"?>
<vxml xmlns="http://www.w3.org/2001/vxml" xmlns:conf="http://www.w3.org/2002/vxml-conformance" version="2.0">
<form id="xfer">
<transfer name="mycall" type="refer" dest="tel:+22736" bridge="false">
</transfer>
</form>
</vxml>
And it works on my CUBE router, does the transfer, when I enable service on the inbound dial-peer, but the problem is that it does not actually send REFER message but sends INVITE instead, therefore keeping CUBE in the loop. I need this to be like RTT release trunk transfer, wondering if this is something that can be done on the CUBE.
thanks!
06-25-2015 05:12 AM
You can set mode as below for redirect, for sample scripts and programming guide please refer https://developer.cisco.com/site/voice-gateway/documentation/
set callInfo(mode) REDIRECT
leg setup $ReferDnis callInfo leg_incoming
please refer below H450 TCL script also
Raghavendra
06-25-2015 01:18 PM
Thanks very much Raghavendra !
So the method you submitted ends up as SIP REFER / NOTIFY being submitted back to calling party, I am wondering what the method would be to send SIP 3XX message i.e. 302, moved temporarily instead of REFER?
Here is my code that I did for SIP REFER
proc act_Media { } {
global dest
set dest 22736
leg setupack leg_incoming
leg proceeding leg_incoming
leg connect leg_incoming
media play leg_incoming flash:welcome.au
# setup the call, connect caller to called party
proc act_Setup { } {
global dest
puts ">>> Tcl: proc act_Setup <<<"
puts ">>> TCL:Final Dest: $dest <<<"
set callInfo(originationNum) 23402
#set callInfo(rerouteMode) REDIRECT_ROTARY
leg setup $dest callInfo leg_incoming
proc act_CallSetupDone { } {
set status [infotag get evt_status]
puts "\n CALL STATUS = $status"
if { $status == "ls_000"} {
puts "\n You have sucessfully placed the call to the destination !"
} else {
puts "\n Sorry your call was not connnected !"
call close
# disconnect the call
proc act_Cleanup { } {
puts ">>> Tcl: act_Cleanup <<<"
call close
set fsm(any_state,ev_disconnected) "act_Cleanup same_state"
set fsm(CALL_INIT,ev_setup_indication) "act_Media PLAYPROMPT"
set fsm(PLAYPROMPT,ev_media_done) "act_Setup PLACECALL"
set fsm(PLACECALL,ev_disconnected) "act_Cleanup CALLDISCONNECT"
set fsm(PLACECALL,ev_setup_done) "act_CallSetupDone CALLDISCONNECT"
set fsm(CALLDISCONNECT,ev_disconnected) "act_Cleanup same_state"
set fsm(CALLDISCONNECT,ev_disconnect_done) "act_Cleanup same_state"
fsm define fsm CALL_INIT
06-25-2015 10:09 PM
please try with alert as below.
set callInfo(mode) REDIRECT_AT_ALERT
Raghavendra
06-26-2015 07:22 AM
but it sends INVITE now, I need that thing to send 3xx no refer no invite, something like 302 moved temprorarily ![]()
06-28-2015 10:10 PM
I don't think we can send 302 with TCL script other than sip invite or refer message.
Raghavendra
07-02-2015 10:05 AM
The mode you mentioned is undocumented. Documented modes are:
Which other modes exists, and what is their differences from the documented modes ?
07-02-2015 10:39 AM
There are REDIRECT_AT_ALERT and REDIRECT_AT_CONNECT, commonly used for TBCT.
REDIRECT_AT_ALERT -- if doing TBCT, PSTN switch will disconnect transfer by leg and trying to connect to transfer to leg. (there is a chance that transfer to leg won't get connected but transfer by leg disconnected already)
REDIRECT_AT_CONNECT transfer by leg is disconnected only when the transfer to leg is connect.
So the difference is when to release transfer by leg when doing TBCT.
07-02-2015 06:15 AM
You can disconnect the leg like this in tcl.
leg disconnect leg_incoming -c1
c1 is cause 1 for ISDN cause code "Unallocated or unassigned number"
you can find the list of cause codes here:
Q.931 - Wikipedia, the free encyclopediahttps://en.wikipedia.org/wiki/Q.931
07-12-2018 09:42 PM
hello Farhad,
i'm having a need that may be as youre's, i was wondering if you can help me. i have not a gw connected to PSTN (E1 or Sip trunk) and i need that when an specific number is called inbound i do play a prompt asking for the destination number and then i just need to add to the dialed number an static @domain.com to transfer the call internally you think you can show me how to achieve that? can you share you script?
thanks
07-13-2018 12:27 AM
you can try to set destination as below.
set dest "sip:1234567@abc.com"
leg setup $dest callinfo leg_incoming
Raghavendra
