take over a monitored call
denes.istvan
I have two applications: A has opened line 1, B is monitoring line 1. If there is an incoming call on line 1, A will accept, than answers it. In case A crashes, can B take over the call, meaning continue somehow the conversation?
6 Replies 6
smupadhy
Let me research this and get back to you.
smupadhy
In this case Line1 seems to be on CTIPort (based on the fact that application is accepting the call). Can you confirm that?
If it is a CTIPort, application B can take over if the following conditions are met:
  • Both application A and B (running on different machines), have registered the port dynamically with the same capabilities.
  • Application A and B, co-ordinate with each other and know when to take over.
This logic is used by Cisco UCCE application for remote agents.
yes Line 1 is a CTIPort.
What do you mean that application A and B co-ordintate with each other?
Thanks.
In order for Application B to take over the call, it has to know that Application A has crashed and is no longer available. For that, B has to have some kind of ping/heartbeat mechanism/communication in place with A. Also, other considerations could be - B taking over in particular call scenarios Vs all call scenarios, etc.
Ok, so if A crashes, the call doesn't get closed? And if B monitors A correctly, than it can take over the call, maybe redirect it to C?
Yes, that is correct.
