Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi,I observed that adding an observer to terminal takes more than 1 second.Its quite a slow operation. I have thousand terminals in my setup.Initializing JTAPI application with these thousand terminals take lot of time.I am using two approaches here:...
Hello,    I have an app that conferences several calls together on one CTI port.   I have a CTI port with 2 calls conferenced.  When this CTI port answers a third call (from a transfer), the terminal connection state goes to HELD.   An attempt to con...
mstromske by • Community Member
  • 1211 Views
  • 1 replies
Hello,On CUCM 9.0.1.1, I am getting error as below:Unable to create provider -- Timed Out while waiting for ProviderGetAllDevicesAndLinesCompletedEvent.Application works perfectly in Windows.But when I migrate my application to Linux, I am getting ab...
I am working with a vendor that I currently have setup with an application user that is able to pull names and extensions from CUCM 9.1.2.  What they are telling me is they cannot pull the MAC address information from the jtapi integration so they ca...
Need procedures on the JTAPI upgrade. Need top install new versions on  our Peripheral Gateways. CM recently upgradedAny help please
gaillard3 by • Frequent Visitor
  • 757 Views
  • 1 replies
I have a TAPI application running in production that restarts every morning and opens a number of lines to monitor. This had been running fine up until a couple days ago and now lineOpen() is failing for every line with the error LINEERR_RESOURCEUNAV...
bhoover02 by • Level 3
  • 1465 Views
  • 2 replies
