TAPI Licensing
bhoover02
Level 3
Level 3
Is there any licensing required to use the Cisco TSP against CUCM?
jocreed
Ben, there is no licensing required to use TSP/TAPI with CUCM.  The only licenses that are relevant would be ones associated with CUCM only.  Depending on the licenses you have with CUCM, that will determine the number of devices and users you are allowed to provision with Call Manager.
Thanks for the reply. Do you know which CUCM licenses are needed to be able to run a third party TAPI call monitoring application?
There are no additonal licenses required.  You can run a third party TAPI application even on demo licenses for call manager.
