Showing results forĀ
Search instead forĀ
Did you mean:Ā
TCL-IVR for Inbound VoIP Dial-Peer - Pre-Announce before ringing the phone
KY_
Level 4
Level 4
Hi Team
We want to play announce before ringing  the phone. Does someone provide me working tcl script and configuration.
Call Flow
ISP--> SIP-VG-[TCL scrip should play announce file stored on VG] -SIP- CUCM-- Directory Number.
On this time, Tcl scrip working for pots dial-peer for following scnerio.
PSTN/PRI- -VG- CUCM- DN
"flash0:c2951-universalk9-mz.SPA.152-4.M6a.bin"
This is a new deployment.
CUCM version:10.0.1.12900-2
We have two CUCM server (Pub /Sub)
Application config;
File name:kisa2.au
application
service seskayit app_fax_detect.2.1.2.2.tcl
  param mode listen-first
  param prompt flash:kisa2.au
Error related param config issue. Below is the correct way to configure, you need to mention location of tcl file and audio file.
hope you copied both files to flash.
service play2connect flash:play_message_2_calling_then_connect.tcl
  param prompt-1 flash:kisa2.au
Raghavendra
18 Replies 18
Raghavendra G V
Hi Kemal,
please check below link.
play message to calling party then connect to called
Raghavendra
This my latest configuration but when I apply   service play2connect on voip dial-peer I'm getting busy tone.
When i apply  service play2connect on  dial-peer 74001 I'm  getting busy tone after removing  service play2connect command phone is ringing. What could be problem.
incoming dial-peer,
dial-peer voice 74001 voip
session protocol sipv2
incoming called-number 08507227400$
voice-class codec 1
voice-class sip bind media source-interface GigabitEthernet0/0
dtmf-relay rtp-nte
fax-relay ecm disable
fax-relay sg3-to-g3
fax nsf 000000
no vad
VROUTER#sh call application voice play2connect
Script Name : play2connect
       URL  : flash:play_message_2_calling_the$
       Type : Service
       State: Not Loaded
       Life : Configured
       Exec Instances: 0
Script Code Begin:
_VROUTER#
debug voice application output.
ISLEASING_VROUTER#sh logg
ISLEASING_VROUTER#sh logging
Syslog logging: enabled (0 messages dropped, 20 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 61 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 91418 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 477 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (10000000 bytes):
122865: Dec  8 11:05:29.268: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service Default modulehandle NULL
122866: Dec  8 11:05:29.268: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = Default
122867: Dec  8 11:05:29.268: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
122868: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_SetRoot: Execenv = 0x14DD4B5C
122869: Dec  8 11:05:29.268: //-1//AFW_:/AFW_M_TclModule_NewDup:
122870: Dec  8 11:05:29.268: //-1//AFW_:HN73CA517C:/AFW_M_TclModule_Free:
122871: Dec  8 11:05:29.268: //-1//AFW_:HN73CA517C:/AFW_M_Module_GetHandle: Module handle: TclModule_0x35A34F4_2_1942638972MOD[TclModule_0x35A34F4_2_1942638972]      ( )
122872: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB55424C)=2
122873: Dec  8 11:05:29.268: //-1//AFW_:LP:EE14DD4B5C000:HN73CB5EF4:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
122874: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
122875: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
122876: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_Initiate: Execenv = 0x14DD4B5C
122877: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_SetCallCorID:
122878: Dec  8 11:05:29.268:  CallCorID is k^ER~<S^Qf j|^NN3)
122879: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Leg_New:
122880: Dec  8 11:05:29.268: //782328//AFW_:/AFW_M_Leg_SetExecEnv:
122881: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
122882: Dec  8 11:05:29.268: //-1//AFW_:LP:EE14DD4B5C000:LG782328:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
122883: Dec  8 11:05:29.268: //782328//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
122884: Dec  8 11:05:29.268: //782328//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782328
122885: Dec  8 11:05:29.268: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_AssignCall: Execenv = 0x14DD4B5C, Leg = 782328, Peer_Tag = 100
122886: Dec  8 11:05:29.268: //782328//AFW_:/AFW_ExecEnv_SetCallCorID:
122887: Dec  8 11:05:29.268:  CallCorID is k^ER~<S^Qf j|^NN3)
122888: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
122889: Dec  8 11:05:29.268: //782328//AFW_:/AFW_Process_GetCcqEvent: Received
122890: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
122891: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
122892: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782328][LEG_INIT(0)][Cause(0)]
122893: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
122894: Dec  8 11:05:29.268: //782328//SSIN:/AFW_SS_MapEvent:
122895: Dec  8 11:05:29.268: //782328//AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
122896: Dec  8 11:05:29.268: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
122897: Dec  8 11:05:29.268: //-1//AFW_:/AFW_Util_SaveRawMsg:
122898: Dec  8 11:05:29.268: //782328/EB05527EA0EA/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E8 type 0
122899: Dec  8 11:05:29.268: //782328/EB05527EA0EA/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [2] for dial-peer [100]
122900: Dec  8 11:05:29.268: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
122901: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
122902: Dec  8 11:05:29.272: //-1//AFW_:/AFW_M_Object_ShowListeners:
122903: Dec  8 11:05:29.272: //782328//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x35A2354_2_1942707956MOD[TclModule_0x35A2354_2_1942707956]  (
122904: Dec  8 11:05:29.272: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCINIT(1)][Cause(0)]
122905: Dec  8 11:05:29.272: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
122906: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
122907: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
122908: Dec  8 11:05:29.272: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> TclModule_0x35A2354_2_1942707956
122909: Dec  8 11:05:29.272: //782328//AFW_:/AFW_M_TclModule_Action:
122910: Dec  8 11:05:29.272: //782328//AFW_:/AFW_TclModule_DefaultEvHandling:
122911: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_CheckIncomingCallBlock:
122912: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
122913: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_IncomingTranslate:
122914: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(100) calling[05324612631] redirect[] called[425]
122915: Dec  8 11:05:29.272: //-1//AFW_:/C_ServiceSession_Event_Handler:
122916: Dec  8 11:05:29.272: //782328//XCCS:/C_PackageXCCSession_AcceptCallCheck: No AcceptCall; XCC application is unregistered
122917: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Session_New:
122918: Dec  8 11:05:29.272: //-1//AFW_:/AFW_FSM_New:
122919: Dec  8 11:05:29.272: //-1//AFW_:HN73CB5EF8:/AFW_M_Session_SetExecEnv:
122920: Dec  8 11:05:29.272: //-1//AFW_:LP:EE14DD4B5C000:HN73CB5EF8:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
122921: Dec  8 11:05:29.272: //782328//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
122922: Dec  8 11:05:29.272: //782328//AFW_:/AFW_M_Module_GetHandle: Module handle: Session_0x15B32938_2_1942707960
122923: Dec  8 11:05:29.272: //782328//AFW_:/C_PackageSession_NewCall: Session module listened by TclModule_0x35A2354_2_1942707956
122924: Dec  8 11:05:29.272: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> Session_0x15B32938_2_1942707960
122925: Dec  8 11:05:29.272: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_OPEN[1],ev_setup_indication[34])---[C_Action]------
122926: Dec  8 11:05:29.272: //782328//AFW_:/Open_SetupIndication: Calling #(05324612631), Calling Name (), Called #(425), peer_tag(100)
122927: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetCalledNumber: calledNumber = 425
122928: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Object_AddListener: adding Module Session as listener
122929: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetUserFromURL:
122930: Dec  8 11:05:29.272:  destination: 425
122931: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetUserFromURL:
122932: Dec  8 11:05:29.272:  ret_val : 425
122933: Dec  8 11:05:29.272: //-1//AFW_:/SetupDestination: SetupDestination: afwSSApdu is NULL
122934: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
122935: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
122936: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
122937: Dec  8 11:05:29.272: //782328//AFW_:/SetupDestinationSnrHandler:
122938: Dec  8 11:05:29.272: //782328//AFW_:/ProcessSnrDestination:
122939: Dec  8 11:05:29.272: //782328//AFW_:/ResetSnrParamenter:
122940: Dec  8 11:05:29.272: //782328//AFW_:/SetupDestinationSnrHandler: not snr call
122941: Dec  8 11:05:29.272: //782328//AFW_:/SetupValidateSharedln: calledNum=425, callingNum=05324612631, callID=782328,  callinf.peertag=100, joinXtoID=0
122942: Dec  8 11:05:29.272: //782328//AFW_:/SetupDestination:
122943: Dec  8 11:05:29.272:  destinations[0] = 425
122944: Dec  8 11:05:29.272: //782328//CSPK:/C_CallSetup_Start: ControlInfo = 0x3487544, callInfo = 0x154E020C, destination[0]=425
122945: Dec  8 11:05:29.272: //782328//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
122946: Dec  8 11:05:29.272: //-1//Call:/AFW_CallSetup_New:
122947: Dec  8 11:05:29.272: //-1//AFW_:/AFW_FSM_New:
122948: Dec  8 11:05:29.272: //-1//AFW_:LP:EE14DD4B5C000:HN73CB5EF8:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
122949: Dec  8 11:05:29.272: //782328//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
122950: Dec  8 11:05:29.272: //782328//AFW_:/AFW_Object_AddListener: adding Module Session as listener
122951: Dec  8 11:05:29.272: //782328//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_0x1560A230_2_1942707960
122952: Dec  8 11:05:29.272: //782328//Call:/AFW_CallSetup_AddDest:  425 index 0
122953: Dec  8 11:05:29.272: //782328//Call:/AFW_CallSetup_SetIntWrkLeg:
122954: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_SignalPeerGet: Leg [782328]
122955: Dec  8 11:05:29.272: //-1//AFW_:/C_PackageSession_GetSigPeer:
122956: Dec  8 11:05:29.272: //782328//Call:/AFW_M_CallSetup_Initiate:
122957: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
122958: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
122959: Dec  8 11:05:29.272: //782328//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
122960: Dec  8 11:05:29.272: //782328//Call:/CallSetupInitiate:
122961: Dec  8 11:05:29.272: //782328//Call:/CS_Placecall:
122962: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetUserFromURL:
122963: Dec  8 11:05:29.272:  destination: 425
122964: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_GetUserFromURL:
122965: Dec  8 11:05:29.272:  ret_val : 425
122966: Dec  8 11:05:29.272: //782328//Call:/setupHuntGroupInfo: set intWrkLeg id=782328 hgTag=-1 oldhgTag=-1 bacd=0
122967: Dec  8 11:05:29.272: //782328//Call:/CS_Placecall: enable reroute_ind intercept for reroutemode REDIRECT_ROTARY
122968: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
122969: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
122970: Dec  8 11:05:29.272: //782328//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
122971: Dec  8 11:05:29.272: //-1//Dest:/AFW_Destination_New:
122972: Dec  8 11:05:29.272: //-1//AFW_:/AFW_FSM_New:
122973: Dec  8 11:05:29.272: //-1//AFW_:/AFW_FSM_New:
122974: Dec  8 11:05:29.272: //-1//AFW_:LP:EE14DD4B5C000:HN73CB5EF8:/AFW_M_Object_SetExecEnv: ObjCount: 5, CmdPending 2
122975: Dec  8 11:05:29.272: //782328//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
122976: Dec  8 11:05:29.272: //782328//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
122977: Dec  8 11:05:29.272: //782328//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_0x17CFA530_2_1942707960
122978: Dec  8 11:05:29.272: //782328//Dest:/AFW_Destination_AddDest:
122979: Dec  8 11:05:29.272: //-1//Dest:/AFW_Destination_AddDest: adding destination "425"
122980: Dec  8 11:05:29.272: //782328//Dest:/AFW_Destination_SetIntWrkLeg: LEG[782328 ][LEG_INCPROCEED(3)][Cause(0)]
122981: Dec  8 11:05:29.272: //782328//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
122982: Dec  8 11:05:29.272: //782328//Dest:/DestSetIntWrkLeg:
122983: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
122984: Dec  8 11:05:29.272: //782328//Dest:/AFW_M_Destination_Initiate:
122985: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_SaveRawMsg:
122986: Dec  8 11:05:29.272: //782328//Dest:/AFW_M_Destination_Initiate: Outgoing guid : EB05527E.BC5311E6.A0EA7C0E.CEB32900
122987: Dec  8 11:05:29.272:  Incoming_guid : 00000000.00000000.00000000.00000000
122988: Dec  8 11:05:29.272: //782328//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : EB05527E.BC5311E6.A0EA7C0E.CEB32900
122989: Dec  8 11:05:29.272:  Incoming_gcid : 00000000.00000000.00000000.00000000
122990: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
122991: Dec  8 11:05:29.272: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
122992: Dec  8 11:05:29.272: //782328//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
122993: Dec  8 11:05:29.272: //782328//Dest:/DestSetupInitiate:
122994: Dec  8 11:05:29.272: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
122995: Dec  8 11:05:29.272: //782328//Dest:/DestLocalConsultHandoff: no local handoff, intwrk leg 184B8A68, consult id 14C1DFE0
122996: Dec  8 11:05:29.276: //782328//Dest:/DestAddRerouteSetupInfo:
122997: Dec  8 11:05:29.276: //782328//Dest:/DestAddTransferSetupInfo:
122998: Dec  8 11:05:29.276: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 425
122999: Dec  8 11:05:29.276: //782328//Dest:/DestMatchDialPeer:
123000: Dec  8 11:05:29.276: //782328//Dest:/DestMatchDialPeer: src carrier id:telekom, tgt carrier id:
123001: Dec  8 11:05:29.276: //782328//Dest:/DestQueuePeers: Matched peers:
123002: Dec  8 11:05:29.276: //782328//Dest:/DestPeerItemUpdatePreemptInfo:
123003: Dec  8 11:05:29.276: //782328//Dest:/DestPeerItemResetLPCORInfo:
123004: Dec  8 11:05:29.276: //-1//Dest:/DestQueuePeers:  777
123005: Dec  8 11:05:29.276: //782328//Dest:/DestPeerItemUpdatePreemptInfo:
123006: Dec  8 11:05:29.276: //782328//Dest:/DestPeerItemResetLPCORInfo:
123007: Dec  8 11:05:29.276: //-1//Dest:/DestQueuePeers:  778
123008: Dec  8 11:05:29.276: //-1//Dest:/DestQueuePeers: , Total(2)
123009: Dec  8 11:05:29.276: //782328//Dest:/DestDialPeerRotary:
123010: Dec  8 11:05:29.276: //782328//Dest:/DestOutboundCallUsingPeer: dest(425), numexpDest(7425), numDestDigits(2)
123011: Dec  8 11:05:29.276: //782328//Dest:/DestOutboundCallUsingPeer:    prefix(1.18), peer tag(777)
123012: Dec  8 11:05:29.276: //782328//Dest:/DestUpdatePreemptSetupInfo:
123013: Dec  8 11:05:29.276: //782328//Dest:/DestDialPeerFilter:
123014: Dec  8 11:05:29.276: //782328//Dest:/DestDialPeerFilter: Checking peer [777]
123015: Dec  8 11:05:29.276: //782328//Dest:/DestPeerFilterRouteCode: Route Code not available in callInfo
123016: Dec  8 11:05:29.276: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(777) calling[05324612631] called[7425]
123017: Dec  8 11:05:29.276: //782328//Dest:/DestCheckTeleUnassBusy:
123018: Dec  8 11:05:29.276: //782328//Dest:/DestHandleLPCOR:
123019: Dec  8 11:05:29.276: //782328//Dest:/DestSetup:
123020: Dec  8 11:05:29.276: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123021: Dec  8 11:05:29.276: //-1//AFW_:/AFW_Util_SaveRawMsg:
123022: Dec  8 11:05:29.276: //782328//Dest:/DestSetup: snrPeerCallID 0 intWrkLegID 782328
123023: Dec  8 11:05:29.276: //-1//AFW_:/AFW_Leg_New:
123024: Dec  8 11:05:29.276: //782329/EB05527EA0EA/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
123025: Dec  8 11:05:29.276: //782329/EB05527EA0EA/AFW_:/AFW_M_Leg_SetExecEnv:
123026: Dec  8 11:05:29.276: //782328//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 4
123027: Dec  8 11:05:29.276: //-1/EB05527EA0EA/AFW_:LP:EE14DD4B5C000:LG782329:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 4
123028: Dec  8 11:05:29.276: //782329/EB05527EA0EA/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
123029: Dec  8 11:05:29.276: //782329/EB05527EA0EA/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782329
123030: Dec  8 11:05:29.276: //782329/EB05527EA0EA/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E8 type 3
123031: Dec  8 11:05:29.276: //782328//Dest:/DestSetup: Destination setup success
123032: Dec  8 11:05:29.276: //782328//Dest:/AFW_M_Destination_Initiate: attempting call to destination 425
123033: Dec  8 11:05:29.276: //782328//Call:/CS_Placecall: Call placed to 425 index 0
123034: Dec  8 11:05:29.276: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
123035: Dec  8 11:05:29.276: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B32938_2_1942707960 ---> TclModule_0x35A2354_2_1942707956
123036: Dec  8 11:05:29.276: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> TclModule_0x35A2354_2_1942707956
123037: Dec  8 11:05:29.276: //782328/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123038: Dec  8 11:05:29.276: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123039: Dec  8 11:05:29.276: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123040: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_Process_GetCcqEvent: Received
123041: Dec  8 11:05:29.280: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
123042: Dec  8 11:05:29.280: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123043: Dec  8 11:05:29.280: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782329][LEG_OUTINIT(7)][Cause(0)]
123044: Dec  8 11:05:29.280: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123045: Dec  8 11:05:29.280: //782329/EB05527EA0EA/SSIN:/AFW_SS_MapEvent:
123046: Dec  8 11:05:29.280: //-1//SSIN:/AFW_SS_SIP_MapEvent:
123047: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_M_Leg_EventPreProcess: LEG[782329 ][LEG_OUTINIT(7)][Cause(0)]
123048: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123049: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123050: Dec  8 11:05:29.280: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17CFA530_2_1942707960]  (
123051: Dec  8 11:05:29.280: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCPROCEED(3)][Cause(0)]
123052: Dec  8 11:05:29.280: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782329][LEG_OUTINIT(7)][Cause(0)]
123053: Dec  8 11:05:29.280: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123054: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123055: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123056: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17CFA530_2_1942707960
123057: Dec  8 11:05:29.280: //782328//Dest:/AFW_M_Destination_Action:
123058: Dec  8 11:05:29.280: //782328//Dest:/AFW_Destination_Action:
123059: Dec  8 11:05:29.280: //782328//Dest:/OB_FSM_Drive:
123060: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123061: Dec  8 11:05:29.280: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
123062: Dec  8 11:05:29.280: //782328//Dest:/OB_Setting_Proceeding:
123063: Dec  8 11:05:29.280: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
123064: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123065: Dec  8 11:05:29.280: //782328//Dest:/IW_FSM_Drive:
123066: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123067: Dec  8 11:05:29.280: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_proceeding[31])---[C_Action]------
123068: Dec  8 11:05:29.280: //782328//Dest:/IW_InitProc_Proceeding:
123069: Dec  8 11:05:29.280: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_INIT[1])---------------
123070: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123071: Dec  8 11:05:29.280: //782328//Dest:/DestIsEventNotified:
123072: Dec  8 11:05:29.280: //782328//Dest:/DestComplete: peer #:777 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
123073: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> NULL
123074: Dec  8 11:05:29.280: //782329/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123075: Dec  8 11:05:29.280: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123076: Dec  8 11:05:29.360: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123077: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_Process_GetCcqEvent: Received
123078: Dec  8 11:05:29.360: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_ALERT(16)] {
123079: Dec  8 11:05:29.360: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123080: Dec  8 11:05:29.360: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782329][LEG_OUTPROCEED(8)][Cause(0)]
123081: Dec  8 11:05:29.360: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123082: Dec  8 11:05:29.360: //782329/EB05527EA0EA/SSIN:/AFW_SS_MapEvent:
123083: Dec  8 11:05:29.360: //-1//SSIN:/AFW_SS_SIP_MapEvent:
123084: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/updateInitialDisplayNumber: Final Dial String Unavailable
123085: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123086: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123087: Dec  8 11:05:29.360: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17CFA530_2_1942707960]  (
123088: Dec  8 11:05:29.360: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCPROCEED(3)][Cause(0)]
123089: Dec  8 11:05:29.360: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782329][LEG_OUTPROCEED(8)][Cause(0)]
123090: Dec  8 11:05:29.360: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123091: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123092: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123093: Dec  8 11:05:29.360: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17CFA530_2_1942707960
123094: Dec  8 11:05:29.360: //782328//Dest:/AFW_M_Destination_Action:
123095: Dec  8 11:05:29.360: //782328//Dest:/AFW_Destination_Action:
123096: Dec  8 11:05:29.360: //782328//Dest:/OB_FSM_Drive:
123097: Dec  8 11:05:29.360: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123098: Dec  8 11:05:29.360: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_alert[16])---[C_Action]------
123099: Dec  8 11:05:29.360: //782328//Dest:/OB_Setting_Alert:
123100: Dec  8 11:05:29.360: //-1//Dest:/OB_Setting_Alert: aData bitmask 0x81000001
123101: Dec  8 11:05:29.360: //-1//Dest:/OB_Setting_Alert: aData.display_info=MUSTAFA MANKIRCI
123102: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =7425,notifyData.display_info = MUSTAFA MANKIRCI,notifyData.connected_num.oct3a = 0
123103: Dec  8 11:05:29.360: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7425,notifyData.display_info = MUSTAFA MANKIRCI,notifyData.connected_num.oct3a = 0
123104: Dec  8 11:05:29.360: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
123105: Dec  8 11:05:29.360: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123106: Dec  8 11:05:29.360: //782328//Dest:/IW_FSM_Drive:
123107: Dec  8 11:05:29.360: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123108: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_alert[16])---[C_Action]------
123109: Dec  8 11:05:29.364: //782328//Dest:/IW_AlertRing:
123110: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123111: Dec  8 11:05:29.364: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: :opcode=1, Name=MUSTAFA MANKIRCI
123112: Dec  8 11:05:29.364: //-1//SSIN:/AFW_SS_PrepareNameInfoContent:
123113: Dec  8 11:05:29.364:  AFW_SS_PrepareNameInfoContent: ssInfo=0x17A69188
123114: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123115: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7425,notifyData.display_info = MUSTAFA MANKIRCI,notifyData.connected_num.oct3a = 0
123116: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123117: Dec  8 11:05:29.364: //782328/EB05527EA0EA/Dest:/DestRingBackFromApp: Leg state [LEG_INCALERTING], alert_sent [1], tone_playing [0]
123118: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123119: Dec  8 11:05:29.364: //782328//Dest:/DestRingBack: Playing Ringback Tone
123120: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GenerateTone:  ccTone 1 cptone 1
123121: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetCodec:
123122: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
123123: Dec  8 11:05:29.364: //782328//Dest:/DestUpdateDisplayInfo:
123124: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123125: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[782328] display using Leg[782329] info
123126: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123127: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123128: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7425,notifyData.display_info = MUSTAFA MANKIRCI,notifyData.connected_num.oct3a = 0
123129: Dec  8 11:05:29.364: //782328/EB05527EA0EA/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[782328] display not supported
123130: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_OOB[2])---------------
123131: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123132: Dec  8 11:05:29.364: //782328//Dest:/DestIsEventNotified:
123133: Dec  8 11:05:29.364: //782328//Dest:/DestComplete: peer #:777 IW State IW_STATE_ALERT_OOB, OB State OB_STATE_SETTING
123134: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> NULL
123135: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Event Interceptd : Destination
123136: Dec  8 11:05:29.364: //782328//AFW_:/AFW_Object_WalkListeners:
123137: Dec  8 11:05:29.364: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123138: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1560A230_2_1942707960]  (
123139: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17CFA530_2_1942707960]  (
123140: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782328][LEG_INCALERTING(4)][Cause(0)]
123141: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782329][LEG_OUTRINGING(9)][Cause(0)]
123142: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123143: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123144: Dec  8 11:05:29.364: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123145: Dec  8 11:05:29.364: //782328//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
123146: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1560A230_2_1942707960
123147: Dec  8 11:05:29.364: //782328//Call:/AFW_M_CallSetup_Action:
123148: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_alert[16])---[C_Action]------
123149: Dec  8 11:05:29.364: //782328//Call:/CS_Placecall_CallSignal:
123150: Dec  8 11:05:29.364: //782328//Call:/CS_Placecall_CallSignal:  Event notified to parent
123151: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_PLACECALL[2])---------------
123152: Dec  8 11:05:29.364: //782328//Call:/CS_Complete: Can't complete
123153: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1560A230_2_1942707960 ---> NULL
123154: Dec  8 11:05:29.364: //782328//AFW_:/AFW_Object_WalkListeners: Event Interceptd : CallSetup
123155: Dec  8 11:05:29.364: //782328//AFW_:/AFW_Object_WalkListeners:
123156: Dec  8 11:05:29.364: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123157: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x15B32938_2_1942707960]  (
123158: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCALERTING(4)][Cause(0)]
123159: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560A230_2_1942707960]  (
123160: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x17CFA530_2_1942707960]  (
123161: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782328][LEG_INCALERTING(4)][Cause(0)]
123162: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782329][LEG_OUTRINGING(9)][Cause(0)]
123163: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
123164: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123165: Dec  8 11:05:29.364: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123166: Dec  8 11:05:29.364: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123167: Dec  8 11:05:29.364: //782328//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123168: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x15B32938_2_1942707960
123169: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_alert[16])---[C_Action]------
123170: Dec  8 11:05:29.364: //782328//AFW_:/ContactingDest_AlertProg: the pLegOut is [782329]
123171: Dec  8 11:05:29.364: //782328//AFW_:/ContactingDest_AlertProg: new called number 7425
123172: Dec  8 11:05:29.364: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
123173: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B32938_2_1942707960 ---> NULL
123174: Dec  8 11:05:29.364: //782329/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123175: Dec  8 11:05:29.364: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123176: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123177: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_Process_GetCcqEvent: Received
123178: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECTED(20)] {
123179: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123180: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782328][LEG_INCALERTING(4)][Cause(0)]
123181: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123182: Dec  8 11:05:50.051: //782328/EB05527EA0EA/SSIN:/AFW_SS_MapEvent:
123183: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123184: Dec  8 11:05:50.051: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
123185: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123186: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123187: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17CFA530_2_1942707960]  (
123188: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123189: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782329][LEG_OUTRINGING(9)][Cause(0)]
123190: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123191: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x15B32938_2_1942707960]  (
123192: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123193: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560A230_2_1942707960]  (
123194: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x17CFA530_2_1942707960]  (
123195: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123196: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782329][LEG_OUTRINGING(9)][Cause(0)]
123197: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
123198: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123199: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123200: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x35A2354_2_1942707956]  (
123201: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x15B32938_2_1942707960]  (
123202: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123203: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[CallSetup_0x1560A230_2_1942707960]  (
123204: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:         MOD[Destination_0x17CFA530_2_1942707960]  (
123205: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123206: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782329][LEG_OUTRINGING(9)][Cause(0)]
123207: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:         )
123208: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
123209: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123210: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123211: Dec  8 11:05:50.051: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123212: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123213: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123214: Dec  8 11:05:50.051: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17CFA530_2_1942707960
123215: Dec  8 11:05:50.051: //782328//Dest:/AFW_M_Destination_Action:
123216: Dec  8 11:05:50.051: //782328//Dest:/AFW_Destination_Action:
123217: Dec  8 11:05:50.051: //782328//Dest:/IW_FSM_Drive:
123218: Dec  8 11:05:50.051: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123219: Dec  8 11:05:50.051: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_OOB[2],ev_disconnected[20])---[C_Action]------
123220: Dec  8 11:05:50.051: //782328//Dest:/IW_AlertOut_Disconnect:
123221: Dec  8 11:05:50.051: //-1//AFW_:/AFW_Util_SaveRawMsg:
123222: Dec  8 11:05:50.051: //782328//Dest:/DestTerminate:
123223: Dec  8 11:05:50.051: //782328//Dest:/TermInterworking: current state IW_STATE_ALERT_OOB, Keep IntWrkLeg
123224: Dec  8 11:05:50.051: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GenerateTone:  ccTone 0 cptone -1
123225: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetCodec:
123226: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
123227: Dec  8 11:05:50.055: //782328//Dest:/TermOutboundCall: current state OB_STATE_SETTING
123228: Dec  8 11:05:50.055: //782329/EB05527EA0EA/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_782329
123229: Dec  8 11:05:50.055: //782329/EB05527EA0EA/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_782329, Cause 16
123230: Dec  8 11:05:50.055: //782329/EB05527EA0EA/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E8 type 2
123231: Dec  8 11:05:50.055: //782329/EB05527EA0EA/AFW_:/AFW_Object_RemoveListener:
123232: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 1
123233: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done(239)
123234: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_ReturnArgEv:
123235: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782328 ][LEG_INCALERTING(4)][Cause(16)]}
123236: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Object_RemoveListener:
123237: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 0
123238: Dec  8 11:05:50.055: //782328//Dest:/DestReturn: Destination Returning(ds_008 Status DEST_INTWRKLEG_DISCONNECT)
123239: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_DONE[10])---------------
123240: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123241: Dec  8 11:05:50.055: //782328//Dest:/OB_FSM_Drive:
123242: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123243: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_DONE[8],ev_disconnected[20])---[C_Action]------
123244: Dec  8 11:05:50.055: //782328//Dest:/OB_Ignore: IGNORING EVENT
123245: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
123246: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> Destination_0x17CFA530_2_1942707960
123247: Dec  8 11:05:50.055: //782328//Dest:/DestComplete: peer #:777 IW State IW_STATE_DONE, OB State OB_STATE_DONE
123248: Dec  8 11:05:50.055: //782328//Dest:/DestComplete: Module already completed
123249: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17CFA530_2_1942707960 ---> NULL
123250: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123251: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x15B32938_2_1942707960
123252: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_disconnected[20])---[C_Action]------
123253: Dec  8 11:05:50.055: //782328//AFW_:/AnyState_Disconnected: pLeg callID 782328
123254: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Util_SaveRawMsg:
123255: Dec  8 11:05:50.055: //782328//AFW_:/Session_Close: lastFailureCause 16
123256: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_Terminate:  Terminating Module: Session_0x15B32938_2_1942707960
123257: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Session_Terminate:
123258: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Session_Terminate: lastFailureCause 16
123259: Dec  8 11:05:50.055: //782328//AFW_:/Session_Cleaner:
123260: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_Terminate:  Terminating Module: CallSetup_0x1560A230_2_1942707960
123261: Dec  8 11:05:50.055: //782328//Call:/AFW_M_CallSetup_Terminate:
123262: Dec  8 11:05:50.055: //-1//Call:/CS_Terminate:
123263: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_Terminate:  Terminating Module: Destination_0x17CFA530_2_1942707960
123264: Dec  8 11:05:50.055: //782328//Dest:/AFW_M_Destination_Terminate:
123265: Dec  8 11:05:50.055: //782328//Call:/CS_Complete: Can't complete
123266: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CLOSING[20])---------------
123267: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B32938_2_1942707960 ---> NULL
123268: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
123269: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x35A2354_2_1942707956
123270: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_TclModule_Action:
123271: Dec  8 11:05:50.055: //782328//AFW_:/AFW_TclModule_DefaultEvHandling:
123272: Dec  8 11:05:50.055: //-1//AFW_:/C_ServiceSession_Event_Handler:
123273: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/C_ServiceSession_Event_Handler: Received event CC_EV_CALL_DISCONNECTED[20] in Main Loop
123274: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> NULL
123275: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123276: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123277: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
123278: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Process_GetPriorityQEvent: Received
123279: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(239)] {
123280: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
123281: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_0x17CFA530_2_1942707960]  (
123282: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
123283: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
123284: Dec  8 11:05:50.055: //782328//Dest:/AFW_M_Destination_EventPreProcess:
123285: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_WalkListeners:
123286: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123287: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1560A230_2_1942707960]  (
123288: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17CFA530_2_1942707960]  (
123289: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123290: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123291: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123292: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
123293: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
123294: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_RemoveListener:
123295: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 1
123296: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1560A230_2_1942707960
123297: Dec  8 11:05:50.055: //782328//Call:/AFW_M_CallSetup_Action:
123298: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CLOSING[12],ev_destination_done[239])---[C_Action]------
123299: Dec  8 11:05:50.055: //782328//Call:/CS_Closing_ModuleDone:
123300: Dec  8 11:05:50.055: //782328//Call:/CS_Closing_ModuleDone: All sub-modules completed, move to DONE state
123301: Dec  8 11:05:50.055: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
123302: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done(237)
123303: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_ReturnArgEv:
123304: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782328 ][LEG_INCALERTING(4)][Cause(16)]}
123305: Dec  8 11:05:50.055: //782328/EB05527EA0EA/AFW_:/AFW_Object_RemoveListener:
123306: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 0
123307: Dec  8 11:05:50.055: //782328//Call:/CS_Complete: CallSetup Returning(ls_015 Status CS_TERMINATED_BY_USER)
123308: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1560A230_2_1942707960 ---> NULL
123309: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_WalkListeners:
123310: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123311: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123312: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Event_Free:
123313: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_0x17CFA530_2_1942707960
123314: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_RemoveAllListener:
123315: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 4
123316: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 3
123317: Dec  8 11:05:50.055: //-1//AFW_:HN73CB5EF8:/AFW_M_Event_Free: ExecEnv objCount: 5
123318: Dec  8 11:05:50.055: //-1//Dest:HN73CB5EF8:/AFW_M_Destination_Free:
123319: Dec  8 11:05:50.055: //-1//Dest:HN73CB5EF8:/DestEmptyPreemptHoldQ:
123320: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_FSM_Free:
123321: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_FSM_Free:
123322: Dec  8 11:05:50.055: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
123323: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
123324: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Process_GetPriorityQEvent: Received
123325: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(237)] {
123326: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
123327: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_0x1560A230_2_1942707960]  (
123328: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
123329: Dec  8 11:05:50.055: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
123330: Dec  8 11:05:50.055: //782328//Call:/AFW_M_CallSetup_EventPreProcess:
123331: Dec  8 11:05:50.055: //782328//AFW_:/AFW_Object_WalkListeners:
123332: Dec  8 11:05:50.055: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123333: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x15B32938_2_1942707960]  (
123334: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_INCALERTING(4)][Cause(16)]
123335: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560A230_2_1942707960]  (
123336: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123337: Dec  8 11:05:50.055: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123338: Dec  8 11:05:50.059: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123339: Dec  8 11:05:50.059: //782328//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123340: Dec  8 11:05:50.059: //782328/EB05527EA0EA/AFW_:/AFW_Object_AddListener: adding Module Session as listener
123341: Dec  8 11:05:50.059: //782328//AFW_:/AFW_Object_RemoveListener:
123342: Dec  8 11:05:50.059: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 1
123343: Dec  8 11:05:50.059: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x15B32938_2_1942707960
123344: Dec  8 11:05:50.059: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CLOSING[20],ev_setup_done[237])---[C_Action]------
123345: Dec  8 11:05:50.059: //782328//AFW_:/Closing_AnyEvent:
123346: Dec  8 11:05:50.059: //782328//AFW_:/Session_Cleaner:
123347: Dec  8 11:05:50.059: //782328//AFW_:/Session_Cleaner: lastFailureCause 16
123348: Dec  8 11:05:50.059: //782328/EB05527EA0EA/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_782328
123349: Dec  8 11:05:50.059: //782328/EB05527EA0EA/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_782328, Cause 16
123350: Dec  8 11:05:50.059: //782328/EB05527EA0EA/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123351: Dec  8 11:05:50.059: //782328/EB05527EA0EA/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E8 type 2
123352: Dec  8 11:05:50.059: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CLOSING[20])---------------
123353: Dec  8 11:05:50.059: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B32938_2_1942707960 ---> NULL
123354: Dec  8 11:05:50.059: //782328//AFW_:/AFW_Object_WalkListeners:
123355: Dec  8 11:05:50.059: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123356: Dec  8 11:05:50.059: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123357: Dec  8 11:05:50.059: //782328//AFW_:/AFW_M_Event_Free:
123358: Dec  8 11:05:50.059: //782328//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_0x1560A230_2_1942707960
123359: Dec  8 11:05:50.059: //782328//AFW_:/AFW_Object_RemoveAllListener:
123360: Dec  8 11:05:50.059: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 4, CmdPending 3
123361: Dec  8 11:05:50.059: //782328//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 2
123362: Dec  8 11:05:50.059: //-1//AFW_:HN73CB5EF8:/AFW_M_Event_Free: ExecEnv objCount: 4
123363: Dec  8 11:05:50.059: //-1//Call:HN73CB5EF8:/AFW_M_CallSetup_Free:
123364: Dec  8 11:05:50.059: //-1//AFW_:/AFW_M_FSM_Free:
123365: Dec  8 11:05:50.059: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 2
123366: Dec  8 11:05:50.059: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123367: Dec  8 11:05:50.059: //-1//AFW_:/AFW_M_Event_Free:
123368: Dec  8 11:05:50.059: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
123369: Dec  8 11:05:50.067: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123370: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_Process_GetCcqEvent: Received
123371: Dec  8 11:05:50.067: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECT_DONE(21)] {
123372: Dec  8 11:05:50.067: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123373: Dec  8 11:05:50.067: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782329][LEG_OUTDISCONNECTING(11)][Cause(0)]
123374: Dec  8 11:05:50.067: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123375: Dec  8 11:05:50.067: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
123376: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123377: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123378: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123379: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123380: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Event_Free:  CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_782329
123381: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_Object_RemoveAllListener:
123382: Dec  8 11:05:50.067: //782328//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 1
123383: Dec  8 11:05:50.067: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 3, CmdPending 1
123384: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 3
123385: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Leg_Free:
123386: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/AFW_M_Leg_Free: LEG[782329 ][LEG_DISCONNECTED(12)][Cause(0)]
123387: Dec  8 11:05:50.067: //782329/EB05527EA0EA/AFW_:/decrementDialPeerCallStats: Decrementing call-stat to [1], dial-peer [777]
123388: Dec  8 11:05:50.067: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
123389: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123390: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Process_GetCcqEvent: Received
123391: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECT_DONE(21)] {
123392: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123393: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782328][LEG_INCDISCONNECTING(6)][Cause(16)]
123394: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123395: Dec  8 11:05:50.091: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
123396: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123397: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123398: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x15B32938_2_1942707960]  (
123399: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_DISCONNECTED(12)][Cause(16)]
123400: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123401: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x35A2354_2_1942707956]  (
123402: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x15B32938_2_1942707960]  (
123403: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782328][LEG_DISCONNECTED(12)][Cause(16)]
123404: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123405: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_DISCONNECTED(12)][Cause(16)]
123406: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123407: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123408: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123409: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_RemoveListener:
123410: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 0
123411: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x15B32938_2_1942707960
123412: Dec  8 11:05:50.091: //782328//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CLOSING[20],ev_disconnect_done[21])---[C_Action]------
123413: Dec  8 11:05:50.091: //782328//AFW_:/Closing_AnyEvent:
123414: Dec  8 11:05:50.091: //782328//AFW_:/Session_Cleaner:
123415: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Event_New: Event ID: ev_session_xworkdone(247)
123416: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_ReturnArgEv:
123417: Dec  8 11:05:50.091: //782328//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CLOSING[20])---------------
123418: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x15B32938_2_1942707960 ---> NULL
123419: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123420: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123421: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: -->(**)
123422: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x35A2354_2_1942707956]  (
123423: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x15B32938_2_1942707960]  (
123424: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123425: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782328][LEG_DISCONNECTED(12)][Cause(16)]
123426: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123427: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123428: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
123429: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_RemoveListener:
123430: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 1
123431: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x35A2354_2_1942707956
123432: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_TclModule_Action:
123433: Dec  8 11:05:50.091: //782328//AFW_:/AFW_TclModule_DefaultEvHandling:
123434: Dec  8 11:05:50.091: //-1//AFW_:/C_ServiceSession_Event_Handler:
123435: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/C_ServiceSession_Event_Handler: Received event CC_EV_CALL_DISCONNECT_DONE[21] in Main Loop
123436: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> NULL
123437: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_WalkListeners:
123438: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: START
123439: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Object_ShowListeners: END
123440: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Event_Free:
123441: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Event_Free:  CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_782328
123442: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_Object_RemoveAllListener:
123443: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 0
123444: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 2, CmdPending 0
123445: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 2
123446: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Leg_Free:
123447: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/AFW_M_Leg_Free: LEG[782328 ][LEG_DISCONNECTED(12)][Cause(16)]
123448: Dec  8 11:05:50.091: //782328/EB05527EA0EA/AFW_:/decrementDialPeerCallStats: Decrementing call-stat to [1], dial-peer [100]
123449: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 0
123450: Dec  8 11:05:50.091: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 1
123451: Dec  8 11:05:50.091: //-1//AFW_:/AFW_ExecEnv_CallClose:  Terminating ExecEnv's root module
123452: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_Terminate:  Terminating Module: TclModule_0x35A2354_2_1942707956
123453: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_TclModule_Terminate:  Module is in the state: ACTIVE
123454: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_Terminate:  Terminating Module: Session_0x15B32938_2_1942707960
123455: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Session_Terminate:
123456: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
123457: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Process_GetPriorityQEvent: Received
123458: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_SESSIONXWORK_DONE(247)] {
123459: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
123460: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Session_0x15B32938_2_1942707960]  (
123461: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
123462: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
123463: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Object_WalkListeners:
123464: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123465: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x35A2354_2_1942707956]  (
123466: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x15B32938_2_1942707960]  (
123467: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123468: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123469: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123470: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
123471: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Object_RemoveListener:
123472: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_UnListen:  NumObjects: 0
123473: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x35A2354_2_1942707956
123474: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_TclModule_Action:
123475: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_TclModule_Action: Module is Terminating
123476: Dec  8 11:05:50.091: //-1//AFW_:/AFW_Event_New: Event ID: ev_module_done(257)
123477: Dec  8 11:05:50.091: //782328//AFW_:/AFW_TclModule_ReturnIfDone:  Sending Out APP_EV_TCLMODULE_DONE event
123478: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Module_ReturnArgEv:
123479: Dec  8 11:05:50.091: //782328//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x35A2354_2_1942707956 ---> NULL
123480: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Object_WalkListeners:
123481: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123482: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123483: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Event_Free:
123484: Dec  8 11:05:50.091: //782328//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Session_0x15B32938_2_1942707960
123485: Dec  8 11:05:50.091: //782328//AFW_:/AFW_Object_RemoveAllListener:
123486: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 1, CmdPending 0
123487: Dec  8 11:05:50.091: //-1//AFW_:HN73CB5EF8:/AFW_M_Event_Free: ExecEnv objCount: 1
123488: Dec  8 11:05:50.091: //-1//AFW_:HN73CB5EF8:/AFW_M_Session_Free:  MOD[Session_0x15B32938_2_1942707960]   ( )
123489: Dec  8 11:05:50.091: //-1//AFW_:/AFW_M_FSM_Free:
123490: Dec  8 11:05:50.095: //782328//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 0
123491: Dec  8 11:05:50.095: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 3
123492: Dec  8 11:05:50.095: //782328//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
123493: Dec  8 11:05:50.095: //782328//AFW_:/AFW_Process_GetPriorityQEvent: Received
123494: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_TCLMODULE_DONE(257)] {
123495: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
123496: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[TclModule_0x35A2354_2_1942707956]  (
123497: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
123498: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
123499: Dec  8 11:05:50.095: //782328//AFW_:/AFW_M_TclModule_EventPreProcess:
123500: Dec  8 11:05:50.095: //782328//AFW_:/AFW_Object_WalkListeners:
123501: Dec  8 11:05:50.095: //782328//AFW_:/AFW_M_Object_ShowListeners: START
123502: Dec  8 11:05:50.095: //782328//AFW_:/AFW_M_Object_ShowListeners: END
123503: Dec  8 11:05:50.095: //782328//AFW_:/AFW_M_Event_Free:
123504: Dec  8 11:05:50.095: //782328//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: TclModule_0x35A2354_2_1942707956
123505: Dec  8 11:05:50.095: //782328//AFW_:/AFW_Object_RemoveAllListener:
123506: Dec  8 11:05:50.095: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 0, CmdPending 0
123507: Dec  8 11:05:50.095: //-1//AFW_:HN73CB5EF4:/AFW_M_Event_Free: ExecEnv objCount: 0
123508: Dec  8 11:05:50.095: //-1//SERV:/AFW_Service_ReleaseExecEnv: Script Name = Default cache = true calls = 1
123509: Dec  8 11:05:50.095: //782328//AFW_:/AFW_ExecEnv_UnSetRoot: Execenv = 0x14DD4B5C
123510: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Process_UnLock: pProcess(0xB55424C)=1
123511: Dec  8 11:05:50.095: //-1//SCRI:/cam_sa_stopped: Instance: [] ExecEnv: 0x14DD4B5C
123512: Dec  8 11:05:50.095: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123513: Dec  8 11:05:50.095: //-1//AFW_:/AFW_M_Event_Free:
123514: Dec  8 11:05:50.095: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
123515: Dec  8 11:06:06.515: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service Default modulehandle NULL
123516: Dec  8 11:06:06.515: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = Default
123517: Dec  8 11:06:06.515: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
123518: Dec  8 11:06:06.515: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_SetRoot: Execenv = 0x14DD4B5C
123519: Dec  8 11:06:06.515: //-1//AFW_:/AFW_M_TclModule_NewDup:
123520: Dec  8 11:06:06.515: //-1//AFW_:HN73CBB050:/AFW_M_TclModule_Free:  MOD[TclModule_0x35A2354_2_1942707956]        ( )
123521: Dec  8 11:06:06.515: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB55424C)=2
123522: Dec  8 11:06:06.519: //-1//AFW_:LP:EE14DD4B5C000:HN73CBF074:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
123523: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
123524: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
123525: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_Initiate: Execenv = 0x14DD4B5C
123526: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_SetCallCorID:
123527: Dec  8 11:06:06.519:  CallCorID is ^A8a1<T^Qf k|^NN3)
123528: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Leg_New:
123529: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_Leg_SetExecEnv:
123530: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
123531: Dec  8 11:06:06.519: //-1//AFW_:LP:EE14DD4B5C000:LG782332:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
123532: Dec  8 11:06:06.519: //782332//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
123533: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782332
123534: Dec  8 11:06:06.519: //-1//AFW_:EE14DD4B5C000:/AFW_ExecEnv_AssignCall: Execenv = 0x14DD4B5C, Leg = 782332, Peer_Tag = 100
123535: Dec  8 11:06:06.519: //782332//AFW_:/AFW_ExecEnv_SetCallCorID:
123536: Dec  8 11:06:06.519:  CallCorID is ^A8a1<T^Qf k|^NN3)
123537: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123538: Dec  8 11:06:06.519: //782332//AFW_:/AFW_Process_GetCcqEvent: Received
123539: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
123540: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123541: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782332][LEG_INIT(0)][Cause(0)]
123542: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123543: Dec  8 11:06:06.519: //782332//SSIN:/AFW_SS_MapEvent:
123544: Dec  8 11:06:06.519: //782332//AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123545: Dec  8 11:06:06.519: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
123546: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_SaveRawMsg:
123547: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E9 type 0
123548: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [2] for dial-peer [100]
123549: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners:
123550: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: START
123551: Dec  8 11:06:06.519: //-1//AFW_:/AFW_M_Object_ShowListeners:
123552: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0xBFD5EE8_2_1942745204MOD[TclModule_0xBFD5EE8_2_1942745204]  (
123553: Dec  8 11:06:06.519: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCINIT(1)][Cause(0)]
123554: Dec  8 11:06:06.519: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123555: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: END
123556: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
123557: Dec  8 11:06:06.519: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD5EE8_2_1942745204 ---> TclModule_0xBFD5EE8_2_1942745204
123558: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_TclModule_Action:
123559: Dec  8 11:06:06.519: //782332//AFW_:/AFW_TclModule_DefaultEvHandling:
123560: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_CheckIncomingCallBlock:
123561: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
123562: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_IncomingTranslate:
123563: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(100) calling[05498005405] redirect[] called[400]
123564: Dec  8 11:06:06.519: //-1//AFW_:/C_ServiceSession_Event_Handler:
123565: Dec  8 11:06:06.519: //782332//XCCS:/C_PackageXCCSession_AcceptCallCheck: No AcceptCall; XCC application is unregistered
123566: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Session_New:
123567: Dec  8 11:06:06.519: //-1//AFW_:/AFW_FSM_New:
123568: Dec  8 11:06:06.519: //-1//AFW_:HN73CBF078:/AFW_M_Session_SetExecEnv:
123569: Dec  8 11:06:06.519: //-1//AFW_:LP:EE14DD4B5C000:HN73CBF078:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
123570: Dec  8 11:06:06.519: //782332//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
123571: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_Module_GetHandle: Module handle: Session_0x17AC518C_2_1942745208
123572: Dec  8 11:06:06.519: //782332//AFW_:/C_PackageSession_NewCall: Session module listened by TclModule_0xBFD5EE8_2_1942745204
123573: Dec  8 11:06:06.519: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD5EE8_2_1942745204 ---> Session_0x17AC518C_2_1942745208
123574: Dec  8 11:06:06.519: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_OPEN[1],ev_setup_indication[34])---[C_Action]------
123575: Dec  8 11:06:06.519: //782332//AFW_:/Open_SetupIndication: Calling #(05498005405), Calling Name (), Called #(400), peer_tag(100)
123576: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_GetCalledNumber: calledNumber = 400
123577: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module Session as listener
123578: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_GetUserFromURL:
123579: Dec  8 11:06:06.519:  destination: 400
123580: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_GetUserFromURL:
123581: Dec  8 11:06:06.519:  ret_val : 400
123582: Dec  8 11:06:06.519: //-1//AFW_:/SetupDestination: SetupDestination: afwSSApdu is NULL
123583: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
123584: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
123585: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
123586: Dec  8 11:06:06.519: //782332//AFW_:/SetupDestinationSnrHandler:
123587: Dec  8 11:06:06.519: //782332//AFW_:/ProcessSnrDestination:
123588: Dec  8 11:06:06.519: //782332//AFW_:/ResetSnrParamenter:
123589: Dec  8 11:06:06.519: //782332//AFW_:/SetupDestinationSnrHandler: not snr call
123590: Dec  8 11:06:06.519: //782332//AFW_:/SetupValidateSharedln: calledNum=400, callingNum=05498005405, callID=782332,  callinf.peertag=100, joinXtoID=0
123591: Dec  8 11:06:06.519: //782332//AFW_:/SetupDestination:
123592: Dec  8 11:06:06.519:  destinations[0] = 400
123593: Dec  8 11:06:06.519: //782332//CSPK:/C_CallSetup_Start: ControlInfo = 0x14C58C20, callInfo = 0x14E3886C, destination[0]=400
123594: Dec  8 11:06:06.519: //782332//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
123595: Dec  8 11:06:06.519: //-1//Call:/AFW_CallSetup_New:
123596: Dec  8 11:06:06.519: //-1//AFW_:/AFW_FSM_New:
123597: Dec  8 11:06:06.519: //-1//AFW_:LP:EE14DD4B5C000:HN73CBF078:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
123598: Dec  8 11:06:06.519: //782332//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
123599: Dec  8 11:06:06.519: //782332//AFW_:/AFW_Object_AddListener: adding Module Session as listener
123600: Dec  8 11:06:06.519: //782332//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_0x14D6125C_2_1942745208
123601: Dec  8 11:06:06.519: //782332//Call:/AFW_CallSetup_AddDest:  400 index 0
123602: Dec  8 11:06:06.519: //782332//Call:/AFW_CallSetup_SetIntWrkLeg:
123603: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_SignalPeerGet: Leg [782332]
123604: Dec  8 11:06:06.519: //-1//AFW_:/C_PackageSession_GetSigPeer:
123605: Dec  8 11:06:06.519: //782332//Call:/AFW_M_CallSetup_Initiate:
123606: Dec  8 11:06:06.519: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
123607: Dec  8 11:06:06.519: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
123608: Dec  8 11:06:06.519: //782332//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
123609: Dec  8 11:06:06.519: //782332//Call:/CallSetupInitiate:
123610: Dec  8 11:06:06.523: //782332//Call:/CS_Placecall:
123611: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_GetUserFromURL:
123612: Dec  8 11:06:06.523:  destination: 400
123613: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_GetUserFromURL:
123614: Dec  8 11:06:06.523:  ret_val : 400
123615: Dec  8 11:06:06.523: //782332//Call:/setupHuntGroupInfo: set intWrkLeg id=782332 hgTag=-1 oldhgTag=-1 bacd=0
123616: Dec  8 11:06:06.523: //782332//Call:/CS_Placecall: enable reroute_ind intercept for reroutemode REDIRECT_ROTARY
123617: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
123618: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
123619: Dec  8 11:06:06.523: //782332//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
123620: Dec  8 11:06:06.523: //-1//Dest:/AFW_Destination_New:
123621: Dec  8 11:06:06.523: //-1//AFW_:/AFW_FSM_New:
123622: Dec  8 11:06:06.523: //-1//AFW_:/AFW_FSM_New:
123623: Dec  8 11:06:06.523: //-1//AFW_:LP:EE14DD4B5C000:HN73CBF07C:/AFW_M_Object_SetExecEnv: ObjCount: 5, CmdPending 2
123624: Dec  8 11:06:06.523: //782332//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
123625: Dec  8 11:06:06.523: //782332//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
123626: Dec  8 11:06:06.523: //782332//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_0x3457C1C_2_1942745212
123627: Dec  8 11:06:06.523: //782332//Dest:/AFW_Destination_AddDest:
123628: Dec  8 11:06:06.523: //-1//Dest:/AFW_Destination_AddDest: adding destination "400"
123629: Dec  8 11:06:06.523: //782332//Dest:/AFW_Destination_SetIntWrkLeg: LEG[782332 ][LEG_INCPROCEED(3)][Cause(0)]
123630: Dec  8 11:06:06.523: //782332//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
123631: Dec  8 11:06:06.523: //782332//Dest:/DestSetIntWrkLeg:
123632: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
123633: Dec  8 11:06:06.523: //782332//Dest:/AFW_M_Destination_Initiate:
123634: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_SaveRawMsg:
123635: Dec  8 11:06:06.523: //782332//Dest:/AFW_M_Destination_Initiate: Outgoing guid : 0138E1B1.BC5411E6.A0EB7C0E.CEB32900
123636: Dec  8 11:06:06.523:  Incoming_guid : 00000000.00000000.00000000.00000000
123637: Dec  8 11:06:06.523: //782332//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : 0138E1B1.BC5411E6.A0EB7C0E.CEB32900
123638: Dec  8 11:06:06.523:  Incoming_gcid : 00000000.00000000.00000000.00000000
123639: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
123640: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
123641: Dec  8 11:06:06.523: //782332//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
123642: Dec  8 11:06:06.523: //782332//Dest:/DestSetupInitiate:
123643: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123644: Dec  8 11:06:06.523: //782332//Dest:/DestLocalConsultHandoff: no local handoff, intwrk leg 10E9716C, consult id 14C1DFE0
123645: Dec  8 11:06:06.523: //782332//Dest:/DestAddRerouteSetupInfo:
123646: Dec  8 11:06:06.523: //782332//Dest:/DestAddTransferSetupInfo:
123647: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 400
123648: Dec  8 11:06:06.523: //782332//Dest:/DestMatchDialPeer:
123649: Dec  8 11:06:06.523: //782332//Dest:/DestMatchDialPeer: src carrier id:telekom, tgt carrier id:
123650: Dec  8 11:06:06.523: //782332//Dest:/DestQueuePeers: Matched peers:
123651: Dec  8 11:06:06.523: //782332//Dest:/DestPeerItemUpdatePreemptInfo:
123652: Dec  8 11:06:06.523: //782332//Dest:/DestPeerItemResetLPCORInfo:
123653: Dec  8 11:06:06.523: //-1//Dest:/DestQueuePeers:  777
123654: Dec  8 11:06:06.523: //782332//Dest:/DestPeerItemUpdatePreemptInfo:
123655: Dec  8 11:06:06.523: //782332//Dest:/DestPeerItemResetLPCORInfo:
123656: Dec  8 11:06:06.523: //-1//Dest:/DestQueuePeers:  778
123657: Dec  8 11:06:06.523: //-1//Dest:/DestQueuePeers: , Total(2)
123658: Dec  8 11:06:06.523: //782332//Dest:/DestDialPeerRotary:
123659: Dec  8 11:06:06.523: //782332//Dest:/DestOutboundCallUsingPeer: dest(400), numexpDest(9901), numDestDigits(2)
123660: Dec  8 11:06:06.523: //782332//Dest:/DestOutboundCallUsingPeer:    prefix(1.18), peer tag(777)
123661: Dec  8 11:06:06.523: //782332//Dest:/DestUpdatePreemptSetupInfo:
123662: Dec  8 11:06:06.523: //782332//Dest:/DestDialPeerFilter:
123663: Dec  8 11:06:06.523: //782332//Dest:/DestDialPeerFilter: Checking peer [777]
123664: Dec  8 11:06:06.523: //782332//Dest:/DestPeerFilterRouteCode: Route Code not available in callInfo
123665: Dec  8 11:06:06.523: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(777) calling[05498005405] called[9901]
123666: Dec  8 11:06:06.523: //782332//Dest:/DestCheckTeleUnassBusy:
123667: Dec  8 11:06:06.523: //782332//Dest:/DestHandleLPCOR:
123668: Dec  8 11:06:06.523: //782332//Dest:/DestSetup:
123669: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123670: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Util_SaveRawMsg:
123671: Dec  8 11:06:06.523: //782332//Dest:/DestSetup: snrPeerCallID 0 intWrkLegID 782332
123672: Dec  8 11:06:06.523: //-1//AFW_:/AFW_Leg_New:
123673: Dec  8 11:06:06.523: //782333/0138E1B1A0EB/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
123674: Dec  8 11:06:06.523: //782333/0138E1B1A0EB/AFW_:/AFW_M_Leg_SetExecEnv:
123675: Dec  8 11:06:06.523: //782332//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 4
123676: Dec  8 11:06:06.523: //-1/0138E1B1A0EB/AFW_:LP:EE14DD4B5C000:LG782333:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 4
123677: Dec  8 11:06:06.523: //782333/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
123678: Dec  8 11:06:06.523: //782333/0138E1B1A0EB/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782333
123679: Dec  8 11:06:06.523: //782333/0138E1B1A0EB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E9 type 3
123680: Dec  8 11:06:06.523: //782332//Dest:/DestSetup: Destination setup success
123681: Dec  8 11:06:06.523: //782332//Dest:/AFW_M_Destination_Initiate: attempting call to destination 400
123682: Dec  8 11:06:06.523: //782332//Call:/CS_Placecall: Call placed to 400 index 0
123683: Dec  8 11:06:06.523: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
123684: Dec  8 11:06:06.523: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC518C_2_1942745208 ---> TclModule_0xBFD5EE8_2_1942745204
123685: Dec  8 11:06:06.523: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD5EE8_2_1942745204 ---> TclModule_0xBFD5EE8_2_1942745204
123686: Dec  8 11:06:06.523: //782332/0138E1B1A0EB/AFW_:/AFW_M_Event_Free:
123687: Dec  8 11:06:06.523: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123688: Dec  8 11:06:06.527: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123689: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_Process_GetCcqEvent: Received
123690: Dec  8 11:06:06.527: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
123691: Dec  8 11:06:06.527: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123692: Dec  8 11:06:06.527: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782333][LEG_OUTINIT(7)][Cause(0)]
123693: Dec  8 11:06:06.527: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123694: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/SSIN:/AFW_SS_MapEvent:
123695: Dec  8 11:06:06.527: //-1//SSIN:/AFW_SS_SIP_MapEvent:
123696: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_M_Leg_EventPreProcess: LEG[782333 ][LEG_OUTINIT(7)][Cause(0)]
123697: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners:
123698: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: START
123699: Dec  8 11:06:06.527: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3457C1C_2_1942745212]  (
123700: Dec  8 11:06:06.527: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCPROCEED(3)][Cause(0)]
123701: Dec  8 11:06:06.527: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782333][LEG_OUTINIT(7)][Cause(0)]
123702: Dec  8 11:06:06.527: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123703: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: END
123704: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123705: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3457C1C_2_1942745212
123706: Dec  8 11:06:06.527: //782332//Dest:/AFW_M_Destination_Action:
123707: Dec  8 11:06:06.527: //782332//Dest:/AFW_Destination_Action:
123708: Dec  8 11:06:06.527: //782332//Dest:/OB_FSM_Drive:
123709: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123710: Dec  8 11:06:06.527: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
123711: Dec  8 11:06:06.527: //782332//Dest:/OB_Setting_Proceeding:
123712: Dec  8 11:06:06.527: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
123713: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123714: Dec  8 11:06:06.527: //782332//Dest:/IW_FSM_Drive:
123715: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123716: Dec  8 11:06:06.527: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_proceeding[31])---[C_Action]------
123717: Dec  8 11:06:06.527: //782332//Dest:/IW_InitProc_Proceeding:
123718: Dec  8 11:06:06.527: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_INIT[1])---------------
123719: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123720: Dec  8 11:06:06.527: //782332//Dest:/DestIsEventNotified:
123721: Dec  8 11:06:06.527: //782332//Dest:/DestComplete: peer #:777 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
123722: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> NULL
123723: Dec  8 11:06:06.527: //782333/0138E1B1A0EB/AFW_:/AFW_M_Event_Free:
123724: Dec  8 11:06:06.527: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123725: Dec  8 11:06:06.539: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123726: Dec  8 11:06:06.539: //782333/0138E1B1A0EB/AFW_:/AFW_Process_GetCcqEvent: Received
123727: Dec  8 11:06:06.539: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_ALERT(16)] {
123728: Dec  8 11:06:06.539: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123729: Dec  8 11:06:06.539: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782333][LEG_OUTPROCEED(8)][Cause(0)]
123730: Dec  8 11:06:06.539: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123731: Dec  8 11:06:06.539: //782333/0138E1B1A0EB/SSIN:/AFW_SS_MapEvent:
123732: Dec  8 11:06:06.539: //-1//SSIN:/AFW_SS_SIP_MapEvent:
123733: Dec  8 11:06:06.539: //782333/0138E1B1A0EB/AFW_:/updateInitialDisplayNumber: Final Dial String Unavailable
123734: Dec  8 11:06:06.539: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners:
123735: Dec  8 11:06:06.539: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: START
123736: Dec  8 11:06:06.539: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3457C1C_2_1942745212]  (
123737: Dec  8 11:06:06.539: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCPROCEED(3)][Cause(0)]
123738: Dec  8 11:06:06.539: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782333][LEG_OUTPROCEED(8)][Cause(0)]
123739: Dec  8 11:06:06.539: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123740: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: END
123741: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123742: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3457C1C_2_1942745212
123743: Dec  8 11:06:06.543: //782332//Dest:/AFW_M_Destination_Action:
123744: Dec  8 11:06:06.543: //782332//Dest:/AFW_Destination_Action:
123745: Dec  8 11:06:06.543: //782332//Dest:/OB_FSM_Drive:
123746: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123747: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_alert[16])---[C_Action]------
123748: Dec  8 11:06:06.543: //782332//Dest:/OB_Setting_Alert:
123749: Dec  8 11:06:06.543: //-1//Dest:/OB_Setting_Alert: aData bitmask 0x81000001
123750: Dec  8 11:06:06.543: //-1//Dest:/OB_Setting_Alert: no Called Name info
123751: Dec  8 11:06:06.543: //-1//Dest:/OB_Setting_Alert: aData.display_info=
123752: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =9960,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123753: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123754: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
123755: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123756: Dec  8 11:06:06.543: //782332//Dest:/IW_FSM_Drive:
123757: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123758: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_alert[16])---[C_Action]------
123759: Dec  8 11:06:06.543: //782332//Dest:/IW_AlertRing:
123760: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123761: Dec  8 11:06:06.543: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: empty name, skip preparing content
123762: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123763: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123764: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123765: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/Dest:/DestRingBackFromApp: Leg state [LEG_INCALERTING], alert_sent [1], tone_playing [0]
123766: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123767: Dec  8 11:06:06.543: //782332//Dest:/DestRingBack: Playing Ringback Tone
123768: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GenerateTone:  ccTone 1 cptone 1
123769: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetCodec:
123770: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
123771: Dec  8 11:06:06.543: //782332//Dest:/DestUpdateDisplayInfo:
123772: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123773: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[782332] display using Leg[782333] info
123774: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123775: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123776: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123777: Dec  8 11:06:06.543: //782332/0138E1B1A0EB/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[782332] display not supported
123778: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_OOB[2])---------------
123779: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123780: Dec  8 11:06:06.543: //782332//Dest:/DestIsEventNotified:
123781: Dec  8 11:06:06.543: //782332//Dest:/DestComplete: peer #:777 IW State IW_STATE_ALERT_OOB, OB State OB_STATE_SETTING
123782: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> NULL
123783: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Event Interceptd : Destination
123784: Dec  8 11:06:06.543: //782332//AFW_:/AFW_Object_WalkListeners:
123785: Dec  8 11:06:06.543: //782332//AFW_:/AFW_M_Object_ShowListeners: START
123786: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x14D6125C_2_1942745208]  (
123787: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x3457C1C_2_1942745212]  (
123788: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123789: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782333][LEG_OUTRINGING(9)][Cause(0)]
123790: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123791: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123792: Dec  8 11:06:06.543: //782332//AFW_:/AFW_M_Object_ShowListeners: END
123793: Dec  8 11:06:06.543: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
123794: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x14D6125C_2_1942745208
123795: Dec  8 11:06:06.543: //782332//Call:/AFW_M_CallSetup_Action:
123796: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_alert[16])---[C_Action]------
123797: Dec  8 11:06:06.543: //782332//Call:/CS_Placecall_CallSignal:
123798: Dec  8 11:06:06.543: //782332//Call:/CS_Placecall_CallSignal:  Event notified to parent
123799: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_PLACECALL[2])---------------
123800: Dec  8 11:06:06.543: //782332//Call:/CS_Complete: Can't complete
123801: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x14D6125C_2_1942745208 ---> NULL
123802: Dec  8 11:06:06.543: //782332//AFW_:/AFW_Object_WalkListeners: Event Interceptd : CallSetup
123803: Dec  8 11:06:06.543: //782332//AFW_:/AFW_Object_WalkListeners:
123804: Dec  8 11:06:06.543: //782332//AFW_:/AFW_M_Object_ShowListeners: START
123805: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC518C_2_1942745208]  (
123806: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x14D6125C_2_1942745208]  (
123807: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x3457C1C_2_1942745212]  (
123808: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123809: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782333][LEG_OUTRINGING(9)][Cause(0)]
123810: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
123811: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123812: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123813: Dec  8 11:06:06.543: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123814: Dec  8 11:06:06.543: //782332//AFW_:/AFW_M_Object_ShowListeners: END
123815: Dec  8 11:06:06.543: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123816: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC518C_2_1942745208
123817: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_alert[16])---[C_Action]------
123818: Dec  8 11:06:06.543: //782332//AFW_:/ContactingDest_AlertProg: the pLegOut is [782333]
123819: Dec  8 11:06:06.543: //782332//AFW_:/ContactingDest_AlertProg: new called number 9901
123820: Dec  8 11:06:06.543: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
123821: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC518C_2_1942745208 ---> NULL
123822: Dec  8 11:06:06.543: //782333/0138E1B1A0EB/AFW_:/AFW_M_Event_Free:
123823: Dec  8 11:06:06.543: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
123824: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123825: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Process_GetCcqEvent: Received
123826: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_CONNECTED(17)] {
123827: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123828: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782333][LEG_OUTRINGING(9)][Cause(0)]
123829: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123830: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/SSIN:/AFW_SS_MapEvent:
123831: Dec  8 11:06:06.587: //-1//SSIN:/AFW_SS_SIP_MapEvent:
123832: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E9 type 1
123833: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners:
123834: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: START
123835: Dec  8 11:06:06.587: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3457C1C_2_1942745212]  (
123836: Dec  8 11:06:06.587: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123837: Dec  8 11:06:06.587: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123838: Dec  8 11:06:06.587: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123839: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: END
123840: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123841: Dec  8 11:06:06.587: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3457C1C_2_1942745212
123842: Dec  8 11:06:06.587: //782332//Dest:/AFW_M_Destination_Action:
123843: Dec  8 11:06:06.587: //782332//Dest:/AFW_Destination_Action:
123844: Dec  8 11:06:06.587: //782332//Dest:/OB_FSM_Drive:
123845: Dec  8 11:06:06.587: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123846: Dec  8 11:06:06.587: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_connected[17])---[C_Action]------
123847: Dec  8 11:06:06.587: //782332//Dest:/OB_Setting_Connect:
123848: Dec  8 11:06:06.587: //-1//Dest:/OB_Setting_Connect: cData.display_info=VoiceMail
123849: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =9960,notifyData.display_info = VoiceMail,notifyData.connected_num.oct3a = 0
123850: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = VoiceMail,notifyData.connected_num.oct3a = 0
123851: Dec  8 11:06:06.587: //782332//Dest:/DestNotifySharedLnState: callid: 782333, peer: 777
123852: Dec  8 11:06:06.587: //782332//Dest:/DestNotifySharedLnState: Shared-Line NOT enabled!
123853: Dec  8 11:06:06.587: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
123854: Dec  8 11:06:06.587: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123855: Dec  8 11:06:06.587: //782332//Dest:/IW_FSM_Drive:
123856: Dec  8 11:06:06.587: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123857: Dec  8 11:06:06.587: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_OOB[2],ev_connected[17])---[C_Action]------
123858: Dec  8 11:06:06.587: //782332//Dest:/IW_AlertOut_Connect:
123859: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123860: Dec  8 11:06:06.587: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = VoiceMail,notifyData.connected_num.oct3a = 0
123861: Dec  8 11:06:06.587: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123862: Dec  8 11:06:06.587: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: :opcode=2, Name=VoiceMail
123863: Dec  8 11:06:06.587: //-1//SSIN:/AFW_SS_PrepareNameInfoContent:
123864: Dec  8 11:06:06.587:  AFW_SS_PrepareNameInfoContent: ssInfo=0x190DCA0
123865: Dec  8 11:06:06.587: //-1//AFW_:/AFW_Util_SaveRawMsg:
123866: Dec  8 11:06:06.587: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GenerateTone:  ccTone 0 cptone -1
123867: Dec  8 11:06:06.587: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetCodec:
123868: Dec  8 11:06:06.587: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
123869: Dec  8 11:06:06.591: //782332//Dest:/DestStartMediaNegotiation:
123870: Dec  8 11:06:06.591: //782332//Dest:/DestStartMediaNegotiation: Interworking Leg does not need renegotiation
123871: Dec  8 11:06:06.591: //782332/0138E1B1A0EB/AFW_:/AFW_Connection_NewFromConID:
123872: Dec  8 11:06:06.591: //-1//AFW_:CN410481:/AFW_Connection_New: Conference created
123873: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 5
123874: Dec  8 11:06:06.591: //-1//AFW_:LP:EE14DD4B5C000:CN410481:/AFW_M_Object_SetExecEnv: ObjCount: 7, CmdPending 5
123875: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_AddListener: adding Module Destination as listener
123876: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Connection_GetHandle: Connection handle: CON_410481
123877: Dec  8 11:06:06.591: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_CONNECT_CONFING[5])---------------
123878: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123879: Dec  8 11:06:06.591: //782332//Dest:/DestIsEventNotified:
123880: Dec  8 11:06:06.591: //782332//Dest:/DestComplete: peer #:777 IW State IW_STATE_CONNECT_CONFING, OB State OB_STATE_DONE
123881: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> NULL
123882: Dec  8 11:06:06.591: //782333/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Event Interceptd : Destination
123883: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners:
123884: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Object_ShowListeners: START
123885: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x14D6125C_2_1942745208]  (
123886: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x3457C1C_2_1942745212]  (
123887: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123888: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       CON[410481][CONNECTION_CONFING(1)] {
123889: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782332][LEG_INCALERTING(4)][Cause(0)],
123890: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123891: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       }
123892: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123893: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123894: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123895: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Object_ShowListeners: END
123896: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
123897: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x14D6125C_2_1942745208
123898: Dec  8 11:06:06.591: //782332//Call:/AFW_M_CallSetup_Action:
123899: Dec  8 11:06:06.591: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_connected[17])---[C_Action]------
123900: Dec  8 11:06:06.591: //782332//Call:/CS_Placecall_CallSignal:
123901: Dec  8 11:06:06.591: //782332//Call:/CS_Placecall_CallSignal:  Event notified to parent
123902: Dec  8 11:06:06.591: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_PLACECALL[2])---------------
123903: Dec  8 11:06:06.591: //782332//Call:/CS_Complete: Can't complete
123904: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x14D6125C_2_1942745208 ---> NULL
123905: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners: Event Interceptd : CallSetup
123906: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners:
123907: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Object_ShowListeners: START
123908: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC518C_2_1942745208]  (
123909: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x14D6125C_2_1942745208]  (
123910: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x3457C1C_2_1942745212]  (
123911: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123912: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         CON[410481][CONNECTION_CONFING(1)] {
123913: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782332][LEG_INCALERTING(4)][Cause(0)],
123914: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123915: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         }
123916: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123917: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
123918: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
123919: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123920: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123921: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Object_ShowListeners: END
123922: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
123923: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC518C_2_1942745208
123924: Dec  8 11:06:06.591: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_connected[17])---[C_Action]------
123925: Dec  8 11:06:06.591: //782332//AFW_:/ContactingDest_SignalEvent:
123926: Dec  8 11:06:06.591: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
123927: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC518C_2_1942745208 ---> NULL
123928: Dec  8 11:06:06.591: //782333/0138E1B1A0EB/AFW_:/AFW_M_Event_Free:
123929: Dec  8 11:06:06.591: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
123930: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
123931: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Process_GetCcqEvent: Received
123932: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CONF_CREATE_DONE(39)] {
123933: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
123934: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:     CON[410481][CONNECTION_CONFING(1)] {
123935: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[782332][LEG_INCALERTING(4)][Cause(0)],
123936: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123937: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:     }
123938: Dec  8 11:06:06.591: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
123939: Dec  8 11:06:06.591: //782332//AFW_:/AFW_Object_WalkListeners:
123940: Dec  8 11:06:06.591: //782332//AFW_:/AFW_M_Object_ShowListeners: START
123941: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3457C1C_2_1942745212]  (
123942: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCALERTING(4)][Cause(0)]
123943: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[410481][CONNECTION_CONFED(2)] {
123944: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782332][LEG_INCALERTING(4)][Cause(0)],
123945: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123946: Dec  8 11:06:06.591: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
123947: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
123948: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
123949: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Object_ShowListeners: END
123950: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
123951: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3457C1C_2_1942745212
123952: Dec  8 11:06:06.595: //782332//Dest:/AFW_M_Destination_Action:
123953: Dec  8 11:06:06.595: //782332//Dest:/AFW_Destination_Action:
123954: Dec  8 11:06:06.595: //782332//Dest:/IW_FSM_Drive:
123955: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123956: Dec  8 11:06:06.595: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_CONNECT_CONFING[5],ev_create_done[39])---[C_Action]------
123957: Dec  8 11:06:06.595: //782332//Dest:/IW_ConnectConfing_CreateDone:
123958: Dec  8 11:06:06.595: //782332//Dest:/IW_ConnectConfing_CreateDone: setupLeg.CallID=782333,setupLeg->snrLegType=0
123959: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123960: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = VoiceMail,notifyData.connected_num.oct3a = 0
123961: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_Connect: prog_ind=0, ccRawMsgInfo_t=0x345AB94, cData=3503E10
123962: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123963: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146E9 type 1
123964: Dec  8 11:06:06.595: //782332//Dest:/DestUpdateDisplayInfo:
123965: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123966: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[782332] display using Leg[782333] info
123967: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
123968: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
123969: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =9960,notifyData.display_info = VoiceMail,notifyData.connected_num.oct3a = 0
123970: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[782332] display not supported
123971: Dec  8 11:06:06.595: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_DONE[10])---------------
123972: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> Destination_0x3457C1C_2_1942745212
123973: Dec  8 11:06:06.595: //782332//Dest:/DestComplete: peer #:777 IW State IW_STATE_DONE, OB State OB_STATE_DONE
123974: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done(239)
123975: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv:
123976: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782332 ][LEG_INCCONNECTED(5)][Cause(0)]}
123977: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Object_RemoveListener:
123978: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 2
123979: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[410481 ][CONNECTION_CONFED(2)] {LEG[782332 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[782333 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
123980: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_RemoveListener:
123981: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 1
123982: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782333 ][LEG_OUTCONNECTED(10)][Cause(0)]}
123983: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Object_RemoveListener:
123984: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 0
123985: Dec  8 11:06:06.595: //782332//Dest:/DestReturn: Destination Returning(ds_000 Status DEST_ACTIVE)
123986: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3457C1C_2_1942745212 ---> NULL
123987: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Event_Free:
123988: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
123989: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
123990: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Process_GetPriorityQEvent: Received
123991: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(239)] {
123992: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
123993: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_0x3457C1C_2_1942745212]  (
123994: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
123995: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
123996: Dec  8 11:06:06.595: //782332//Dest:/AFW_M_Destination_EventPreProcess:
123997: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/Dest:/DestUpdateSuccessStats:
123998: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_WalkListeners:
123999: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Object_ShowListeners: START
124000: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x14D6125C_2_1942745208]  (
124001: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x3457C1C_2_1942745212]  (
124002: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124003: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124004: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Object_ShowListeners: END
124005: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
124006: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124007: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124008: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124009: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_RemoveListener:
124010: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 3
124011: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x14D6125C_2_1942745208
124012: Dec  8 11:06:06.595: //782332//Call:/AFW_M_CallSetup_Action:
124013: Dec  8 11:06:06.595: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[239])---[C_Action]------
124014: Dec  8 11:06:06.595: //782332//Call:/CS_Placecall_DestDone:
124015: Dec  8 11:06:06.595: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
124016: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done(237)
124017: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv:
124018: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782332 ][LEG_INCCONNECTED(5)][Cause(0)]}
124019: Dec  8 11:06:06.595: //782332/0138E1B1A0EB/AFW_:/AFW_Object_RemoveListener:
124020: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 2
124021: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782333 ][LEG_OUTCONNECTED(10)][Cause(0)]}
124022: Dec  8 11:06:06.595: //782333/0138E1B1A0EB/AFW_:/AFW_Object_RemoveListener:
124023: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 1
124024: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[410481 ][CONNECTION_CONFED(2)] {LEG[782332 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[782333 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
124025: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_RemoveListener:
124026: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 0
124027: Dec  8 11:06:06.595: //782332//Call:/CS_Complete: CallSetup Returning(ls_000 Status CS_ACTIVE)
124028: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x14D6125C_2_1942745208 ---> NULL
124029: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_WalkListeners:
124030: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Object_ShowListeners: START
124031: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Object_ShowListeners: END
124032: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Event_Free:
124033: Dec  8 11:06:06.595: //782332//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_0x3457C1C_2_1942745212
124034: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Object_RemoveAllListener:
124035: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 6, CmdPending 5
124036: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 4
124037: Dec  8 11:06:06.595: //-1//AFW_:HN73CBF07C:/AFW_M_Event_Free: ExecEnv objCount: 6
124038: Dec  8 11:06:06.595: //-1//Dest:HN73CBF07C:/AFW_M_Destination_Free:
124039: Dec  8 11:06:06.595: //-1//Dest:HN73CBF07C:/DestEmptyPreemptHoldQ:
124040: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_FSM_Free:
124041: Dec  8 11:06:06.595: //-1//AFW_:/AFW_M_FSM_Free:
124042: Dec  8 11:06:06.595: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
124043: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
124044: Dec  8 11:06:06.595: //782332//AFW_:/AFW_Process_GetPriorityQEvent: Received
124045: Dec  8 11:06:06.595: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(237)] {
124046: Dec  8 11:06:06.599: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
124047: Dec  8 11:06:06.599: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_0x14D6125C_2_1942745208]  (
124048: Dec  8 11:06:06.599: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
124049: Dec  8 11:06:06.599: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
124050: Dec  8 11:06:06.599: //782332//Call:/AFW_M_CallSetup_EventPreProcess:
124051: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_WalkListeners:
124052: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Object_ShowListeners: START
124053: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC518C_2_1942745208]  (
124054: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x14D6125C_2_1942745208]  (
124055: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124056: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCCONNECTED(5)][Cause(0)]
124057: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124058: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Object_ShowListeners: END
124059: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124060: Dec  8 11:06:06.599: //782332/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module Session as listener
124061: Dec  8 11:06:06.599: //782333/0138E1B1A0EB/AFW_:/AFW_Object_AddListener: adding Module Session as listener
124062: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_AddListener: adding Module Session as listener
124063: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_RemoveListener:
124064: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Module_UnListen:  NumObjects: 3
124065: Dec  8 11:06:06.599: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC518C_2_1942745208
124066: Dec  8 11:06:06.599: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_setup_done[237])---[C_Action]------
124067: Dec  8 11:06:06.599: //782332//AFW_:/ContactingDest_SetupDone:
124068: Dec  8 11:06:06.599: //782332//AFW_:/Session_Start_CallFeatureM:
124069: Dec  8 11:06:06.599: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
124070: Dec  8 11:06:06.599: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC518C_2_1942745208 ---> NULL
124071: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_WalkListeners:
124072: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Object_ShowListeners: START
124073: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Object_ShowListeners: END
124074: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Event_Free:
124075: Dec  8 11:06:06.599: //782332//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_0x14D6125C_2_1942745208
124076: Dec  8 11:06:06.599: //782332//AFW_:/AFW_Object_RemoveAllListener:
124077: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 4
124078: Dec  8 11:06:06.599: //782332//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 3
124079: Dec  8 11:06:06.599: //-1//AFW_:HN73CBF078:/AFW_M_Event_Free: ExecEnv objCount: 5
124080: Dec  8 11:06:06.599: //-1//Call:HN73CBF078:/AFW_M_CallSetup_Free:
124081: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_FSM_Free:
124082: Dec  8 11:06:06.599: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
124083: Dec  8 11:06:06.599: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124084: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Event_Free:
124085: Dec  8 11:06:06.599: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
124086: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124087: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_Process_GetCcqEvent: Received
124088: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_VOICE_MODE_DONE(66)] {
124089: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
124090: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782332][LEG_INCCONNECTED(5)][Cause(0)]
124091: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124092: Dec  8 11:06:06.603: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
124093: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_M_Leg_EventPreProcess: LEG[782332 ][LEG_INCCONNECTED(5)][Cause(0)]
124094: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners:
124095: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: START
124096: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC518C_2_1942745208]  (
124097: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCCONNECTED(5)][Cause(0)]
124098: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[410481][CONNECTION_CONFED(2)] {
124099: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782332][LEG_INCCONNECTED(5)][Cause(0)],
124100: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
124101: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
124102: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
124103: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124104: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0xBFD5EE8_2_1942745204]  (
124105: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782332][LEG_INCCONNECTED(5)][Cause(0)]
124106: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC518C_2_1942745208]  (
124107: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782332][LEG_INCCONNECTED(5)][Cause(0)]
124108: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       CON[410481][CONNECTION_CONFED(2)] {
124109: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782332][LEG_INCCONNECTED(5)][Cause(0)],
124110: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
124111: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       }
124112: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782333][LEG_OUTCONNECTED(10)][Cause(0)]
124113: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124114: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124115: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_M_Object_ShowListeners: END
124116: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124117: Dec  8 11:06:06.603: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC518C_2_1942745208
124118: Dec  8 11:06:06.603: //782332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],UnknownEvent[66])---[C_Action]------
124119: Dec  8 11:06:06.603: //782332//AFW_:/AnyState_AnyEvent: Wrong Event in Wrong State
124120: Dec  8 11:06:06.603: //782332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
124121: Dec  8 11:06:06.603: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC518C_2_1942745208 ---> NULL
124122: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
124123: Dec  8 11:06:06.603: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0xBFD5EE8_2_1942745204
124124: Dec  8 11:06:06.603: //782332//AFW_:/AFW_M_TclModule_Action:
124125: Dec  8 11:06:06.603: //782332//AFW_:/AFW_TclModule_DefaultEvHandling:
124126: Dec  8 11:06:06.603: //-1//AFW_:/C_ServiceSession_Event_Handler:
124127: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/C_ServiceSession_Event_Handler: Received event CC_EV_VOICE_MODE_DONE[66] in Main Loop
124128: Dec  8 11:06:06.603: //782332//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0xBFD5EE8_2_1942745204 ---> NULL
124129: Dec  8 11:06:06.603: //782332/0138E1B1A0EB/AFW_:/AFW_M_Event_Free:
124130: Dec  8 11:06:06.603: //782332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
124131: Dec  8 11:06:06.603: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124132: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Event_Free:
124133: Dec  8 11:06:06.603: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
124134: Dec  8 11:06:07.895: %SYS-5-CONFIG_I: Configured from console by vty2 (213.143.238.185)
124135: Dec  8 11:06:17.859: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service Default modulehandle NULL
124136: Dec  8 11:06:17.863: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = Default
124137: Dec  8 11:06:17.863: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
124138: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_SetRoot: Execenv = 0x3C24C1C
124139: Dec  8 11:06:17.863: //-1//AFW_:/AFW_M_TclModule_NewDup:
124140: Dec  8 11:06:17.863: //-1//AFW_:HN73C9D7F4:/AFW_M_TclModule_Free:
124141: Dec  8 11:06:17.863: //-1//AFW_:HN73C9D7F4:/AFW_M_Module_GetHandle: Module handle: TclModule_0x34DBC4C_2_1942607860MOD[TclModule_0x34DBC4C_2_1942607860]      ( )
124142: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB55424C)=3
124143: Dec  8 11:06:17.863: //-1//AFW_:LP:EE03C24C1C000:HN73CC1CC8:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
124144: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
124145: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
124146: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_Initiate: Execenv = 0x3C24C1C
124147: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_SetCallCorID:
124148: Dec  8 11:06:17.863:  CallCorID is {S{<T^Qf l|^NN3)
124149: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Leg_New:
124150: Dec  8 11:06:17.863: //782342//AFW_:/AFW_M_Leg_SetExecEnv:
124151: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
124152: Dec  8 11:06:17.863: //-1//AFW_:LP:EE03C24C1C000:LG782342:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
124153: Dec  8 11:06:17.863: //782342//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
124154: Dec  8 11:06:17.863: //782342//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782342
124155: Dec  8 11:06:17.863: //-1//AFW_:EE03C24C1C000:/AFW_ExecEnv_AssignCall: Execenv = 0x3C24C1C, Leg = 782342, Peer_Tag = 100
124156: Dec  8 11:06:17.863: //782342//AFW_:/AFW_ExecEnv_SetCallCorID:
124157: Dec  8 11:06:17.863:  CallCorID is {S{<T^Qf l|^NN3)
124158: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124159: Dec  8 11:06:17.863: //782342//AFW_:/AFW_Process_GetCcqEvent: Received
124160: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
124161: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124162: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782342][LEG_INIT(0)][Cause(0)]
124163: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124164: Dec  8 11:06:17.863: //782342//SSIN:/AFW_SS_MapEvent:
124165: Dec  8 11:06:17.863: //782342//AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124166: Dec  8 11:06:17.863: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
124167: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_SaveRawMsg:
124168: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146EA type 0
124169: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [3] for dial-peer [100]
124170: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners:
124171: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: START
124172: Dec  8 11:06:17.863: //-1//AFW_:/AFW_M_Object_ShowListeners:
124173: Dec  8 11:06:17.863: //782342//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x14E540A8_2_1942756552MOD[TclModule_0x14E540A8_2_1942756552]  (
124174: Dec  8 11:06:17.863: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCINIT(1)][Cause(0)]
124175: Dec  8 11:06:17.863: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124176: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: END
124177: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
124178: Dec  8 11:06:17.863: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1942756552 ---> TclModule_0x14E540A8_2_1942756552
124179: Dec  8 11:06:17.863: //782342//AFW_:/AFW_M_TclModule_Action:
124180: Dec  8 11:06:17.863: //782342//AFW_:/AFW_TclModule_DefaultEvHandling:
124181: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_CheckIncomingCallBlock:
124182: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
124183: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_IncomingTranslate:
124184: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(100) calling[05352865007] redirect[] called[435]
124185: Dec  8 11:06:17.863: //-1//AFW_:/C_ServiceSession_Event_Handler:
124186: Dec  8 11:06:17.863: //782342//XCCS:/C_PackageXCCSession_AcceptCallCheck: No AcceptCall; XCC application is unregistered
124187: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Session_New:
124188: Dec  8 11:06:17.863: //-1//AFW_:/AFW_FSM_New:
124189: Dec  8 11:06:17.863: //-1//AFW_:HN73CC1CC8:/AFW_M_Session_SetExecEnv:
124190: Dec  8 11:06:17.863: //-1//AFW_:LP:EE03C24C1C000:HN73CC1CC8:/AFW_M_Object_SetExecEnv: ObjCount: 3, CmdPending 1
124191: Dec  8 11:06:17.863: //782342//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
124192: Dec  8 11:06:17.863: //782342//AFW_:/AFW_M_Module_GetHandle: Module handle: Session_0x17AC33FC_2_1942756552
124193: Dec  8 11:06:17.863: //782342//AFW_:/C_PackageSession_NewCall: Session module listened by TclModule_0x14E540A8_2_1942756552
124194: Dec  8 11:06:17.863: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1942756552 ---> Session_0x17AC33FC_2_1942756552
124195: Dec  8 11:06:17.863: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_OPEN[1],ev_setup_indication[34])---[C_Action]------
124196: Dec  8 11:06:17.863: //782342//AFW_:/Open_SetupIndication: Calling #(05352865007), Calling Name (), Called #(435), peer_tag(100)
124197: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_GetCalledNumber: calledNumber = 435
124198: Dec  8 11:06:17.863: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module Session as listener
124199: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_GetUserFromURL:
124200: Dec  8 11:06:17.863:  destination: 435
124201: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_GetUserFromURL:
124202: Dec  8 11:06:17.863:  ret_val : 435
124203: Dec  8 11:06:17.863: //-1//AFW_:/SetupDestination: SetupDestination: afwSSApdu is NULL
124204: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
124205: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
124206: Dec  8 11:06:17.863: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
124207: Dec  8 11:06:17.863: //782342//AFW_:/SetupDestinationSnrHandler:
124208: Dec  8 11:06:17.863: //782342//AFW_:/ProcessSnrDestination:
124209: Dec  8 11:06:17.863: //782342//AFW_:/ResetSnrParamenter:
124210: Dec  8 11:06:17.863: //782342//AFW_:/SetupDestinationSnrHandler: not snr call
124211: Dec  8 11:06:17.863: //782342//AFW_:/SetupValidateSharedln: calledNum=435, callingNum=05352865007, callID=782342,  callinf.peertag=100, joinXtoID=0
124212: Dec  8 11:06:17.863: //782342//AFW_:/SetupDestination:
124213: Dec  8 11:06:17.863:  destinations[0] = 435
124214: Dec  8 11:06:17.863: //782342//CSPK:/C_CallSetup_Start: ControlInfo = 0x33C94B8, callInfo = 0x324DF4C, destination[0]=435
124215: Dec  8 11:06:17.863: //782342//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
124216: Dec  8 11:06:17.863: //-1//Call:/AFW_CallSetup_New:
124217: Dec  8 11:06:17.863: //-1//AFW_:/AFW_FSM_New:
124218: Dec  8 11:06:17.863: //-1//AFW_:LP:EE03C24C1C000:HN73CC1CC8:/AFW_M_Object_SetExecEnv: ObjCount: 4, CmdPending 1
124219: Dec  8 11:06:17.863: //782342//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
124220: Dec  8 11:06:17.867: //782342//AFW_:/AFW_Object_AddListener: adding Module Session as listener
124221: Dec  8 11:06:17.867: //782342//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_0x1560ED90_2_1942756552
124222: Dec  8 11:06:17.867: //782342//Call:/AFW_CallSetup_AddDest:  435 index 0
124223: Dec  8 11:06:17.867: //782342//Call:/AFW_CallSetup_SetIntWrkLeg:
124224: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_SignalPeerGet: Leg [782342]
124225: Dec  8 11:06:17.867: //-1//AFW_:/C_PackageSession_GetSigPeer:
124226: Dec  8 11:06:17.867: //782342//Call:/AFW_M_CallSetup_Initiate:
124227: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
124228: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
124229: Dec  8 11:06:17.867: //782342//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
124230: Dec  8 11:06:17.867: //782342//Call:/CallSetupInitiate:
124231: Dec  8 11:06:17.867: //782342//Call:/CS_Placecall:
124232: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_GetUserFromURL:
124233: Dec  8 11:06:17.867:  destination: 435
124234: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_GetUserFromURL:
124235: Dec  8 11:06:17.867:  ret_val : 435
124236: Dec  8 11:06:17.867: //782342//Call:/setupHuntGroupInfo: set intWrkLeg id=782342 hgTag=-1 oldhgTag=-1 bacd=0
124237: Dec  8 11:06:17.867: //782342//Call:/CS_Placecall: enable reroute_ind intercept for reroutemode REDIRECT_ROTARY
124238: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
124239: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
124240: Dec  8 11:06:17.867: //782342//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
124241: Dec  8 11:06:17.867: //-1//Dest:/AFW_Destination_New:
124242: Dec  8 11:06:17.867: //-1//AFW_:/AFW_FSM_New:
124243: Dec  8 11:06:17.867: //-1//AFW_:/AFW_FSM_New:
124244: Dec  8 11:06:17.867: //-1//AFW_:LP:EE03C24C1C000:HN73CC1CCC:/AFW_M_Object_SetExecEnv: ObjCount: 5, CmdPending 2
124245: Dec  8 11:06:17.867: //782342//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
124246: Dec  8 11:06:17.867: //782342//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124247: Dec  8 11:06:17.867: //782342//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_0x17D065B0_2_1942756556
124248: Dec  8 11:06:17.867: //782342//Dest:/AFW_Destination_AddDest:
124249: Dec  8 11:06:17.867: //-1//Dest:/AFW_Destination_AddDest: adding destination "435"
124250: Dec  8 11:06:17.867: //782342//Dest:/AFW_Destination_SetIntWrkLeg: LEG[782342 ][LEG_INCPROCEED(3)][Cause(0)]
124251: Dec  8 11:06:17.867: //782342//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
124252: Dec  8 11:06:17.867: //782342//Dest:/DestSetIntWrkLeg:
124253: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
124254: Dec  8 11:06:17.867: //782342//Dest:/AFW_M_Destination_Initiate:
124255: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_SaveRawMsg:
124256: Dec  8 11:06:17.867: //782342//Dest:/AFW_M_Destination_Initiate: Outgoing guid : 07FBD3FB.BC5411E6.A0EC7C0E.CEB32900
124257: Dec  8 11:06:17.867:  Incoming_guid : 00000000.00000000.00000000.00000000
124258: Dec  8 11:06:17.867: //782342//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : 07FBD3FB.BC5411E6.A0EC7C0E.CEB32900
124259: Dec  8 11:06:17.867:  Incoming_gcid : 00000000.00000000.00000000.00000000
124260: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
124261: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
124262: Dec  8 11:06:17.867: //782342//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
124263: Dec  8 11:06:17.867: //782342//Dest:/DestSetupInitiate:
124264: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124265: Dec  8 11:06:17.867: //782342//Dest:/DestLocalConsultHandoff: no local handoff, intwrk leg 33514B4, consult id 279CE78
124266: Dec  8 11:06:17.867: //782342//Dest:/DestAddRerouteSetupInfo:
124267: Dec  8 11:06:17.867: //782342//Dest:/DestAddTransferSetupInfo:
124268: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 435
124269: Dec  8 11:06:17.867: //782342//Dest:/DestMatchDialPeer:
124270: Dec  8 11:06:17.867: //782342//Dest:/DestMatchDialPeer: src carrier id:telekom, tgt carrier id:
124271: Dec  8 11:06:17.867: //782342//Dest:/DestQueuePeers: Matched peers:
124272: Dec  8 11:06:17.867: //782342//Dest:/DestPeerItemUpdatePreemptInfo:
124273: Dec  8 11:06:17.867: //782342//Dest:/DestPeerItemResetLPCORInfo:
124274: Dec  8 11:06:17.867: //-1//Dest:/DestQueuePeers:  777
124275: Dec  8 11:06:17.867: //782342//Dest:/DestPeerItemUpdatePreemptInfo:
124276: Dec  8 11:06:17.867: //782342//Dest:/DestPeerItemResetLPCORInfo:
124277: Dec  8 11:06:17.867: //-1//Dest:/DestQueuePeers:  778
124278: Dec  8 11:06:17.867: //-1//Dest:/DestQueuePeers: , Total(2)
124279: Dec  8 11:06:17.867: //782342//Dest:/DestDialPeerRotary:
124280: Dec  8 11:06:17.867: //782342//Dest:/DestOutboundCallUsingPeer: dest(435), numexpDest(7435), numDestDigits(2)
124281: Dec  8 11:06:17.867: //782342//Dest:/DestOutboundCallUsingPeer:    prefix(1.18), peer tag(777)
124282: Dec  8 11:06:17.867: //782342//Dest:/DestUpdatePreemptSetupInfo:
124283: Dec  8 11:06:17.867: //782342//Dest:/DestDialPeerFilter:
124284: Dec  8 11:06:17.867: //782342//Dest:/DestDialPeerFilter: Checking peer [777]
124285: Dec  8 11:06:17.867: //782342//Dest:/DestPeerFilterRouteCode: Route Code not available in callInfo
124286: Dec  8 11:06:17.867: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(777) calling[05352865007] called[7435]
124287: Dec  8 11:06:17.867: //782342//Dest:/DestCheckTeleUnassBusy:
124288: Dec  8 11:06:17.867: //782342//Dest:/DestHandleLPCOR:
124289: Dec  8 11:06:17.867: //782342//Dest:/DestSetup:
124290: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124291: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Util_SaveRawMsg:
124292: Dec  8 11:06:17.867: //782342//Dest:/DestSetup: snrPeerCallID 0 intWrkLegID 782342
124293: Dec  8 11:06:17.867: //-1//AFW_:/AFW_Leg_New:
124294: Dec  8 11:06:17.867: //782343/07FBD3FBA0EC/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
124295: Dec  8 11:06:17.867: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Leg_SetExecEnv:
124296: Dec  8 11:06:17.867: //782342//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 4
124297: Dec  8 11:06:17.867: //-1/07FBD3FBA0EC/AFW_:LP:EE03C24C1C000:LG782343:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 4
124298: Dec  8 11:06:17.867: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
124299: Dec  8 11:06:17.867: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_782343
124300: Dec  8 11:06:17.867: //782343/07FBD3FBA0EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146EA type 3
124301: Dec  8 11:06:17.867: //782342//Dest:/DestSetup: Destination setup success
124302: Dec  8 11:06:17.867: //782342//Dest:/AFW_M_Destination_Initiate: attempting call to destination 435
124303: Dec  8 11:06:17.867: //782342//Call:/CS_Placecall: Call placed to 435 index 0
124304: Dec  8 11:06:17.867: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
124305: Dec  8 11:06:17.867: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC33FC_2_1942756552 ---> TclModule_0x14E540A8_2_1942756552
124306: Dec  8 11:06:17.867: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1942756552 ---> TclModule_0x14E540A8_2_1942756552
124307: Dec  8 11:06:17.867: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Event_Free:
124308: Dec  8 11:06:17.867: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
124309: Dec  8 11:06:17.871: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124310: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_Process_GetCcqEvent: Received
124311: Dec  8 11:06:17.871: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
124312: Dec  8 11:06:17.871: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124313: Dec  8 11:06:17.871: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782343][LEG_OUTINIT(7)][Cause(0)]
124314: Dec  8 11:06:17.871: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124315: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/SSIN:/AFW_SS_MapEvent:
124316: Dec  8 11:06:17.871: //-1//SSIN:/AFW_SS_SIP_MapEvent:
124317: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Leg_EventPreProcess: LEG[782343 ][LEG_OUTINIT(7)][Cause(0)]
124318: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners:
124319: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: START
124320: Dec  8 11:06:17.871: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D065B0_2_1942756556]  (
124321: Dec  8 11:06:17.871: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCPROCEED(3)][Cause(0)]
124322: Dec  8 11:06:17.871: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782343][LEG_OUTINIT(7)][Cause(0)]
124323: Dec  8 11:06:17.871: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124324: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: END
124325: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
124326: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D065B0_2_1942756556
124327: Dec  8 11:06:17.871: //782342//Dest:/AFW_M_Destination_Action:
124328: Dec  8 11:06:17.871: //782342//Dest:/AFW_Destination_Action:
124329: Dec  8 11:06:17.871: //782342//Dest:/OB_FSM_Drive:
124330: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124331: Dec  8 11:06:17.871: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
124332: Dec  8 11:06:17.871: //782342//Dest:/OB_Setting_Proceeding:
124333: Dec  8 11:06:17.871: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
124334: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124335: Dec  8 11:06:17.871: //782342//Dest:/IW_FSM_Drive:
124336: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124337: Dec  8 11:06:17.871: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_proceeding[31])---[C_Action]------
124338: Dec  8 11:06:17.871: //782342//Dest:/IW_InitProc_Proceeding:
124339: Dec  8 11:06:17.871: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_INIT[1])---------------
124340: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124341: Dec  8 11:06:17.871: //782342//Dest:/DestIsEventNotified:
124342: Dec  8 11:06:17.871: //782342//Dest:/DestComplete: peer #:777 IW State IW_STATE_INIT, OB State OB_STATE_SETTING
124343: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> NULL
124344: Dec  8 11:06:17.871: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Event_Free:
124345: Dec  8 11:06:17.871: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
124346: Dec  8 11:06:17.943: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124347: Dec  8 11:06:17.943: //782343/07FBD3FBA0EC/AFW_:/AFW_Process_GetCcqEvent: Received
124348: Dec  8 11:06:17.947: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_ALERT(16)] {
124349: Dec  8 11:06:17.947: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124350: Dec  8 11:06:17.947: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782343][LEG_OUTPROCEED(8)][Cause(0)]
124351: Dec  8 11:06:17.947: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124352: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/SSIN:/AFW_SS_MapEvent:
124353: Dec  8 11:06:17.947: //-1//SSIN:/AFW_SS_SIP_MapEvent:
124354: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/updateInitialDisplayNumber: Final Dial String Unavailable
124355: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners:
124356: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: START
124357: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D065B0_2_1942756556]  (
124358: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCPROCEED(3)][Cause(0)]
124359: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782343][LEG_OUTPROCEED(8)][Cause(0)]
124360: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124361: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: END
124362: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
124363: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D065B0_2_1942756556
124364: Dec  8 11:06:17.947: //782342//Dest:/AFW_M_Destination_Action:
124365: Dec  8 11:06:17.947: //782342//Dest:/AFW_Destination_Action:
124366: Dec  8 11:06:17.947: //782342//Dest:/OB_FSM_Drive:
124367: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124368: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_alert[16])---[C_Action]------
124369: Dec  8 11:06:17.947: //782342//Dest:/OB_Setting_Alert:
124370: Dec  8 11:06:17.947: //-1//Dest:/OB_Setting_Alert: aData bitmask 0x81000001
124371: Dec  8 11:06:17.947: //-1//Dest:/OB_Setting_Alert: aData.display_info=NILUFER CAKA
124372: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124373: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124374: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
124375: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124376: Dec  8 11:06:17.947: //782342//Dest:/IW_FSM_Drive:
124377: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124378: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_alert[16])---[C_Action]------
124379: Dec  8 11:06:17.947: //782342//Dest:/IW_AlertRing:
124380: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124381: Dec  8 11:06:17.947: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: :opcode=1, Name=NILUFER CAKA
124382: Dec  8 11:06:17.947: //-1//SSIN:/AFW_SS_PrepareNameInfoContent:
124383: Dec  8 11:06:17.947:  AFW_SS_PrepareNameInfoContent: ssInfo=0x15604F9C
124384: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
124385: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124386: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124387: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/Dest:/DestRingBackFromApp: Leg state [LEG_INCALERTING], alert_sent [1], tone_playing [0]
124388: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124389: Dec  8 11:06:17.947: //782342//Dest:/DestRingBack: Playing Ringback Tone
124390: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GenerateTone:  ccTone 1 cptone 1
124391: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetCodec:
124392: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
124393: Dec  8 11:06:17.947: //782342//Dest:/DestUpdateDisplayInfo:
124394: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124395: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[782342] display using Leg[782343] info
124396: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124397: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
124398: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124399: Dec  8 11:06:17.947: //782342/07FBD3FBA0EC/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[782342] display not supported
124400: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_OOB[2])---------------
124401: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124402: Dec  8 11:06:17.947: //782342//Dest:/DestIsEventNotified:
124403: Dec  8 11:06:17.947: //782342//Dest:/DestComplete: peer #:777 IW State IW_STATE_ALERT_OOB, OB State OB_STATE_SETTING
124404: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> NULL
124405: Dec  8 11:06:17.947: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Event Interceptd : Destination
124406: Dec  8 11:06:17.947: //782342//AFW_:/AFW_Object_WalkListeners:
124407: Dec  8 11:06:17.947: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124408: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1560ED90_2_1942756552]  (
124409: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17D065B0_2_1942756556]  (
124410: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124411: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782343][LEG_OUTRINGING(9)][Cause(0)]
124412: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124413: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124414: Dec  8 11:06:17.947: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124415: Dec  8 11:06:17.947: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
124416: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1560ED90_2_1942756552
124417: Dec  8 11:06:17.947: //782342//Call:/AFW_M_CallSetup_Action:
124418: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_alert[16])---[C_Action]------
124419: Dec  8 11:06:17.947: //782342//Call:/CS_Placecall_CallSignal:
124420: Dec  8 11:06:17.947: //782342//Call:/CS_Placecall_CallSignal:  Event notified to parent
124421: Dec  8 11:06:17.947: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_PLACECALL[2])---------------
124422: Dec  8 11:06:17.947: //782342//Call:/CS_Complete: Can't complete
124423: Dec  8 11:06:17.947: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1560ED90_2_1942756552 ---> NULL
124424: Dec  8 11:06:17.947: //782342//AFW_:/AFW_Object_WalkListeners: Event Interceptd : CallSetup
124425: Dec  8 11:06:17.947: //782342//AFW_:/AFW_Object_WalkListeners:
124426: Dec  8 11:06:17.947: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124427: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC33FC_2_1942756552]  (
124428: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560ED90_2_1942756552]  (
124429: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x17D065B0_2_1942756556]  (
124430: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124431: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782343][LEG_OUTRINGING(9)][Cause(0)]
124432: Dec  8 11:06:17.947: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
124433: Dec  8 11:06:17.951: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124434: Dec  8 11:06:17.951: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124435: Dec  8 11:06:17.951: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124436: Dec  8 11:06:17.951: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124437: Dec  8 11:06:17.951: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124438: Dec  8 11:06:17.951: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC33FC_2_1942756552
124439: Dec  8 11:06:17.951: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_alert[16])---[C_Action]------
124440: Dec  8 11:06:17.951: //782342//AFW_:/ContactingDest_AlertProg: the pLegOut is [782343]
124441: Dec  8 11:06:17.951: //782342//AFW_:/ContactingDest_AlertProg: new called number 7435
124442: Dec  8 11:06:17.951: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
124443: Dec  8 11:06:17.951: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC33FC_2_1942756552 ---> NULL
124444: Dec  8 11:06:17.951: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Event_Free:
124445: Dec  8 11:06:17.951: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
124446: Dec  8 11:06:20.971: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124447: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Process_GetCcqEvent: Received
124448: Dec  8 11:06:20.971: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_CONNECTED(17)] {
124449: Dec  8 11:06:20.971: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124450: Dec  8 11:06:20.971: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782343][LEG_OUTRINGING(9)][Cause(0)]
124451: Dec  8 11:06:20.971: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124452: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/SSIN:/AFW_SS_MapEvent:
124453: Dec  8 11:06:20.971: //-1//SSIN:/AFW_SS_SIP_MapEvent:
124454: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146EA type 1
124455: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners:
124456: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: START
124457: Dec  8 11:06:20.971: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D065B0_2_1942756556]  (
124458: Dec  8 11:06:20.971: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124459: Dec  8 11:06:20.971: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124460: Dec  8 11:06:20.971: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124461: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: END
124462: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
124463: Dec  8 11:06:20.971: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D065B0_2_1942756556
124464: Dec  8 11:06:20.971: //782342//Dest:/AFW_M_Destination_Action:
124465: Dec  8 11:06:20.971: //782342//Dest:/AFW_Destination_Action:
124466: Dec  8 11:06:20.971: //782342//Dest:/OB_FSM_Drive:
124467: Dec  8 11:06:20.971: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124468: Dec  8 11:06:20.971: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_connected[17])---[C_Action]------
124469: Dec  8 11:06:20.971: //782342//Dest:/OB_Setting_Connect:
124470: Dec  8 11:06:20.971: //-1//Dest:/OB_Setting_Connect: cData.display_info=NILUFER CAKA
124471: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124472: Dec  8 11:06:20.971: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124473: Dec  8 11:06:20.971: //782342//Dest:/DestNotifySharedLnState: callid: 782343, peer: 777
124474: Dec  8 11:06:20.975: //782342//Dest:/DestNotifySharedLnState: Shared-Line NOT enabled!
124475: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
124476: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124477: Dec  8 11:06:20.975: //782342//Dest:/IW_FSM_Drive:
124478: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124479: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_OOB[2],ev_connected[17])---[C_Action]------
124480: Dec  8 11:06:20.975: //782342//Dest:/IW_AlertOut_Connect:
124481: Dec  8 11:06:20.975: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
124482: Dec  8 11:06:20.975: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124483: Dec  8 11:06:20.975: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124484: Dec  8 11:06:20.975: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: :opcode=2, Name=NILUFER CAKA
124485: Dec  8 11:06:20.975: //-1//SSIN:/AFW_SS_PrepareNameInfoContent:
124486: Dec  8 11:06:20.975:  AFW_SS_PrepareNameInfoContent: ssInfo=0x13BDED7C
124487: Dec  8 11:06:20.975: //-1//AFW_:/AFW_Util_SaveRawMsg:
124488: Dec  8 11:06:20.975: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GenerateTone:  ccTone 0 cptone -1
124489: Dec  8 11:06:20.975: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetCodec:
124490: Dec  8 11:06:20.975: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
124491: Dec  8 11:06:20.975: //782342//Dest:/DestStartMediaNegotiation:
124492: Dec  8 11:06:20.975: //782342//Dest:/DestStartMediaNegotiation: Interworking Leg does not need renegotiation
124493: Dec  8 11:06:20.975: //782342/07FBD3FBA0EC/AFW_:/AFW_Connection_NewFromConID:
124494: Dec  8 11:06:20.975: //-1//AFW_:CN410488:/AFW_Connection_New: Conference created
124495: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 5
124496: Dec  8 11:06:20.975: //-1//AFW_:LP:EE03C24C1C000:CN410488:/AFW_M_Object_SetExecEnv: ObjCount: 7, CmdPending 5
124497: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_AddListener: adding Module Destination as listener
124498: Dec  8 11:06:20.975: //782342//AFW_:/AFW_M_Connection_GetHandle: Connection handle: CON_410488
124499: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_CONNECT_CONFING[5])---------------
124500: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124501: Dec  8 11:06:20.975: //782342//Dest:/DestIsEventNotified:
124502: Dec  8 11:06:20.975: //782342//Dest:/DestComplete: peer #:777 IW State IW_STATE_CONNECT_CONFING, OB State OB_STATE_DONE
124503: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> NULL
124504: Dec  8 11:06:20.975: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Event Interceptd : Destination
124505: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_WalkListeners:
124506: Dec  8 11:06:20.975: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124507: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1560ED90_2_1942756552]  (
124508: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17D065B0_2_1942756556]  (
124509: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       CON[410488][CONNECTION_CONFING(1)] {
124510: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782342][LEG_INCALERTING(4)][Cause(0)],
124511: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124512: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       }
124513: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124514: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124515: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124516: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124517: Dec  8 11:06:20.975: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124518: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
124519: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1560ED90_2_1942756552
124520: Dec  8 11:06:20.975: //782342//Call:/AFW_M_CallSetup_Action:
124521: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_connected[17])---[C_Action]------
124522: Dec  8 11:06:20.975: //782342//Call:/CS_Placecall_CallSignal:
124523: Dec  8 11:06:20.975: //782342//Call:/CS_Placecall_CallSignal:  Event notified to parent
124524: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_PLACECALL[2])---------------
124525: Dec  8 11:06:20.975: //782342//Call:/CS_Complete: Can't complete
124526: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1560ED90_2_1942756552 ---> NULL
124527: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_WalkListeners: Event Interceptd : CallSetup
124528: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_WalkListeners:
124529: Dec  8 11:06:20.975: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124530: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC33FC_2_1942756552]  (
124531: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560ED90_2_1942756552]  (
124532: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x17D065B0_2_1942756556]  (
124533: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         CON[410488][CONNECTION_CONFING(1)] {
124534: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782342][LEG_INCALERTING(4)][Cause(0)],
124535: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124536: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         }
124537: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124538: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124539: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
124540: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124541: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124542: Dec  8 11:06:20.975: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124543: Dec  8 11:06:20.975: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124544: Dec  8 11:06:20.975: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124545: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC33FC_2_1942756552
124546: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_connected[17])---[C_Action]------
124547: Dec  8 11:06:20.975: //782342//AFW_:/ContactingDest_SignalEvent:
124548: Dec  8 11:06:20.975: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
124549: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC33FC_2_1942756552 ---> NULL
124550: Dec  8 11:06:20.975: //782343/07FBD3FBA0EC/AFW_:/AFW_M_Event_Free:
124551: Dec  8 11:06:20.975: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
124552: Dec  8 11:06:20.975: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124553: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Process_GetCcqEvent: Received
124554: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CONF_CREATE_DONE(39)] {
124555: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124556: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:     CON[410488][CONNECTION_CONFING(1)] {
124557: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[782342][LEG_INCALERTING(4)][Cause(0)],
124558: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124559: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:     }
124560: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124561: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_WalkListeners:
124562: Dec  8 11:06:20.979: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124563: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D065B0_2_1942756556]  (
124564: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[410488][CONNECTION_CONFED(2)] {
124565: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782342][LEG_INCALERTING(4)][Cause(0)],
124566: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124567: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
124568: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCALERTING(4)][Cause(0)]
124569: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124570: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124571: Dec  8 11:06:20.979: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124572: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
124573: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D065B0_2_1942756556
124574: Dec  8 11:06:20.979: //782342//Dest:/AFW_M_Destination_Action:
124575: Dec  8 11:06:20.979: //782342//Dest:/AFW_Destination_Action:
124576: Dec  8 11:06:20.979: //782342//Dest:/IW_FSM_Drive:
124577: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124578: Dec  8 11:06:20.979: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_CONNECT_CONFING[5],ev_create_done[39])---[C_Action]------
124579: Dec  8 11:06:20.979: //782342//Dest:/IW_ConnectConfing_CreateDone:
124580: Dec  8 11:06:20.979: //782342//Dest:/IW_ConnectConfing_CreateDone: setupLeg.CallID=782343,setupLeg->snrLegType=0
124581: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
124582: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124583: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_Connect: prog_ind=0, ccRawMsgInfo_t=0x17D09528, cData=14C7E6D8
124584: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124585: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 146EA type 1
124586: Dec  8 11:06:20.979: //782342//Dest:/DestUpdateDisplayInfo:
124587: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124588: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[782342] display using Leg[782343] info
124589: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
124590: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
124591: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7435,notifyData.display_info = NILUFER CAKA,notifyData.connected_num.oct3a = 0
124592: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[782342] display not supported
124593: Dec  8 11:06:20.979: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_DONE[10])---------------
124594: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> Destination_0x17D065B0_2_1942756556
124595: Dec  8 11:06:20.979: //782342//Dest:/DestComplete: peer #:777 IW State IW_STATE_DONE, OB State OB_STATE_DONE
124596: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done(239)
124597: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv:
124598: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[410488 ][CONNECTION_CONFED(2)] {LEG[782342 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[782343 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
124599: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_RemoveListener:
124600: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 2
124601: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782342 ][LEG_INCCONNECTED(5)][Cause(0)]}
124602: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_RemoveListener:
124603: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 1
124604: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782343 ][LEG_OUTCONNECTED(10)][Cause(0)]}
124605: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_RemoveListener:
124606: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 0
124607: Dec  8 11:06:20.979: //782342//Dest:/DestReturn: Destination Returning(ds_000 Status DEST_ACTIVE)
124608: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D065B0_2_1942756556 ---> NULL
124609: Dec  8 11:06:20.979: //782342//AFW_:/AFW_M_Event_Free:
124610: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
124611: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
124612: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Process_GetPriorityQEvent: Received
124613: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(239)] {
124614: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x3C24C1C][Default]
124615: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_0x17D065B0_2_1942756556]  (
124616: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
124617: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
124618: Dec  8 11:06:20.979: //782342//Dest:/AFW_M_Destination_EventPreProcess:
124619: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/Dest:/DestUpdateSuccessStats:
124620: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_WalkListeners:
124621: Dec  8 11:06:20.979: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124622: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1560ED90_2_1942756552]  (
124623: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17D065B0_2_1942756556]  (
124624: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124625: Dec  8 11:06:20.979: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124626: Dec  8 11:06:20.979: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124627: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
124628: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124629: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124630: Dec  8 11:06:20.979: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
124631: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_RemoveListener:
124632: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 3
124633: Dec  8 11:06:20.979: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1560ED90_2_1942756552
124634: Dec  8 11:06:20.979: //782342//Call:/AFW_M_CallSetup_Action:
124635: Dec  8 11:06:20.979: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[239])---[C_Action]------
124636: Dec  8 11:06:20.979: //782342//Call:/CS_Placecall_DestDone:
124637: Dec  8 11:06:20.979: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
124638: Dec  8 11:06:20.979: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done(237)
124639: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv:
124640: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[410488 ][CONNECTION_CONFED(2)] {LEG[782342 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[782343 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
124641: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Object_RemoveListener:
124642: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 2
124643: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782342 ][LEG_INCCONNECTED(5)][Cause(0)]}
124644: Dec  8 11:06:20.979: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_RemoveListener:
124645: Dec  8 11:06:20.979: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 1
124646: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[782343 ][LEG_OUTCONNECTED(10)][Cause(0)]}
124647: Dec  8 11:06:20.983: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_RemoveListener:
124648: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 0
124649: Dec  8 11:06:20.983: //782342//Call:/CS_Complete: CallSetup Returning(ls_000 Status CS_ACTIVE)
124650: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1560ED90_2_1942756552 ---> NULL
124651: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_WalkListeners:
124652: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124653: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124654: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Event_Free:
124655: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_0x17D065B0_2_1942756556
124656: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_RemoveAllListener:
124657: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 6, CmdPending 5
124658: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 4
124659: Dec  8 11:06:20.983: //-1//AFW_:HN73CC1CCC:/AFW_M_Event_Free: ExecEnv objCount: 6
124660: Dec  8 11:06:20.983: //-1//Dest:HN73CC1CCC:/AFW_M_Destination_Free:
124661: Dec  8 11:06:20.983: //-1//Dest:HN73CC1CCC:/DestEmptyPreemptHoldQ:
124662: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_FSM_Free:
124663: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_FSM_Free:
124664: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
124665: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
124666: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Process_GetPriorityQEvent: Received
124667: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(237)] {
124668: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x3C24C1C][Default]
124669: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_0x1560ED90_2_1942756552]  (
124670: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
124671: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
124672: Dec  8 11:06:20.983: //782342//Call:/AFW_M_CallSetup_EventPreProcess:
124673: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_WalkListeners:
124674: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124675: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC33FC_2_1942756552]  (
124676: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1560ED90_2_1942756552]  (
124677: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124678: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCCONNECTED(5)][Cause(0)]
124679: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124680: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124681: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124682: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_AddListener: adding Module Session as listener
124683: Dec  8 11:06:20.983: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module Session as listener
124684: Dec  8 11:06:20.983: //782343/07FBD3FBA0EC/AFW_:/AFW_Object_AddListener: adding Module Session as listener
124685: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_RemoveListener:
124686: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Module_UnListen:  NumObjects: 3
124687: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC33FC_2_1942756552
124688: Dec  8 11:06:20.983: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_CONTACTINGDEST[5],ev_setup_done[237])---[C_Action]------
124689: Dec  8 11:06:20.983: //782342//AFW_:/ContactingDest_SetupDone:
124690: Dec  8 11:06:20.983: //782342//AFW_:/Session_Start_CallFeatureM:
124691: Dec  8 11:06:20.983: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
124692: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC33FC_2_1942756552 ---> NULL
124693: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_WalkListeners:
124694: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: START
124695: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Object_ShowListeners: END
124696: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Event_Free:
124697: Dec  8 11:06:20.983: //782342//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_0x1560ED90_2_1942756552
124698: Dec  8 11:06:20.983: //782342//AFW_:/AFW_Object_RemoveAllListener:
124699: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 4
124700: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 3
124701: Dec  8 11:06:20.983: //-1//AFW_:HN73CC1CC8:/AFW_M_Event_Free: ExecEnv objCount: 5
124702: Dec  8 11:06:20.983: //-1//Call:HN73CC1CC8:/AFW_M_CallSetup_Free:
124703: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_FSM_Free:
124704: Dec  8 11:06:20.983: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
124705: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124706: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Event_Free:
124707: Dec  8 11:06:20.983: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
124708: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124709: Dec  8 11:06:20.983: //782342/07FBD3FBA0EC/AFW_:/AFW_Process_GetCcqEvent: Received
124710: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_VOICE_MODE_DONE(66)] {
124711: Dec  8 11:06:20.983: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24C1C][Default]
124712: Dec  8 11:06:20.987: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[782342][LEG_INCCONNECTED(5)][Cause(0)]
124713: Dec  8 11:06:20.987: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
124714: Dec  8 11:06:20.987: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
124715: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Leg_EventPreProcess: LEG[782342 ][LEG_INCCONNECTED(5)][Cause(0)]
124716: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners:
124717: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: START
124718: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC33FC_2_1942756552]  (
124719: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[410488][CONNECTION_CONFED(2)] {
124720: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782342][LEG_INCCONNECTED(5)][Cause(0)],
124721: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124722: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
124723: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCCONNECTED(5)][Cause(0)]
124724: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124725: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124726: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E540A8_2_1942756552]  (
124727: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC33FC_2_1942756552]  (
124728: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       CON[410488][CONNECTION_CONFED(2)] {
124729: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782342][LEG_INCCONNECTED(5)][Cause(0)],
124730: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124731: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       }
124732: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782342][LEG_INCCONNECTED(5)][Cause(0)]
124733: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[782343][LEG_OUTCONNECTED(10)][Cause(0)]
124734: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
124735: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[782342][LEG_INCCONNECTED(5)][Cause(0)]
124736: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
124737: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Object_ShowListeners: END
124738: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
124739: Dec  8 11:06:20.987: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC33FC_2_1942756552
124740: Dec  8 11:06:20.987: //782342//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],UnknownEvent[66])---[C_Action]------
124741: Dec  8 11:06:20.987: //782342//AFW_:/AnyState_AnyEvent: Wrong Event in Wrong State
124742: Dec  8 11:06:20.987: //782342//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
124743: Dec  8 11:06:20.987: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC33FC_2_1942756552 ---> NULL
124744: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
124745: Dec  8 11:06:20.987: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x14E540A8_2_1942756552
124746: Dec  8 11:06:20.987: //782342//AFW_:/AFW_M_TclModule_Action:
124747: Dec  8 11:06:20.987: //782342//AFW_:/AFW_TclModule_DefaultEvHandling:
124748: Dec  8 11:06:20.987: //-1//AFW_:/C_ServiceSession_Event_Handler:
124749: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/C_ServiceSession_Event_Handler: Received event CC_EV_VOICE_MODE_DONE[66] in Main Loop
124750: Dec  8 11:06:20.987: //782342//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1942756552 ---> NULL
124751: Dec  8 11:06:20.987: //782342/07FBD3FBA0EC/AFW_:/AFW_M_Event_Free:
124752: Dec  8 11:06:20.987: //782342//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
124753: Dec  8 11:06:20.987: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
124754: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Event_Free:
124755: Dec  8 11:06:20.987: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
debug voice application,
Its matching right now my play2conenct tcl services.  but call is connect and disconnected suddenly announce also not play.
167009: Dec  8 11:46:04.618: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service play2connect modulehandle NULL
167010: Dec  8 11:46:04.618: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = play2connect
167011: Dec  8 11:46:04.618: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
167012: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_SetRoot: Execenv = 0x14E51B7C
167013: Dec  8 11:46:04.618: //-1//AFW_:/AFW_M_TclModule_NewDup:
167014: Dec  8 11:46:04.618: //-1//AFW_:HN73EEF394:/AFW_M_TclModule_Free:  MOD[TclModule_0x13B417C4_2_1945039728]       ( )
167015: Dec  8 11:46:04.618: //-1//AFW_:/AFW_M_FSM_Free:
167016: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB553DCC)=1
167017: Dec  8 11:46:04.618: //-1//AFW_:LP:EE14E51B7C000:HN73F08818:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
167018: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
167019: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
167020: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_Initiate: Execenv = 0x14E51B7C
167021: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_SetCallCorID:
167022: Dec  8 11:46:04.618:  CallCorID is ^V^Y)^V<Y^Qf^ZsB^XYGHL
167023: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Leg_New:
167024: Dec  8 11:46:04.618: //783251//AFW_:/AFW_M_Leg_SetExecEnv:
167025: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
167026: Dec  8 11:46:04.618: //-1//AFW_:LP:EE14E51B7C000:LG783251:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
167027: Dec  8 11:46:04.618: //783251//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
167028: Dec  8 11:46:04.618: //783251//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_783251
167029: Dec  8 11:46:04.618: //-1//AFW_:EE14E51B7C000:/AFW_ExecEnv_AssignCall: Execenv = 0x14E51B7C, Leg = 783251, Peer_Tag = 74001
167030: Dec  8 11:46:04.618: //783251//AFW_:/AFW_ExecEnv_SetCallCorID:
167031: Dec  8 11:46:04.618:  CallCorID is ^V^Y)^V<Y^Qf^ZsB^XYGHL
167032: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
167033: Dec  8 11:46:04.618: //783251//AFW_:/AFW_Process_GetCcqEvent: Received
167034: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
167035: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14E51B7C][play2connect]
167036: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[783251][LEG_INIT(0)][Cause(0)]
167037: Dec  8 11:46:04.618: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
167038: Dec  8 11:46:04.622: //783251//SSIN:/AFW_SS_MapEvent:
167039: Dec  8 11:46:04.622: //-1//SSIN:/AFW_SS_SIP_MapEvent:
167040: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 14735 type 0
167041: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [1] for dial-peer [74001]
167042: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Object_WalkListeners:
167043: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_M_Object_ShowListeners: START
167044: Dec  8 11:46:04.622: //-1//AFW_:/AFW_M_Object_ShowListeners:
167045: Dec  8 11:46:04.622: //783251//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x14E52C18_2_1945143320MOD[TclModule_0x14E52C18_2_1945143320]  (
167046: Dec  8 11:46:04.622: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[783251][LEG_INCINIT(1)][Cause(0)]
167047: Dec  8 11:46:04.622: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
167048: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_M_Object_ShowListeners: END
167049: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
167050: Dec  8 11:46:04.622: //783251//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E52C18_2_1945143320 ---> TclModule_0x14E52C18_2_1945143320
167051: Dec  8 11:46:04.622: //783251//AFW_:/AFW_M_TclModule_Action:
167052: Dec  8 11:46:04.622: //783251//AFW_:/AFW_TclModule_DefaultEvHandling:
167053: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Leg_CheckIncomingCallBlock:
167054: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
167055: Dec  8 11:46:04.622: //783251/9699A9969AF3/AFW_:/AFW_Leg_IncomingTranslate:
167056: Dec  8 11:46:04.622: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(74001) calling[05342992223] redirect[] called[08507227400]
167057: Dec  8 11:46:04.622: //783251//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALL_INIT[1],ev_setup_indication[34])---[act_Media]------
167058: Dec  8 11:46:04.622: //783251//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
167059: Dec  8 11:46:04.622: //783251//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
167060: Dec  8 11:46:04.622: //783251//AFW_:/vtr_lg_dnis: argc 2 argindex 2
167061: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
167062: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
167063: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: argc 2
167064: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: Legs [783251 ]
167065: Dec  8 11:46:04.622: //783251//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
167066: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
167067: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
167068: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: argc 2
167069: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: Legs [783251 ]
167070: Dec  8 11:46:04.622: //783251//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
167071: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
167072: Dec  8 11:46:04.622: //783251//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
167073: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: argc 2
167074: Dec  8 11:46:04.622: //783251//AFW_:/vtd_lg_incoming: Legs [783251 ]
ISLEASING_VROUTER#un all
All possible debugging has been turned off
ISLEASING_VROUTER#
Please attach the full logs as attachment instead of copying here.
Raghavendra
configure "codec g711ulaw" to your dial peer instead of voice-class codec and see.
make sure your audio file codec is same the one your configuring to the dial peer.
Raghavendra
I tested it with codec g711ulaw but same issue.
I posted debug voice application  and debug ccsip messages output.
ISLEASING_VROUTER#deb
ISLEASING_VROUTER#debug  voice ap
ISLEASING_VROUTER#debug  voice application
Default vxml debugging is on
Default application debugging is on
ISLEASING_VROUTER#debug  ccsi
ISLEASING_VROUTER#debug  ccsip   mes
ISLEASING_VROUTER#debug  ccsip   messages
SIP Call messages tracing is enabled
ISLEASING_VROUTER#
ISLEASING_VROUTER#
ISLEASING_VROUTER#sh logg
ISLEASING_VROUTER#term len 0
ISLEASING_VROUTER#sh logging
Syslog logging: enabled (0 messages dropped, 20 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: disabled
    Monitor logging: level debugging, 61 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 242419 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (8192 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 500 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (10000000 bytes):
171899: Dec  8 13:46:22.193: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
171900: Dec  8 13:46:22.193: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
171901: Dec  8 13:46:22.193: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
171902: Dec  8 13:46:22.193: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
171903: Dec  8 13:46:22.193: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171904: Dec  8 13:46:22.193: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
171905: Dec  8 13:46:22.193: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
171906: Dec  8 13:46:22.193: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
171907: Dec  8 13:46:22.193: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
171908: Dec  8 13:46:22.285: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
171909: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
171910: Dec  8 13:46:22.285: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
171911: Dec  8 13:46:22.285: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
171912: Dec  8 13:46:22.285: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171913: Dec  8 13:46:22.285: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
171914: Dec  8 13:46:22.285: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
171915: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
171916: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
171917: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
171918: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171919: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171920: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171921: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
171922: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171923: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171924: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
171925: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
171926: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171927: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:
171928: Dec  8 13:46:22.285: //784347//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x14E53660_2_1952360332MOD[TclModule_0x14E53660_2_1952360332]  (
171929: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171930: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
171931: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
171932: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171933: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
171934: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
171935: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
171936: Dec  8 13:46:22.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171937: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
171938: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
171939: Dec  8 13:46:22.285: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
171940: Dec  8 13:46:22.285: //784347//Digi:/AFW_M_DigitCollect_Action:
171941: Dec  8 13:46:22.285: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 0 Tone Mode 0
171942: Dec  8 13:46:22.285: //784347//Digi:/DigitCollect_TreatDigit:
171943: Dec  8 13:46:22.285: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=0
171944: Dec  8 13:46:22.285: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
171945: Dec  8 13:46:22.285: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
171946: Dec  8 13:46:22.285: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
171947: Dec  8 13:46:22.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
171948: Dec  8 13:46:22.285: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
171949: Dec  8 13:46:22.397: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
171950: Dec  8 13:46:22.397: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
171951: Dec  8 13:46:22.397: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
171952: Dec  8 13:46:22.397: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
171953: Dec  8 13:46:22.397: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171954: Dec  8 13:46:22.397: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
171955: Dec  8 13:46:22.397: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
171956: Dec  8 13:46:22.397: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
171957: Dec  8 13:46:22.397: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
171958: Dec  8 13:46:22.485: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
171959: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
171960: Dec  8 13:46:22.485: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
171961: Dec  8 13:46:22.485: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
171962: Dec  8 13:46:22.485: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171963: Dec  8 13:46:22.485: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
171964: Dec  8 13:46:22.485: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
171965: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
171966: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
171967: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
171968: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171969: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171970: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171971: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
171972: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171973: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171974: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
171975: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
171976: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171977: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
171978: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
171979: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
171980: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
171981: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
171982: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
171983: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
171984: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
171985: Dec  8 13:46:22.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
171986: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
171987: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
171988: Dec  8 13:46:22.485: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
171989: Dec  8 13:46:22.485: //784347//Digi:/AFW_M_DigitCollect_Action:
171990: Dec  8 13:46:22.485: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 2 Tone Mode 0
171991: Dec  8 13:46:22.485: //784347//Digi:/DigitCollect_TreatDigit:
171992: Dec  8 13:46:22.485: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02
171993: Dec  8 13:46:22.485: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
171994: Dec  8 13:46:22.485: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
171995: Dec  8 13:46:22.485: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
171996: Dec  8 13:46:22.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
171997: Dec  8 13:46:22.485: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
171998: Dec  8 13:46:22.597: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
171999: Dec  8 13:46:22.597: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172000: Dec  8 13:46:22.597: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172001: Dec  8 13:46:22.597: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172002: Dec  8 13:46:22.597: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172003: Dec  8 13:46:22.597: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172004: Dec  8 13:46:22.597: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172005: Dec  8 13:46:22.597: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172006: Dec  8 13:46:22.597: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172007: Dec  8 13:46:22.685: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172008: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172009: Dec  8 13:46:22.685: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172010: Dec  8 13:46:22.685: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172011: Dec  8 13:46:22.685: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172012: Dec  8 13:46:22.685: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172013: Dec  8 13:46:22.685: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172014: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172015: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172016: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172017: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172018: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172019: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172020: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172021: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172022: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172023: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172024: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172025: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172026: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172027: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172028: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172029: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172030: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172031: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172032: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172033: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172034: Dec  8 13:46:22.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172035: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172036: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172037: Dec  8 13:46:22.685: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172038: Dec  8 13:46:22.685: //784347//Digi:/AFW_M_DigitCollect_Action:
172039: Dec  8 13:46:22.685: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 2 Tone Mode 0
172040: Dec  8 13:46:22.685: //784347//Digi:/DigitCollect_TreatDigit:
172041: Dec  8 13:46:22.685: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=022
172042: Dec  8 13:46:22.685: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172043: Dec  8 13:46:22.685: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172044: Dec  8 13:46:22.685: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172045: Dec  8 13:46:22.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172046: Dec  8 13:46:22.685: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172047: Dec  8 13:46:22.797: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172048: Dec  8 13:46:22.797: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172049: Dec  8 13:46:22.797: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172050: Dec  8 13:46:22.797: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172051: Dec  8 13:46:22.797: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172052: Dec  8 13:46:22.797: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172053: Dec  8 13:46:22.797: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172054: Dec  8 13:46:22.797: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172055: Dec  8 13:46:22.797: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172056: Dec  8 13:46:22.881: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172057: Dec  8 13:46:22.881: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172058: Dec  8 13:46:22.881: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172059: Dec  8 13:46:22.881: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172060: Dec  8 13:46:22.885: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172061: Dec  8 13:46:22.885: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172062: Dec  8 13:46:22.885: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172063: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172064: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172065: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172066: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172067: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172068: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172069: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172070: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172071: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172072: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172073: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172074: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172075: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172076: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172077: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172078: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172079: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172080: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172081: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172082: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172083: Dec  8 13:46:22.885: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172084: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172085: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172086: Dec  8 13:46:22.885: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172087: Dec  8 13:46:22.885: //784347//Digi:/AFW_M_DigitCollect_Action:
172088: Dec  8 13:46:22.885: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 8 Tone Mode 0
172089: Dec  8 13:46:22.885: //784347//Digi:/DigitCollect_TreatDigit:
172090: Dec  8 13:46:22.885: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=0228
172091: Dec  8 13:46:22.885: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172092: Dec  8 13:46:22.885: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172093: Dec  8 13:46:22.885: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172094: Dec  8 13:46:22.885: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172095: Dec  8 13:46:22.885: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172096: Dec  8 13:46:22.957: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172097: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_Process_GetCcqEvent: Received
172098: Dec  8 13:46:22.957: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_NOTIFY(30)] {
172099: Dec  8 13:46:22.957: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14E516F4][Default]
172100: Dec  8 13:46:22.957: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784333][LEG_OUTCONNECTED(10)][Cause(0)]
172101: Dec  8 13:46:22.957: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172102: Dec  8 13:46:22.957: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172103: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =7339,notifyData.display_info = EMIR ERKIVANC,notifyData.connected_num.oct3a = 129
172104: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7339,notifyData.display_info = EMIR ERKIVANC,notifyData.connected_num.oct3a = 129
172105: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_Object_WalkListeners:
172106: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_M_Object_ShowListeners: START
172107: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x28141A8_2_1952335516]  (
172108: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784332][LEG_INCCONNECTED(5)][Cause(0)]
172109: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411648][CONNECTION_CONFED(2)] {
172110: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784332][LEG_INCCONNECTED(5)][Cause(0)],
172111: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784333][LEG_OUTCONNECTED(10)][Cause(0)]
172112: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172113: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784333][LEG_OUTCONNECTED(10)][Cause(0)]
172114: Dec  8 13:46:22.957: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172115: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_M_Object_ShowListeners: END
172116: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
172117: Dec  8 13:46:22.957: //784332//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x28141A8_2_1952335516
172118: Dec  8 13:46:22.957: //784332//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],UnknownEvent[30])---[C_Action]------
172119: Dec  8 13:46:22.957: //784332//AFW_:/Active_PassThru: Interwork event to signal peer leg
172120: Dec  8 13:46:22.957: //784332/5575786EA172/AFW_:/Active_PassThru: Notify Display Name [EMIR ERKIVANC], Notify Connected Number [7339]
172121: Dec  8 13:46:22.957: //784332//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
172122: Dec  8 13:46:22.957: //784332//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x28141A8_2_1952335516 ---> NULL
172123: Dec  8 13:46:22.957: //784333/5575786EA172/AFW_:/AFW_M_Event_Free:
172124: Dec  8 13:46:22.957: //784332//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172125: Dec  8 13:46:22.993: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172126: Dec  8 13:46:22.993: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172127: Dec  8 13:46:22.993: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172128: Dec  8 13:46:22.997: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172129: Dec  8 13:46:22.997: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172130: Dec  8 13:46:22.997: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172131: Dec  8 13:46:22.997: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172132: Dec  8 13:46:22.997: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172133: Dec  8 13:46:22.997: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172134: Dec  8 13:46:23.085: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172135: Dec  8 13:46:23.085: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172136: Dec  8 13:46:23.085: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172137: Dec  8 13:46:23.085: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172138: Dec  8 13:46:23.085: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172139: Dec  8 13:46:23.085: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172140: Dec  8 13:46:23.085: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172141: Dec  8 13:46:23.085: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172142: Dec  8 13:46:23.085: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172143: Dec  8 13:46:23.085: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172144: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172145: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172146: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172147: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172148: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172149: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172150: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172151: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172152: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172153: Dec  8 13:46:23.085: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172154: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172155: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172156: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172157: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172158: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172159: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172160: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172161: Dec  8 13:46:23.089: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172162: Dec  8 13:46:23.089: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172163: Dec  8 13:46:23.089: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172164: Dec  8 13:46:23.089: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172165: Dec  8 13:46:23.089: //784347//Digi:/AFW_M_DigitCollect_Action:
172166: Dec  8 13:46:23.089: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 3 Tone Mode 0
172167: Dec  8 13:46:23.089: //784347//Digi:/DigitCollect_TreatDigit:
172168: Dec  8 13:46:23.089: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02283
172169: Dec  8 13:46:23.089: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172170: Dec  8 13:46:23.089: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172171: Dec  8 13:46:23.089: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172172: Dec  8 13:46:23.089: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172173: Dec  8 13:46:23.089: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172174: Dec  8 13:46:23.193: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172175: Dec  8 13:46:23.193: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172176: Dec  8 13:46:23.193: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172177: Dec  8 13:46:23.193: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172178: Dec  8 13:46:23.193: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172179: Dec  8 13:46:23.193: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172180: Dec  8 13:46:23.193: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172181: Dec  8 13:46:23.193: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172182: Dec  8 13:46:23.193: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172183: Dec  8 13:46:23.221: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172184: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_Process_GetCcqEvent: Received
172185: Dec  8 13:46:23.221: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_CONNECTED(17)] {
172186: Dec  8 13:46:23.221: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24ED4][seskayit]
172187: Dec  8 13:46:23.221: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784344][LEG_OUTRINGING(9)][Cause(0)]
172188: Dec  8 13:46:23.221: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172189: Dec  8 13:46:23.221: //784344/5DAF2C79A173/SSIN:/AFW_SS_MapEvent:
172190: Dec  8 13:46:23.221: //-1//SSIN:/AFW_SS_SIP_MapEvent:
172191: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 147AD type 1
172192: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners:
172193: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: START
172194: Dec  8 13:46:23.221: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D27710_2_1952358316]  (
172195: Dec  8 13:46:23.221: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172196: Dec  8 13:46:23.221: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172197: Dec  8 13:46:23.221: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172198: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: END
172199: Dec  8 13:46:23.221: //784344/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
172200: Dec  8 13:46:23.221: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D27710_2_1952358316
172201: Dec  8 13:46:23.221: //784337//Dest:/AFW_M_Destination_Action:
172202: Dec  8 13:46:23.221: //784337//Dest:/AFW_Destination_Action:
172203: Dec  8 13:46:23.221: //784337//Dest:/OB_FSM_Drive:
172204: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172205: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_connected[17])---[C_Action]------
172206: Dec  8 13:46:23.225: //784337//Dest:/OB_Setting_Connect:
172207: Dec  8 13:46:23.225: //-1//Dest:/OB_Setting_Connect: cData.display_info=GULEN INCE
172208: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =7451,notifyData.display_info = GULEN INCE,notifyData.connected_num.oct3a = 0
172209: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7451,notifyData.display_info = GULEN INCE,notifyData.connected_num.oct3a = 0
172210: Dec  8 13:46:23.225: //784337//Dest:/DestNotifySharedLnState: callid: 784344, peer: 777
172211: Dec  8 13:46:23.225: //784337//Dest:/DestNotifySharedLnState: Shared-Line NOT enabled!
172212: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_DONE[8])---------------
172213: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172214: Dec  8 13:46:23.225: //784337//Dest:/IW_FSM_Drive:
172215: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172216: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_OOB[2],ev_connected[17])---[C_Action]------
172217: Dec  8 13:46:23.225: //784337//Dest:/IW_AlertOut_Connect:
172218: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
172219: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7451,notifyData.display_info = GULEN INCE,notifyData.connected_num.oct3a = 0
172220: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
172221: Dec  8 13:46:23.225: //-1//SSIN:/AFW_SS_PrepareNameInfoContent: :opcode=2, Name=GULEN INCE
172222: Dec  8 13:46:23.225: //-1//SSIN:/AFW_SS_PrepareNameInfoContent:
172223: Dec  8 13:46:23.225:  AFW_SS_PrepareNameInfoContent: ssInfo=0xB578378
172224: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Util_SaveRawMsg:
172225: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GenerateTone:  ccTone 0 cptone -1
172226: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GetCodec:
172227: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GetCodec: Telephony leg. Default codec is assumed
172228: Dec  8 13:46:23.225: //784337//Dest:/DestStartMediaNegotiation:
172229: Dec  8 13:46:23.225: //784337//Dest:/DestStartMediaNegotiation: MediaNeg not supported for this module
172230: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Connection_NewFromConID:
172231: Dec  8 13:46:23.225: //-1//AFW_:CN411654:/AFW_Connection_New: Conference created
172232: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 5
172233: Dec  8 13:46:23.225: //-1//AFW_:LP:EE03C24ED4000:CN411654:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 5
172234: Dec  8 13:46:23.225: //784337//AFW_:/AFW_Object_AddListener: adding Module Destination as listener
172235: Dec  8 13:46:23.225: //784337//AFW_:/AFW_M_Connection_GetHandle: Connection handle: CON_411654
172236: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_CONNECT_CONFING[5])---------------
172237: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172238: Dec  8 13:46:23.225: //784337//Dest:/DestIsEventNotified:
172239: Dec  8 13:46:23.225: //784337//Dest:/DestComplete: peer #:777 IW State IW_STATE_CONNECT_CONFING, OB State OB_STATE_DONE
172240: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> NULL
172241: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_M_Event_Free:
172242: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
172243: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172244: Dec  8 13:46:23.225: //784337//AFW_:/AFW_Process_GetCcqEvent: Received
172245: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CONF_CREATE_DONE(39)] {
172246: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24ED4][seskayit]
172247: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:     CON[411654][CONNECTION_CONFING(1)] {
172248: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172249: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172250: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:     }
172251: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172252: Dec  8 13:46:23.225: //784337//AFW_:/AFW_Object_WalkListeners:
172253: Dec  8 13:46:23.225: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172254: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x17D27710_2_1952358316]  (
172255: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
172256: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172257: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172258: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172259: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172260: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172261: Dec  8 13:46:23.225: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172262: Dec  8 13:46:23.225: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172263: Dec  8 13:46:23.225: //784337//AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
172264: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x17D27710_2_1952358316
172265: Dec  8 13:46:23.225: //784337//Dest:/AFW_M_Destination_Action:
172266: Dec  8 13:46:23.225: //784337//Dest:/AFW_Destination_Action:
172267: Dec  8 13:46:23.225: //784337//Dest:/IW_FSM_Drive:
172268: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172269: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_CONNECT_CONFING[5],ev_create_done[39])---[C_Action]------
172270: Dec  8 13:46:23.225: //784337//Dest:/IW_ConnectConfing_CreateDone:
172271: Dec  8 13:46:23.225: //784337//Dest:/IW_ConnectConfing_CreateDone: setupLeg.CallID=784344,setupLeg->snrLegType=0
172272: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
172273: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7451,notifyData.display_info = GULEN INCE,notifyData.connected_num.oct3a = 0
172274: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_Connect: prog_ind=0, ccRawMsgInfo_t=0x17D2A688, cData=14C79518
172275: Dec  8 13:46:23.225: //784337//Dest:/DestUpdateDisplayInfo:
172276: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[784337] display using Leg[784344] info
172277: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
172278: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
172279: Dec  8 13:46:23.225: //784344/5DAF2C79A173/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =7451,notifyData.display_info = GULEN INCE,notifyData.connected_num.oct3a = 0
172280: Dec  8 13:46:23.225: //784337/5DAF2C79A173/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[784337] display not supported
172281: Dec  8 13:46:23.225: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_DONE[10])---------------
172282: Dec  8 13:46:23.225: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> Destination_0x17D27710_2_1952358316
172283: Dec  8 13:46:23.225: //784337//Dest:/DestComplete: peer #:777 IW State IW_STATE_DONE, OB State OB_STATE_DONE
172284: Dec  8 13:46:23.225: //-1//AFW_:/AFW_Event_New: Event ID: ev_destination_done(239)
172285: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv:
172286: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[411654 ][CONNECTION_CONFED(2)] {LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[784344 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
172287: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_RemoveListener:
172288: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 2
172289: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784344 ][LEG_OUTCONNECTED(10)][Cause(0)]}
172290: Dec  8 13:46:23.229: //784344/5DAF2C79A173/AFW_:/AFW_Object_RemoveListener:
172291: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 1
172292: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]}
172293: Dec  8 13:46:23.229: //784337/5DAF2C79A173/AFW_:/AFW_Object_RemoveListener:
172294: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 0
172295: Dec  8 13:46:23.229: //784337//Dest:/DestReturn: Destination Returning(ds_000 Status DEST_ACTIVE)
172296: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x17D27710_2_1952358316 ---> NULL
172297: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Event_Free:
172298: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
172299: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
172300: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Process_GetPriorityQEvent: Received
172301: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DESTINATION_DONE(239)] {
172302: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x3C24ED4][seskayit]
172303: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[Destination_0x17D27710_2_1952358316]  (
172304: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
172305: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
172306: Dec  8 13:46:23.229: //784337//Dest:/AFW_M_Destination_EventPreProcess:
172307: Dec  8 13:46:23.229: //784344/5DAF2C79A173/Dest:/DestUpdateSuccessStats:
172308: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_WalkListeners:
172309: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172310: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[CallSetup_0x1561BCD8_2_1952358316]  (
172311: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Destination_0x17D27710_2_1952358316]  (
172312: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172313: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172314: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172315: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_WalkListeners: Entering Module : CallSetup
172316: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
172317: Dec  8 13:46:23.229: //784344/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
172318: Dec  8 13:46:23.229: //784337/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
172319: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_RemoveListener:
172320: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 3
172321: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> CallSetup_0x1561BCD8_2_1952358316
172322: Dec  8 13:46:23.229: //784337//Call:/AFW_M_CallSetup_Action:
172323: Dec  8 13:46:23.229: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_PLACECALL[2],ev_destination_done[239])---[C_Action]------
172324: Dec  8 13:46:23.229: //784337//Call:/CS_Placecall_DestDone:
172325: Dec  8 13:46:23.229: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_DONE[13])---------------
172326: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Event_New: Event ID: ev_setup_done(237)
172327: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv:
172328: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){CON[411654 ][CONNECTION_CONFED(2)] {LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)],LEG[784344 ][LEG_OUTCONNECTED(10)][Cause(0)]}}
172329: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_RemoveListener:
172330: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 2
172331: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784344 ][LEG_OUTCONNECTED(10)][Cause(0)]}
172332: Dec  8 13:46:23.229: //784344/5DAF2C79A173/AFW_:/AFW_Object_RemoveListener:
172333: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 1
172334: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]}
172335: Dec  8 13:46:23.229: //784337/5DAF2C79A173/AFW_:/AFW_Object_RemoveListener:
172336: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 0
172337: Dec  8 13:46:23.229: //784337//Call:/CS_Complete: CallSetup Returning(ls_000 Status CS_ACTIVE)
172338: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: CallSetup_0x1561BCD8_2_1952358316 ---> NULL
172339: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_WalkListeners:
172340: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172341: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172342: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Event_Free:
172343: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: Destination_0x17D27710_2_1952358316
172344: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_RemoveAllListener:
172345: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 5
172346: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 4
172347: Dec  8 13:46:23.229: //-1//AFW_:HN745E9FAC:/AFW_M_Event_Free: ExecEnv objCount: 5
172348: Dec  8 13:46:23.229: //-1//Dest:HN745E9FAC:/AFW_M_Destination_Free:
172349: Dec  8 13:46:23.229: //-1//Dest:HN745E9FAC:/DestEmptyPreemptHoldQ:
172350: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_FSM_Free:
172351: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_FSM_Free:
172352: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
172353: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
172354: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Process_GetPriorityQEvent: Received
172355: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_CALLSETUP_DONE(237)] {
172356: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x3C24ED4][seskayit]
172357: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[CallSetup_0x1561BCD8_2_1952358316]  (
172358: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
172359: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
172360: Dec  8 13:46:23.229: //784337//Call:/AFW_M_CallSetup_EventPreProcess:
172361: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_WalkListeners:
172362: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172363: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:
172364: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x34DAC24_2_1952349312MOD[TclModule_0x34DAC24_2_1952349312]  (
172365: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x1561BCD8_2_1952358316]  (
172366: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172367: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172368: Dec  8 13:46:23.229: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172369: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172370: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
172371: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172372: Dec  8 13:46:23.229: //784344/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172373: Dec  8 13:46:23.229: //784337/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172374: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_RemoveListener:
172375: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 3
172376: Dec  8 13:46:23.229: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x34DAC24_2_1952349312
172377: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_TclModule_Action:
172378: Dec  8 13:46:23.229: //784337//AFW_:/AFW_TclModule_DefaultEvHandling:
172379: Dec  8 13:46:23.229: //784344/5DAF2C79A173/AFW_:/AFW_Leg_SignalPeerSet: Legs [784344]<->[784337]
172380: Dec  8 13:46:23.229: //-1//AFW_:/C_PackageSession_SetSigPeer:
172381: Dec  8 13:46:23.229: //-1//AFW_:/AFW_Session_New:
172382: Dec  8 13:46:23.229: //-1//AFW_:/AFW_FSM_New:
172383: Dec  8 13:46:23.229: //-1//AFW_:HN745EADF4:/AFW_M_Session_SetExecEnv:
172384: Dec  8 13:46:23.229: //-1//AFW_:LP:EE03C24ED4000:HN745EADF4:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 4
172385: Dec  8 13:46:23.229: //784337//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172386: Dec  8 13:46:23.229: //784337//AFW_:/AFW_M_Module_GetHandle: Module handle: Session_0x28149B8_2_1952361972
172387: Dec  8 13:46:23.233: //784337//AFW_:/C_PackageSession_SetSigPeer: Session module listened by TclModule_0x34DAC24_2_1952349312
172388: Dec  8 13:46:23.233: //784344/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module Session as listener
172389: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module Session as listener
172390: Dec  8 13:46:23.233: //784337//AFW_:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [784344]'s session
172391: Dec  8 13:46:23.233: //784337//AFW_:/AFW_TclModule_UpdateSessionMask: Update intwrk-mask for leg [784337]'s session
172392: Dec  8 13:46:23.233: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(SETTING_UP_VOICE_MODE[13],ev_setup_done[237])---[act_voice]------
172393: Dec  8 13:46:23.233: //784337//TCL :/tcl_InfotagObjCmd:  infotag get evt_status
172394: Dec  8 13:46:23.233: //784337//TCL :/tcl_InfotagGetObjCmd: infotag get evt_status
172395: Dec  8 13:46:23.233: //784337//AFW_:/vtr_ev_status: argc 2 argindex 2
172396: Dec  8 13:46:23.233: //784337//TCL :/tcl_PutsObjCmd: [Call 784337] The VOICE Call has been established
172397: Dec  8 13:46:23.233:
172398: Dec  8 13:46:23.233: //784337//TCL :/tcl_InfotagObjCmd:  infotag get evt_connections
172399: Dec  8 13:46:23.233: //784337//TCL :/tcl_InfotagGetObjCmd: infotag get evt_connections
172400: Dec  8 13:46:23.233: //784337//AFW_:/vtr_ev_connections: argc 2
172401: Dec  8 13:46:23.233: //784337//AFW_:/vtr_ev_connections: EVCONFID [411654]
172402: Dec  8 13:46:23.233: //784337//TCL :/tcl_PutsObjCmd: [Call 784337] Start DTMF-DETECTION
172403: Dec  8 13:46:23.233:
172404: Dec  8 13:46:23.233: //784337//TCL :/tcl_LegObjCmd:  leg collectdigits leg_incoming params
172405: Dec  8 13:46:23.233: //784337//Digi:/tcl_LegDigitCollectObjCmd: collectdigits leg_incoming params
172406: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: argc 3
172407: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: Legs [784337 ]
172408: Dec  8 13:46:23.233: //784337//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
172409: Dec  8 13:46:23.233: //784337//Digi:/C_DigitCollect_Start: Leg=784337, Dialplan=False, Diaplanterm=False, DigitReport=True, DigitConsume=False IgnoreInitialKey=False, IgnoreDTMFacceptINFO=False, Abortkey=^@, Terminationkey=^@, Numpatterns=0, Maxdigits=0, Mindigits=0, Interruptprompt=False, InterTimeout=-1000, Initialtimeout=0, Mask=0 Hotword=0
172410: Dec  8 13:46:23.233: //-1//Digi:/AFW_DigitCollect_New:
172411: Dec  8 13:46:23.233: //-1//Digi:HN745EADF8:/AFW_DigitCollect_New: DialPlan=FALSE AbortKey=^@ TermKey=^@ NumPatts=0
              Enable=TRUE Consume=FALSE InterruptPrompt=FALSE minDigits=0 maxDigits=0 DialPlanTerm=FALSE hotword=0
172412: Dec  8 13:46:23.233: //-1//AFW_:LP:EE03C24ED4000:HN745EADF8:/AFW_M_Object_SetExecEnv: ObjCount: 7, CmdPending 4
172413: Dec  8 13:46:23.233: //784337//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172414: Dec  8 13:46:23.233: //784337//AFW_:/AFW_M_Module_GetHandle: Module handle: DigitCollect_0x14B6B678_2_1952361976
172415: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module DigitCollect as listener
172416: Dec  8 13:46:23.233: //784337/5DAF2C79A173/Digi:/DigitCollectStart_UpdateStats:
172417: Dec  8 13:46:23.233: //784337//Digi:/DigitCollect_MLPPTuning:
172418: Dec  8 13:46:23.233: //784337//Digi:/DigitCollect_MLPPTuning: Precednece Digit Collect not enabled
172419: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Leg_TypeAheadGet: no chars in buffer.
172420: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
172421: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Leg_DigitReportEnable: Current: 0x2 Input: 0x2
172422: Dec  8 13:46:23.233: //784337//TCL :/tcl_LegObjCmd:  leg tonedetect leg_incoming enable cng
172423: Dec  8 13:46:23.233: //784337//TCL :/tcl_LegToneDetectObjCmd: tonedetect leg_incoming enable cng
172424: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: argc 4
172425: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: Legs [784337 ]
172426: Dec  8 13:46:23.233: //784337//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
172427: Dec  8 13:46:23.233: //784337//TCL :/tcl_PutsObjCmd: [Call 784337] Start CNG detection
172428: Dec  8 13:46:23.233:
172429: Dec  8 13:46:23.233: //784337//TCL :/tcl_PutsObjCmd: [Call 784337] Start TIMER for 9 seconds
172430: Dec  8 13:46:23.233:
172431: Dec  8 13:46:23.233: //784337//TCL :/tcl_TimerObjCmd:  timer start leg_timer 9 leg_incoming
172432: Dec  8 13:46:23.233: //784337//TCL :/tcl_TimerStartObjCmd: timer start leg_timer 9 leg_incoming
172433: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: argc 4
172434: Dec  8 13:46:23.233: //784337//AFW_:/vtd_lg_incoming: Legs [784337 ]
172435: Dec  8 13:46:23.233: //784337//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
172436: Dec  8 13:46:23.233: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(VOICE_MODE[5])---------------
172437: Dec  8 13:46:23.233: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x34DAC24_2_1952349312 ---> NULL
172438: Dec  8 13:46:23.233: //784337//AFW_:/AFW_Object_WalkListeners:
172439: Dec  8 13:46:23.233: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172440: Dec  8 13:46:23.233: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172441: Dec  8 13:46:23.233: //784337//AFW_:/AFW_M_Event_Free:
172442: Dec  8 13:46:23.233: //784337//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: CallSetup_0x1561BCD8_2_1952358316
172443: Dec  8 13:46:23.233: //784337//AFW_:/AFW_Object_RemoveAllListener:
172444: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 6, CmdPending 4
172445: Dec  8 13:46:23.233: //784337//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 3
172446: Dec  8 13:46:23.233: //-1//AFW_:HN745E9FAC:/AFW_M_Event_Free: ExecEnv objCount: 6
172447: Dec  8 13:46:23.233: //-1//Call:HN745E9FAC:/AFW_M_CallSetup_Free:
172448: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_FSM_Free:
172449: Dec  8 13:46:23.233: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172450: Dec  8 13:46:23.233: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172451: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Process_GetCcqEvent: Received
172452: Dec  8 13:46:23.233: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
172453: Dec  8 13:46:23.233: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24ED4][seskayit]
172454: Dec  8 13:46:23.233: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172455: Dec  8 13:46:23.233: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172456: Dec  8 13:46:23.233: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172457: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners:
172458: Dec  8 13:46:23.233: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: START
172459: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6B678_2_1952361976]  (
172460: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172461: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172462: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x28149B8_2_1952361972]  (
172463: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172464: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172465: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172466: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x34DAC24_2_1952349312]  (
172467: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
172468: Dec  8 13:46:23.233: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172469: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172470: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172471: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172472: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x28149B8_2_1952361972]  (
172473: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172474: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172475: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172476: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6B678_2_1952361976]  (
172477: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172478: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172479: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172480: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172481: Dec  8 13:46:23.237: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: END
172482: Dec  8 13:46:23.237: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172483: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6B678_2_1952361976
172484: Dec  8 13:46:23.237: //784337//Digi:/AFW_M_DigitCollect_Action:
172485: Dec  8 13:46:23.237: //784337//Digi:/act_DCRunning_RDone: id=784337 Enable succeeded.enable=1 matchDialplan=0 numPatterns=0matchDialplanTerm=0
172486: Dec  8 13:46:23.237: //-1//Digi:/DigitCollect_Complete: DC_ENABLED. Digits=
172487: Dec  8 13:46:23.237: //784337//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
172488: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done(246)
172489: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Module_ReturnArgEv:
172490: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]}
172491: Dec  8 13:46:23.237: //784337/5DAF2C79A173/AFW_:/AFW_Object_RemoveListener:
172492: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 0
172493: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6B678_2_1952361976 ---> NULL
172494: Dec  8 13:46:23.237: //784337/5DAF2C79A173/AFW_:/AFW_M_Event_Free:
172495: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172496: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
172497: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Process_GetPriorityQEvent: Received
172498: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DIGITCOLLECT_DONE(246)] {
172499: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x3C24ED4][seskayit]
172500: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[DigitCollect_0x14B6B678_2_1952361976]  (
172501: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
172502: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
172503: Dec  8 13:46:23.237: //784337//Digi:/AFW_M_DigitCollect_EventPreProcess:
172504: Dec  8 13:46:23.237: //784337//Digi:/DigitCollectEnd_UpdateStats:
172505: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Object_WalkListeners:
172506: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172507: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x34DAC24_2_1952349312]  (
172508: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
172509: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172510: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172511: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172512: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172513: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x28149B8_2_1952361972]  (
172514: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172515: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172516: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172517: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6B678_2_1952361976]  (
172518: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172519: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172520: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172521: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172522: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
172523: Dec  8 13:46:23.237: //784337/5DAF2C79A173/AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
172524: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Object_RemoveListener:
172525: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Module_UnListen:  NumObjects: 4
172526: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x34DAC24_2_1952349312
172527: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_TclModule_Action:
172528: Dec  8 13:46:23.237: //784337//AFW_:/AFW_TclModule_DefaultEvHandling:
172529: Dec  8 13:46:23.237: //784337//AFW_:/AFW_FSM_Drive: FSM no match for (VOICE_MODE[5],ev_collectdigits_done[246])
172530: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x34DAC24_2_1952349312 ---> NULL
172531: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Object_WalkListeners:
172532: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Object_ShowListeners: START
172533: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Object_ShowListeners: END
172534: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Event_Free:
172535: Dec  8 13:46:23.237: //784337//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: DigitCollect_0x14B6B678_2_1952361976
172536: Dec  8 13:46:23.237: //784337//AFW_:/AFW_Object_RemoveAllListener:
172537: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 5, CmdPending 3
172538: Dec  8 13:46:23.237: //-1//AFW_:HN745EADF8:/AFW_M_Event_Free: ExecEnv objCount: 5
172539: Dec  8 13:46:23.237: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172540: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172541: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Event_Free:
172542: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
172543: Dec  8 13:46:23.237: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172544: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Event_Free:
172545: Dec  8 13:46:23.237: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
172546: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172547: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Process_GetCcqEvent: Received
172548: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_VOICE_MODE_DONE(66)] {
172549: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24ED4][seskayit]
172550: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172551: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172552: Dec  8 13:46:23.241: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172553: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]
172554: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners:
172555: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: START
172556: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x28149B8_2_1952361972]  (
172557: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172558: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172559: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172560: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x34DAC24_2_1952349312]  (
172561: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
172562: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172563: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172564: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172565: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172566: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x28149B8_2_1952361972]  (
172567: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172568: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172569: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172570: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172571: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172572: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: END
172573: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
172574: Dec  8 13:46:23.241: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x28149B8_2_1952361972
172575: Dec  8 13:46:23.241: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],UnknownEvent[66])---[C_Action]------
172576: Dec  8 13:46:23.241: //784337//AFW_:/AnyState_AnyEvent: Wrong Event in Wrong State
172577: Dec  8 13:46:23.241: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
172578: Dec  8 13:46:23.241: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x28149B8_2_1952361972 ---> NULL
172579: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
172580: Dec  8 13:46:23.241: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x34DAC24_2_1952349312
172581: Dec  8 13:46:23.241: //784337//AFW_:/AFW_M_TclModule_Action:
172582: Dec  8 13:46:23.241: //784337//AFW_:/AFW_TclModule_DefaultEvHandling:
172583: Dec  8 13:46:23.241: //784337//AFW_:/AFW_FSM_Drive: FSM no match for (VOICE_MODE[5],UnknownEvent[66])
172584: Dec  8 13:46:23.241: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x34DAC24_2_1952349312 ---> NULL
172585: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Event_Free:
172586: Dec  8 13:46:23.241: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172587: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172588: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Process_GetCcqEvent: Received
172589: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_MODIFY_DONE(42)] {
172590: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x3C24ED4][seskayit]
172591: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172592: Dec  8 13:46:23.241: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172593: Dec  8 13:46:23.241: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172594: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]
172595: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners:
172596: Dec  8 13:46:23.241: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: START
172597: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x28149B8_2_1952361972]  (
172598: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172599: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172600: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172601: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x34DAC24_2_1952349312]  (
172602: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
172603: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
172604: Dec  8 13:46:23.241: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172605: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
172606: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172607: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x28149B8_2_1952361972]  (
172608: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
172609: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172610: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172611: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
172612: Dec  8 13:46:23.245: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172613: Dec  8 13:46:23.245: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: END
172614: Dec  8 13:46:23.245: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
172615: Dec  8 13:46:23.245: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x28149B8_2_1952361972
172616: Dec  8 13:46:23.245: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],UnknownEvent[42])---[C_Action]------
172617: Dec  8 13:46:23.245: //784337//AFW_:/AnyState_AnyEvent: Wrong Event in Wrong State
172618: Dec  8 13:46:23.245: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
172619: Dec  8 13:46:23.245: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x28149B8_2_1952361972 ---> NULL
172620: Dec  8 13:46:23.245: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
172621: Dec  8 13:46:23.245: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x34DAC24_2_1952349312
172622: Dec  8 13:46:23.245: //784337//AFW_:/AFW_M_TclModule_Action:
172623: Dec  8 13:46:23.245: //784337//AFW_:/AFW_TclModule_DefaultEvHandling:
172624: Dec  8 13:46:23.245: //784337//AFW_:/AFW_FSM_Drive: FSM no match for (VOICE_MODE[5],UnknownEvent[42])
172625: Dec  8 13:46:23.245: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x34DAC24_2_1952349312 ---> NULL
172626: Dec  8 13:46:23.245: //784337/5DAF2C79A173/AFW_:/AFW_M_Event_Free:
172627: Dec  8 13:46:23.245: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
172628: Dec  8 13:46:23.285: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172629: Dec  8 13:46:23.285: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172630: Dec  8 13:46:23.285: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172631: Dec  8 13:46:23.285: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172632: Dec  8 13:46:23.285: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172633: Dec  8 13:46:23.285: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172634: Dec  8 13:46:23.285: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172635: Dec  8 13:46:23.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172636: Dec  8 13:46:23.285: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172637: Dec  8 13:46:23.285: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172638: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172639: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172640: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172641: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172642: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172643: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172644: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172645: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172646: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172647: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172648: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172649: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172650: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172651: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172652: Dec  8 13:46:23.285: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172653: Dec  8 13:46:23.289: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172654: Dec  8 13:46:23.289: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172655: Dec  8 13:46:23.289: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172656: Dec  8 13:46:23.289: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172657: Dec  8 13:46:23.289: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172658: Dec  8 13:46:23.289: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172659: Dec  8 13:46:23.289: //784347//Digi:/AFW_M_DigitCollect_Action:
172660: Dec  8 13:46:23.289: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 2 Tone Mode 0
172661: Dec  8 13:46:23.289: //784347//Digi:/DigitCollect_TreatDigit:
172662: Dec  8 13:46:23.289: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=022832
172663: Dec  8 13:46:23.289: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172664: Dec  8 13:46:23.289: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172665: Dec  8 13:46:23.289: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172666: Dec  8 13:46:23.289: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172667: Dec  8 13:46:23.289: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172668: Dec  8 13:46:23.393: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172669: Dec  8 13:46:23.393: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172670: Dec  8 13:46:23.393: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172671: Dec  8 13:46:23.393: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172672: Dec  8 13:46:23.393: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172673: Dec  8 13:46:23.393: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172674: Dec  8 13:46:23.393: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172675: Dec  8 13:46:23.393: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172676: Dec  8 13:46:23.393: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172677: Dec  8 13:46:23.485: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172678: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172679: Dec  8 13:46:23.485: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172680: Dec  8 13:46:23.485: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172681: Dec  8 13:46:23.485: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172682: Dec  8 13:46:23.485: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172683: Dec  8 13:46:23.485: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172684: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172685: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172686: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172687: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172688: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172689: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172690: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172691: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172692: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172693: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172694: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172695: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172696: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172697: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172698: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172699: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172700: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172701: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172702: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172703: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172704: Dec  8 13:46:23.485: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172705: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172706: Dec  8 13:46:23.485: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172707: Dec  8 13:46:23.485: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172708: Dec  8 13:46:23.485: //784347//Digi:/AFW_M_DigitCollect_Action:
172709: Dec  8 13:46:23.485: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 5 Tone Mode 0
172710: Dec  8 13:46:23.489: //784347//Digi:/DigitCollect_TreatDigit:
172711: Dec  8 13:46:23.489: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=0228325
172712: Dec  8 13:46:23.489: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172713: Dec  8 13:46:23.489: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172714: Dec  8 13:46:23.489: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172715: Dec  8 13:46:23.489: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172716: Dec  8 13:46:23.489: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172717: Dec  8 13:46:23.593: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172718: Dec  8 13:46:23.593: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172719: Dec  8 13:46:23.593: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_BEGIN(19)] {
172720: Dec  8 13:46:23.593: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172721: Dec  8 13:46:23.593: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172722: Dec  8 13:46:23.593: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172723: Dec  8 13:46:23.593: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172724: Dec  8 13:46:23.593: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172725: Dec  8 13:46:23.593: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172726: Dec  8 13:46:23.685: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172727: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172728: Dec  8 13:46:23.685: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DIGIT_END(18)] {
172729: Dec  8 13:46:23.685: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172730: Dec  8 13:46:23.685: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172731: Dec  8 13:46:23.685: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172732: Dec  8 13:46:23.685: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172733: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: Passing, not enabled.---
172734: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172735: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172736: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172737: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172738: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172739: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172740: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172741: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172742: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172743: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172744: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172745: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172746: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172747: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172748: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172749: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172750: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172751: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172752: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172753: Dec  8 13:46:23.685: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172754: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172755: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172756: Dec  8 13:46:23.685: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172757: Dec  8 13:46:23.685: //784347//Digi:/AFW_M_DigitCollect_Action:
172758: Dec  8 13:46:23.685: //784347//Digi:/act_DCRunning_Digit: : pLeg 784347 Digit 4 Tone Mode 0
172759: Dec  8 13:46:23.685: //784347//Digi:/DigitCollect_TreatDigit:
172760: Dec  8 13:46:23.685: //784347//Digi:/DigitCollect_DialPlanMatch: pattern offset=0, digits=02283254
172761: Dec  8 13:46:23.685: //784347//Digi:/DigitCollect_DialPlanMatch: src carrier id:, tgt carrier id:
172762: Dec  8 13:46:23.685: //784347//Digi:/DigitCollect_DialPlanMatch: Match single infotype
172763: Dec  8 13:46:23.685: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_DigitReportDisable: Current: 0x2 Input: 0x1
172764: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172765: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172766: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172767: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172768: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172769: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_REPORT_DIGITS_DONE(68)] {
172770: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172771: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172772: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172773: Dec  8 13:46:23.689: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
172774: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172775: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172776: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172777: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172778: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172779: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172780: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172781: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172782: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172783: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172784: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172785: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
172786: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172787: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
172788: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCACKED(2)][Cause(0)]
172789: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172790: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCACKED(2)][Cause(0)]
172791: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
172792: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172793: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172794: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172795: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : DigitCollect
172796: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> DigitCollect_0x14B6C5A8_2_1952360332
172797: Dec  8 13:46:23.689: //784347//Digi:/AFW_M_DigitCollect_Action:
172798: Dec  8 13:46:23.689: //784347//Digi:/act_DCRunning_RDone: id=784347 Reporting disabled.
172799: Dec  8 13:46:23.689: //-1//Digi:/DigitCollect_Complete: DC_MATCHED_DIALPLAN. Digits=02283254
172800: Dec  8 13:46:23.689: //784347//Digi:/DigitCollect_MLPPPostAdjust: Non MLPP call
172801: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Event_New: Event ID: ev_collectdigits_done(246)
172802: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Module_ReturnArgEv:
172803: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Module_ReturnArgEv: Return List (remove=TRUE){LEG[784347 ][LEG_INCACKED(2)][Cause(0)]}
172804: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Object_RemoveListener:
172805: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Module_UnListen:  NumObjects: 0
172806: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: DigitCollect_0x14B6C5A8_2_1952360332 ---> NULL
172807: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
172808: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
172809: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
172810: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Process_GetPriorityQEvent: Received
172811: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_DIGITCOLLECT_DONE(246)] {
172812: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14DD4B5C][Default]
172813: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172814: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
172815: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
172816: Dec  8 13:46:23.689: //784347//Digi:/AFW_M_DigitCollect_EventPreProcess:
172817: Dec  8 13:46:23.689: //784347//Digi:/DigitCollectEnd_UpdateStats:
172818: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Object_WalkListeners:
172819: Dec  8 13:46:23.689: //784347//AFW_:/AFW_M_Object_ShowListeners: START
172820: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
172821: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCACKED(2)][Cause(0)]
172822: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[DigitCollect_0x14B6C5A8_2_1952360332]  (
172823: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
172824: Dec  8 13:46:23.689: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172825: Dec  8 13:46:23.689: //784347//AFW_:/AFW_M_Object_ShowListeners: END
172826: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Object_WalkListeners: Entering Module : Session
172827: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Object_AddListener: adding Module Session as listener
172828: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Object_RemoveListener:
172829: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Module_UnListen:  NumObjects: 1
172830: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x17AC36AC_2_1952360332
172831: Dec  8 13:46:23.689: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_GETTINGDEST[4],ev_collectdigits_done[246])---[C_Action]------
172832: Dec  8 13:46:23.689: //784347//AFW_:/GettingDest_DigitCollectDone: status(4) discCause(0) ovrlp(TRUE)
172833: Dec  8 13:46:23.689: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
172834: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Util_GetUserFromURL:
172835: Dec  8 13:46:23.689:  destination: 02283254
172836: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Util_GetUserFromURL:
172837: Dec  8 13:46:23.689:  ret_val : 02283254
172838: Dec  8 13:46:23.689: //-1//AFW_:/SetupDestination: SetupDestination: afwSSApdu is NULL
172839: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Util_CopyLegServiceCodeToCallInfoContainer: Service Code not available on Leg
172840: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Util_CopyLegRouteCodeToCallInfoContainer: Route Code not available on Leg
172841: Dec  8 13:46:23.689: //-1//AFW_:/AFW_Util_GetTgCicValue: CIC Not  found for tag(56)
172842: Dec  8 13:46:23.689: //784347//AFW_:/SetupDestinationSnrHandler:
172843: Dec  8 13:46:23.689: //784347//AFW_:/ProcessSnrDestination:
172844: Dec  8 13:46:23.689: //784347//AFW_:/ResetSnrParamenter:
172845: Dec  8 13:46:23.689: //784347//AFW_:/SetupDestinationSnrHandler: not snr call
172846: Dec  8 13:46:23.689: //784347//AFW_:/SetupValidateSharedln: calledNum=02283254, callingNum=, callID=784347,  callinf.peertag=7490, joinXtoID=0
172847: Dec  8 13:46:23.689: //784347//AFW_:/SetupDestination:
172848: Dec  8 13:46:23.689:  destinations[0] = 02283254
172849: Dec  8 13:46:23.689: //784347//CSPK:/C_CallSetup_Start: ControlInfo = 0x324DF4C, callInfo = 0x33CEBCC, destination[0]=02283254
172850: Dec  8 13:46:23.689: //784347//CSPK:/C_CallSetup_Start: configured mode=rotary (1)
172851: Dec  8 13:46:23.689: //-1//Call:/AFW_CallSetup_New:
172852: Dec  8 13:46:23.689: //-1//AFW_:/AFW_FSM_New:
172853: Dec  8 13:46:23.689: //-1//AFW_:LP:EE14DD4B5C000:HN745EAFC0:/AFW_M_Object_SetExecEnv: ObjCount: 5, CmdPending 1
172854: Dec  8 13:46:23.689: //784347//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 2
172855: Dec  8 13:46:23.689: //784347//AFW_:/AFW_Object_AddListener: adding Module Session as listener
172856: Dec  8 13:46:23.689: //784347//AFW_:/AFW_M_Module_GetHandle: Module handle: CallSetup_0x14D71A2C_2_1952362432
172857: Dec  8 13:46:23.693: //784347//Call:/AFW_CallSetup_AddDest:  02283254 index 0
172858: Dec  8 13:46:23.693: //784347//Call:/AFW_CallSetup_SetIntWrkLeg:
172859: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_SignalPeerGet: Leg [784347]
172860: Dec  8 13:46:23.693: //-1//AFW_:/C_PackageSession_GetSigPeer:
172861: Dec  8 13:46:23.693: //784347//Call:/AFW_M_CallSetup_Initiate:
172862: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
172863: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
172864: Dec  8 13:46:23.693: //784347//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
172865: Dec  8 13:46:23.693: //784347//Call:/CallSetupInitiate:
172866: Dec  8 13:46:23.693: //784347//Call:/CS_Placecall:
172867: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_GetUserFromURL:
172868: Dec  8 13:46:23.693:  destination: 02283254
172869: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_GetUserFromURL:
172870: Dec  8 13:46:23.693:  ret_val : 02283254
172871: Dec  8 13:46:23.693: //784347//Call:/setupHuntGroupInfo: set intWrkLeg id=784347 hgTag=-1 oldhgTag=-1 bacd=0
172872: Dec  8 13:46:23.693: //784347//Call:/CS_Placecall: enable reroute_ind intercept for reroutemode REDIRECT_ROTARY
172873: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
172874: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
172875: Dec  8 13:46:23.693: //784347//Call:/CS_UpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[0 (INTERNAL_PRECEDENCE_0)]  Preempt Hunt Not Set
172876: Dec  8 13:46:23.693: //-1//Dest:/AFW_Destination_New:
172877: Dec  8 13:46:23.693: //-1//AFW_:/AFW_FSM_New:
172878: Dec  8 13:46:23.693: //-1//AFW_:/AFW_FSM_New:
172879: Dec  8 13:46:23.693: //-1//AFW_:LP:EE14DD4B5C000:HN745EAFC4:/AFW_M_Object_SetExecEnv: ObjCount: 6, CmdPending 2
172880: Dec  8 13:46:23.693: //784347//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 3
172881: Dec  8 13:46:23.693: //784347//AFW_:/AFW_Object_AddListener: adding Module CallSetup as listener
172882: Dec  8 13:46:23.693: //784347//AFW_:/AFW_M_Module_GetHandle: Module handle: Destination_0x3481DDC_2_1952362436
172883: Dec  8 13:46:23.693: //784347//Dest:/AFW_Destination_AddDest:
172884: Dec  8 13:46:23.693: //-1//Dest:/AFW_Destination_AddDest: adding destination "02283254"
172885: Dec  8 13:46:23.693: //784347//Dest:/AFW_Destination_SetIntWrkLeg: LEG[784347 ][LEG_INCPROCEED(3)][Cause(0)]
172886: Dec  8 13:46:23.693: //784347//Dest:/TermInterworking: current state IW_STATE_INIT, Keep IntWrkLeg
172887: Dec  8 13:46:23.693: //784347//Dest:/DestSetIntWrkLeg:
172888: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
172889: Dec  8 13:46:23.693: //784347//Dest:/AFW_M_Destination_Initiate:
172890: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_SaveRawMsg:
172891: Dec  8 13:46:23.693: //784347//Dest:/AFW_M_Destination_Initiate: Outgoing guid : 6440AE5F.BC6A11E6.A0F7C218.5947484C
172892: Dec  8 13:46:23.693:  Incoming_guid : 00000000.00000000.00000000.00000000
172893: Dec  8 13:46:23.693: //784347//Dest:/AFW_M_Destination_Initiate: Outgoing gcid : 6440AE5F.BC6A11E6.A0F7C218.5947484C
172894: Dec  8 13:46:23.693:  Incoming_gcid : 00000000.00000000.00000000.00000000
172895: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_SetMLPPInfo: Unable to set mlpp info
172896: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_CopyMLPPDataToCallInfoContainer: Voice MLPP not configured
172897: Dec  8 13:46:23.693: //784347//Dest:/DestUpdateMLPPInfo: ServiceDomain:[none (0)]  DomainIdentifier:[000000]  PrecedenceLevel:[-1 (PRECEDENCE_LEVEL_NONE)]  NormalizedPrecedence:[-1 (PRECEDENCE_LEVEL_NONE)] Preempt Hunt Not Set
172898: Dec  8 13:46:23.693: //784347//Dest:/DestSetupInitiate:
172899: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
172900: Dec  8 13:46:23.693: //784347//Dest:/DestLocalConsultHandoff: no local handoff, intwrk leg 10EA14EC, consult id 14E4741C
172901: Dec  8 13:46:23.693: //784347//Dest:/DestAddRerouteSetupInfo:
172902: Dec  8 13:46:23.693: //784347//Dest:/DestAddTransferSetupInfo:
172903: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_CopyCallDataToCallInfo: copied 02283254
172904: Dec  8 13:46:23.693: //784347//Dest:/DestMatchDialPeer:
172905: Dec  8 13:46:23.693: //784347//Dest:/DestMatchDialPeer: src carrier id:, tgt carrier id:
172906: Dec  8 13:46:23.693: //784347//Dest:/DestQueuePeers: Matched peers:
172907: Dec  8 13:46:23.693: //784347//Dest:/DestPeerItemUpdatePreemptInfo:
172908: Dec  8 13:46:23.693: //784347//Dest:/DestPeerItemResetLPCORInfo:
172909: Dec  8 13:46:23.693: //-1//Dest:/DestQueuePeers:  401
172910: Dec  8 13:46:23.693: //784347//Dest:/DestPeerItemUpdatePreemptInfo:
172911: Dec  8 13:46:23.693: //784347//Dest:/DestPeerItemResetLPCORInfo:
172912: Dec  8 13:46:23.693: //-1//Dest:/DestQueuePeers:  300
172913: Dec  8 13:46:23.693: //-1//Dest:/DestQueuePeers: , Total(2)
172914: Dec  8 13:46:23.693: //784347//Dest:/DestDialPeerRotary:
172915: Dec  8 13:46:23.693: //784347//Dest:/DestOutboundCallUsingPeer: dest(02283254), numexpDest(02283254), numDestDigits(3)
172916: Dec  8 13:46:23.693: //784347//Dest:/DestOutboundCallUsingPeer:    prefix(), peer tag(401)
172917: Dec  8 13:46:23.693: //784347//Dest:/DestUpdatePreemptSetupInfo:
172918: Dec  8 13:46:23.693: //784347//Dest:/DestDialPeerFilter:
172919: Dec  8 13:46:23.693: //784347//Dest:/DestDialPeerFilter: Checking peer [401]
172920: Dec  8 13:46:23.693: //784347//Dest:/DestPeerFilterRouteCode: Route Code not available in callInfo
172921: Dec  8 13:46:23.693: //-1//Dest:/DestOutboundCallUsingPeer: Outgoing Tag(401) calling[] called[02283254]
172922: Dec  8 13:46:23.693: //784347//Dest:/DestCheckTeleUnassBusy:
172923: Dec  8 13:46:23.693: //784347//Dest:/DestHandleLPCOR:
172924: Dec  8 13:46:23.693: //784347//Dest:/DestSetup:
172925: Dec  8 13:46:23.693: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
172926: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Util_SaveRawMsg:
172927: Dec  8 13:46:23.693: //784347//Dest:/DestSetup: snrPeerCallID 0 intWrkLegID 784347
172928: Dec  8 13:46:23.693: //-1//AFW_:/AFW_Leg_New:
172929: Dec  8 13:46:23.693: //784348/6440AE5FA0F7/AFW_:/AFW_Leg_NewSetupRequest: ccCallSetupRequest done
172930: Dec  8 13:46:23.693: //784348/6440AE5FA0F7/AFW_:/AFW_M_Leg_SetExecEnv:
172931: Dec  8 13:46:23.693: //784347//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 4
172932: Dec  8 13:46:23.693: //-1/6440AE5FA0F7/AFW_:LP:EE14DD4B5C000:LG784348:/AFW_M_Object_SetExecEnv: ObjCount: 7, CmdPending 4
172933: Dec  8 13:46:23.693: //784348/6440AE5FA0F7/AFW_:/AFW_Object_AddListener: adding Module Destination as listener
172934: Dec  8 13:46:23.693: //784348/6440AE5FA0F7/AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_784348
172935: Dec  8 13:46:23.693: //784348/6440AE5FA0F7/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 147AE type 3
172936: Dec  8 13:46:23.693: //784347//Dest:/DestSetup: Destination setup success
172937: Dec  8 13:46:23.693: //784347//Dest:/AFW_M_Destination_Initiate: attempting call to destination 02283254
172938: Dec  8 13:46:23.693: //784347//Call:/CS_Placecall: Call placed to 02283254 index 0
172939: Dec  8 13:46:23.693: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_CONTACTINGDEST[5])---------------
172940: Dec  8 13:46:23.693: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x17AC36AC_2_1952360332 ---> NULL
172941: Dec  8 13:46:23.693: //784347//AFW_:/AFW_Object_WalkListeners:
172942: Dec  8 13:46:23.693: //784347//AFW_:/AFW_M_Object_ShowListeners: START
172943: Dec  8 13:46:23.693: //784347//AFW_:/AFW_M_Object_ShowListeners: END
172944: Dec  8 13:46:23.693: //784347//AFW_:/AFW_M_Event_Free:
172945: Dec  8 13:46:23.693: //784347//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: DigitCollect_0x14B6C5A8_2_1952360332
172946: Dec  8 13:46:23.693: //784347//AFW_:/AFW_Object_RemoveAllListener:
172947: Dec  8 13:46:23.693: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 6, CmdPending 4
172948: Dec  8 13:46:23.693: //-1//AFW_:HN745EA78C:/AFW_M_Event_Free: ExecEnv objCount: 6
172949: Dec  8 13:46:23.697: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 4
172950: Dec  8 13:46:23.697: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172951: Dec  8 13:46:23.697: //-1//AFW_:/AFW_M_Event_Free:
172952: Dec  8 13:46:23.697: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
172953: Dec  8 13:46:23.745: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
172954: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
172955: Dec  8 13:46:23.745: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_PROCEEDING(31)] {
172956: Dec  8 13:46:23.745: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
172957: Dec  8 13:46:23.745: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784348][LEG_OUTINIT(7)][Cause(0)]
172958: Dec  8 13:46:23.745: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
172959: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/SSIN:/AFW_SS_MapEvent:
172960: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 13
172961: Dec  8 13:46:23.745: //-1//SSIN:/AFW_SS_Telephony_MapEvent:
172962: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784348 ][LEG_OUTINIT(7)][Cause(0)]
172963: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
172964: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
172965: Dec  8 13:46:23.745: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3481DDC_2_1952362436]  (
172966: Dec  8 13:46:23.745: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
172967: Dec  8 13:46:23.745: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784348][LEG_OUTINIT(7)][Cause(0)]
172968: Dec  8 13:46:23.745: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
172969: Dec  8 13:46:23.745: //784348/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
172970: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
172971: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3481DDC_2_1952362436
172972: Dec  8 13:46:23.749: //784347//Dest:/AFW_M_Destination_Action:
172973: Dec  8 13:46:23.749: //784347//Dest:/AFW_Destination_Action:
172974: Dec  8 13:46:23.749: //784347//Dest:/OB_FSM_Drive:
172975: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
172976: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],ev_proceeding[31])---[C_Action]------
172977: Dec  8 13:46:23.749: //784347//Dest:/OB_Setting_Proceeding:
172978: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
172979: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
172980: Dec  8 13:46:23.749: //784347//Dest:/IW_FSM_Drive:
172981: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
172982: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_INIT[1],ev_proceeding[31])---[C_Action]------
172983: Dec  8 13:46:23.749: //784347//Dest:/IW_InitProc_Proceeding:
172984: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
172985: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =02283254,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
172986: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
172987: Dec  8 13:46:23.749: //784347//Dest:/DestStartMediaNegotiation:
172988: Dec  8 13:46:23.749: //784347//Dest:/DestStartMediaNegotiation: Interworking Leg does not need renegotiation
172989: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Connection_NewFromConID:
172990: Dec  8 13:46:23.749: //-1//AFW_:CN411655:/AFW_Connection_New: Conference created
172991: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 5
172992: Dec  8 13:46:23.749: //-1//AFW_:LP:EE14DD4B5C000:CN411655:/AFW_M_Object_SetExecEnv: ObjCount: 7, CmdPending 5
172993: Dec  8 13:46:23.749: //784347//AFW_:/AFW_Object_AddListener: adding Module Destination as listener
172994: Dec  8 13:46:23.749: //784347//AFW_:/AFW_M_Connection_GetHandle: Connection handle: CON_411655
172995: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_IB_CONFING[4])---------------
172996: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
172997: Dec  8 13:46:23.749: //784347//Dest:/DestIsEventNotified:
172998: Dec  8 13:46:23.749: //784347//Dest:/DestComplete: peer #:401 IW State IW_STATE_ALERT_IB_CONFING, OB State OB_STATE_SETTING
172999: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> NULL
173000: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
173001: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
173002: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173003: Dec  8 13:46:23.749: //784347//AFW_:/AFW_Process_GetCcqEvent: Received
173004: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CONF_CREATE_DONE(39)] {
173005: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
173006: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:     CON[411655][CONNECTION_CONFING(1)] {
173007: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173008: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:       LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173009: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:     }
173010: Dec  8 13:46:23.749: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
173011: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Connection_CreateDoneHuntGroupUpdate: pLeg2 not connected, skip hunt group update
173012: Dec  8 13:46:23.749: //784347//AFW_:/AFW_Object_WalkListeners:
173013: Dec  8 13:46:23.749: //784347//AFW_:/AFW_M_Object_ShowListeners: START
173014: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3481DDC_2_1952362436]  (
173015: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173016: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411655][CONNECTION_CONFED(2)] {
173017: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173018: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173019: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
173020: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173021: Dec  8 13:46:23.749: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173022: Dec  8 13:46:23.749: //784347//AFW_:/AFW_M_Object_ShowListeners: END
173023: Dec  8 13:46:23.749: //784347//AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
173024: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3481DDC_2_1952362436
173025: Dec  8 13:46:23.749: //784347//Dest:/AFW_M_Destination_Action:
173026: Dec  8 13:46:23.749: //784347//Dest:/AFW_Destination_Action:
173027: Dec  8 13:46:23.749: //784347//Dest:/IW_FSM_Drive:
173028: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173029: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_IB_CONFING[4],ev_create_done[39])---[C_Action]------
173030: Dec  8 13:46:23.749: //784347//Dest:/IW_AlertInConfing_CreateDone:
173031: Dec  8 13:46:23.749: //784347//Dest:/DestUpdateDisplayInfo:
173032: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
173033: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Util_UpdateDisplayInfo: Update Leg[784347] display using Leg[784348] info
173034: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Leg_GetTypeDetail: voice intf type = 3
173035: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Util_FillDispNotifyData:  Current: notifyData.connected_num.num_string =,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
173036: Dec  8 13:46:23.749: //784348/6440AE5FA0F7/AFW_:/AFW_Util_FillDispNotifyData:  Filled : notifyData.connected_num.num_string =02283254,notifyData.display_info = ,notifyData.connected_num.oct3a = 0
173037: Dec  8 13:46:23.749: //784347/6440AE5FA0F7/AFW_:/AFW_Util_UpdateDisplayInfo: Update for Leg[784347] display not supported
173038: Dec  8 13:46:23.749: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_IB[3])---------------
173039: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173040: Dec  8 13:46:23.749: //784347//Dest:/DestComplete: peer #:401 IW State IW_STATE_ALERT_IB, OB State OB_STATE_SETTING
173041: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> NULL
173042: Dec  8 13:46:23.749: //784347//AFW_:/AFW_M_Event_Free:
173043: Dec  8 13:46:23.749: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
173044: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173045: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
173046: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_VOICE_MODE_DONE(66)] {
173047: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
173048: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173049: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
173050: Dec  8 13:46:23.753: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
173051: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784348 ][LEG_OUTPROCEED(8)][Cause(0)]
173052: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
173053: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
173054: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3481DDC_2_1952362436]  (
173055: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173056: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411655][CONNECTION_CONFED(2)] {
173057: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173058: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173059: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
173060: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173061: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173062: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
173063: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
173064: Dec  8 13:46:23.753: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3481DDC_2_1952362436
173065: Dec  8 13:46:23.753: //784347//Dest:/AFW_M_Destination_Action:
173066: Dec  8 13:46:23.753: //784347//Dest:/AFW_Destination_Action:
173067: Dec  8 13:46:23.753: //784347//Dest:/OB_FSM_Drive:
173068: Dec  8 13:46:23.753: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173069: Dec  8 13:46:23.753: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(OB_STATE_SETTING[3],UnknownEvent[66])---[C_Action]------
173070: Dec  8 13:46:23.753: //784347//Dest:/OB_Consume: CONSUMING EVENT
173071: Dec  8 13:46:23.753: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(OB_STATE_SETTING[3])---------------
173072: Dec  8 13:46:23.753: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173073: Dec  8 13:46:23.753: //784347//Dest:/DestIsEventNotified:
173074: Dec  8 13:46:23.753: //784347//Dest:/DestComplete: peer #:401 IW State IW_STATE_ALERT_IB, OB State OB_STATE_SETTING
173075: Dec  8 13:46:23.753: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> NULL
173076: Dec  8 13:46:23.753: //784348/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
173077: Dec  8 13:46:23.753: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
173078: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173079: Dec  8 13:46:23.753: //784347/6440AE5FA0F7/AFW_:/AFW_Process_GetCcqEvent: Received
173080: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_VOICE_MODE_DONE(66)] {
173081: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14DD4B5C][Default]
173082: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173083: Dec  8 13:46:23.753: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
173084: Dec  8 13:46:23.753: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
173085: Dec  8 13:46:23.753: //784347/6440AE5FA0F7/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784347 ][LEG_INCPROCEED(3)][Cause(0)]
173086: Dec  8 13:46:23.753: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners:
173087: Dec  8 13:46:23.753: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: START
173088: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Destination_0x3481DDC_2_1952362436]  (
173089: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173090: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411655][CONNECTION_CONFED(2)] {
173091: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173092: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173093: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
173094: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173095: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173096: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x17AC36AC_2_1952360332]  (
173097: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[CallSetup_0x14D71A2C_2_1952362432]  (
173098: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[Destination_0x3481DDC_2_1952362436]  (
173099: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173100: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:         CON[411655][CONNECTION_CONFED(2)] {
173101: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173102: Dec  8 13:46:23.753: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173103: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:         }
173104: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:         LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173105: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
173106: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
173107: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173108: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173109: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E53660_2_1952360332]  (
173110: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173111: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x17AC36AC_2_1952360332]  (
173112: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:       MOD[CallSetup_0x14D71A2C_2_1952362432]  (
173113: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:         MOD[Destination_0x3481DDC_2_1952362436]  (
173114: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173115: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:           CON[411655][CONNECTION_CONFED(2)] {
173116: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:             LEG[784347][LEG_INCPROCEED(3)][Cause(0)],
173117: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:             LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173118: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:           }
173119: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:           LEG[784348][LEG_OUTPROCEED(8)][Cause(0)]
173120: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:         )
173121: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:       )
173122: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784347][LEG_INCPROCEED(3)][Cause(0)]
173123: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
173124: Dec  8 13:46:23.757: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173125: Dec  8 13:46:23.757: //784347/6440AE5FA0F7/AFW_:/AFW_M_Object_ShowListeners: END
173126: Dec  8 13:46:23.757: //784347/6440AE5FA0F7/AFW_:/AFW_Object_WalkListeners: Entering Module : Destination
173127: Dec  8 13:46:23.757: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Destination_0x3481DDC_2_1952362436
173128: Dec  8 13:46:23.757: //784347//Dest:/AFW_M_Destination_Action:
173129: Dec  8 13:46:23.757: //784347//Dest:/AFW_Destination_Action:
173130: Dec  8 13:46:23.757: //784347//Dest:/IW_FSM_Drive:
173131: Dec  8 13:46:23.757: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173132: Dec  8 13:46:23.757: //784347//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(IW_STATE_ALERT_IB[3],UnknownEvent[66])---[C_Action]------
173133: Dec  8 13:46:23.757: //784347//Dest:/IW_Consume:  Consuming EVENT
173134: Dec  8 13:46:23.757: //784347//AFW_:/AFW_FSM_Drive: ACTION END: -------------(IW_STATE_ALERT_IB[3])---------------
173135: Dec  8 13:46:23.757: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> Destination_0x3481DDC_2_1952362436
173136: Dec  8 13:46:23.757: //784347//Dest:/DestComplete: peer #:401 IW State IW_STATE_ALERT_IB, OB State OB_STATE_SETTING
173137: Dec  8 13:46:23.757: //784347//AFW_:/AFW_ExecEnv_SetModuleScope: Destination_0x3481DDC_2_1952362436 ---> NULL
173138: Dec  8 13:46:23.757: //784347/6440AE5FA0F7/AFW_:/AFW_M_Event_Free:
173139: Dec  8 13:46:23.757: //784347//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 5
173140: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173141: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Event_Free:
173142: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
173143: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Event_New: Event ID: ev_leg_timer(1)
173144: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_Process_GetTimerEvent: Received
173145: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Process_GetTimerEvent:   Event[APP_EV_LEG_TIMER(1)] {
173146: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Process_GetTimerEvent:     EXECENV[0x3C24ED4][seskayit]
173147: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Process_GetTimerEvent:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
173148: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Process_GetTimerEvent:   }
173149: Dec  8 13:46:32.233: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
173150: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_M_Leg_EventPreProcess: LEG[784337 ][LEG_INCCONNECTED(5)][Cause(0)]
173151: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners:
173152: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: START
173153: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[Session_0x28149B8_2_1952361972]  (
173154: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
173155: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
173156: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173157: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x34DAC24_2_1952349312]  (
173158: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     CON[411654][CONNECTION_CONFED(2)] {
173159: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)],
173160: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
173161: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     }
173162: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
173163: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     MOD[Session_0x28149B8_2_1952361972]  (
173164: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784344][LEG_OUTCONNECTED(10)][Cause(0)]
173165: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:       LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
173166: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     )
173167: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784337][LEG_INCCONNECTED(5)][Cause(0)]
173168: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173169: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_M_Object_ShowListeners: END
173170: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : Session
173171: Dec  8 13:46:32.233: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> Session_0x28149B8_2_1952361972
173172: Dec  8 13:46:32.233: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(S_ACTIVE[6],ev_leg_timer[1])---[C_Action]------
173173: Dec  8 13:46:32.233: //784337//AFW_:/Active_LongCallTimer:
173174: Dec  8 13:46:32.233: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(S_ACTIVE[6])---------------
173175: Dec  8 13:46:32.233: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: Session_0x28149B8_2_1952361972 ---> NULL
173176: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
173177: Dec  8 13:46:32.233: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x34DAC24_2_1952349312
173178: Dec  8 13:46:32.233: //784337//AFW_:/AFW_M_TclModule_Action:
173179: Dec  8 13:46:32.233: //784337//AFW_:/AFW_TclModule_DefaultEvHandling:
173180: Dec  8 13:46:32.233: //784337//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(VOICE_MODE[5],ev_leg_timer[1])---[act_process_timer_during_voice]------
173181: Dec  8 13:46:32.233: //784337//TCL :/tcl_PutsObjCmd: [Call 784337] TIMER went off during VOICE mode
173182: Dec  8 13:46:32.233:
173183: Dec  8 13:46:32.233: //784337//AFW_:/AFW_FSM_Drive: ACTION END: -------------(VOICE_MODE[5])---------------
173184: Dec  8 13:46:32.233: //784337//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x34DAC24_2_1952349312 ---> NULL
173185: Dec  8 13:46:32.233: //784337/5DAF2C79A173/AFW_:/AFW_M_Event_Free:
173186: Dec  8 13:46:32.233: //784337//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 3
173187: Dec  8 13:46:32.233: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173188: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Event_Free:
173189: Dec  8 13:46:32.233: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
173190: Dec  8 13:46:37.285: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:08507227400@10.1.174.2;user=phone SIP/2.0
Max-Forwards: 19
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: "08507227400" <sip:08507227400@10.40.11.5:5060;user=phone>
From: <sip:05342992223@isnetkrmsl.net>;tag=3690182919-529273
Call-ID: 11293442-3690182919-529268@isnet-sbc-kule1.mydomain.com
CSeq: 1 INVITE
Allow: PUBLISH,MESSAGE,UPDATE,PRACK,SUBSCRIBE,REFER,INFO,NOTIFY,REGISTER,OPTIONS,BYE,INVITE,ACK,CANCEL
Via: SIP/2.0/UDP 10.235.4.5:5060;branch=z9hG4bK4ae7471365f3d9543304c08df3daa318
Contact: <sip:05342992223@10.235.4.5:5060>
Content-Type: application/sdp
Accept: application/sdp
P-Charging-Vector: icid-value=bfff8d84-2b4a-1b21-a74a-ec9ecd109824;icid-generated-at=172.20.2.13
Content-Length: 450
v=0
o=isnet-sbc-kule1 32030 32030 IN IP4 10.235.4.5
s=sip call
c=IN IP4 10.235.4.4
t=0 0
m=audio 52544 RTP/AVP 18 96 97 98 8 0 4 101 13
a=rtpmap:96 G.729ab/8000
a=rtpmap:97 G.729b/8000
a=rtpmap:98 G.729a/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=fmtp:4 annexa=yes
a=fmtp:18 annexb=yes
a=ptime:20
a=rtpmap:13 CN/8000
a=X-vrzcap:vbd Ver=1 Mode=FaxPr ModemRtpRed=0
a=X-vrzcap:identification bin=DSR2814q Prot=mgcp App=MG
173191: Dec  8 13:46:37.289: //-1//SERV:/AFW_Service_CCInterface: Received Event 26 for service play2connect modulehandle NULL
173192: Dec  8 13:46:37.289: //-1//SERV:/AFW_Service_GetExecEnv: Script Name = play2connect
173193: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_New: play2connect
173194: Dec  8 13:46:37.289: //-1//SERV:/AFW_Service_GetExecEnv: Using Cached ExecEnv
173195: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_SetRoot: Execenv = 0x14E51E34
173196: Dec  8 13:46:37.289: //-1//AFW_:/AFW_M_TclModule_NewDup:
173197: Dec  8 13:46:37.289: //-1//AFW_:HN7457DE9C:/AFW_M_TclModule_Free:
173198: Dec  8 13:46:37.289: //-1//AFW_:HN7457DE9C:/AFW_M_Module_GetHandle: Module handle: TclModule_0xBFD6350_2_1951915676MOD[TclModule_0xBFD6350_2_1951915676]     ( )
173199: Dec  8 13:46:37.289: //-1//AFW_:/AFW_M_FSM_Free:
173200: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_Lock: pProcess(0xB553DCC)=1
173201: Dec  8 13:46:37.289: //-1//AFW_:LP:EE14E51E34000:HN745EE4E0:/AFW_M_Object_SetExecEnv: ObjCount: 1, CmdPending 0
173202: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_RestoreDataBackup: Restore DataArea from Script
173203: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_RestoreDataBackup: Restore TokenTable from Script
173204: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_Initiate: Execenv = 0x14E51E34
173205: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_SetCallCorID:
173206: Dec  8 13:46:37.289:  CallCorID is m^[0x<j^Qf!^CB^XYGHL
173207: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Leg_New:
173208: Dec  8 13:46:37.289: //784356//AFW_:/AFW_M_Leg_SetExecEnv:
173209: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_IncrPendingCmd:  PendingCmdCount: 1
173210: Dec  8 13:46:37.289: //-1//AFW_:LP:EE14E51E34000:LG784356:/AFW_M_Object_SetExecEnv: ObjCount: 2, CmdPending 1
173211: Dec  8 13:46:37.289: //784356//AFW_:/AFW_Object_AddListener: adding Module TclModule as listener
173212: Dec  8 13:46:37.289: //784356//AFW_:/AFW_M_Leg_GetHandle: Leg handle: LEG_784356
173213: Dec  8 13:46:37.289: //-1//AFW_:EE14E51E34000:/AFW_ExecEnv_AssignCall: Execenv = 0x14E51E34, Leg = 784356, Peer_Tag = 74001
173214: Dec  8 13:46:37.289: //784356//AFW_:/AFW_ExecEnv_SetCallCorID:
173215: Dec  8 13:46:37.289:  CallCorID is m^[0x<j^Qf!^CB^XYGHL
173216: Dec  8 13:46:37.289: //-1//SERV:/AFW_Service_Process_Space:
173217: Dec  8 13:46:37.289: Process Started
173218: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_Register: ccAppInitialize(name: _ManagedAppProcess_play2connect)
173219: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Thu, 08 Dec 2016 10:46:37 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.2.4.M6a
Content-Length: 0
173220: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173221: Dec  8 13:46:37.289: //784356//AFW_:/AFW_Process_GetCcqEvent: Received
173222: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_SETUP_IND(34)] {
173223: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14E51E34][play2connect]
173224: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784356][LEG_INIT(0)][Cause(0)]
173225: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
173226: Dec  8 13:46:37.289: //784356//SSIN:/AFW_SS_MapEvent:
173227: Dec  8 13:46:37.289: //-1//SSIN:/AFW_SS_SIP_MapEvent:
173228: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 147AF type 0
173229: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/incrementIncomingDialPeerCallStats: Incrementing call-stat to [1] for dial-peer [74001]
173230: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Object_WalkListeners:
173231: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: START
173232: Dec  8 13:46:37.289: //-1//AFW_:/AFW_M_Object_ShowListeners:
173233: Dec  8 13:46:37.289: //784356//AFW_:/AFW_M_Module_GetHandle: Module handle: TclModule_0x14E540A8_2_1952376032MOD[TclModule_0x14E540A8_2_1952376032]  (
173234: Dec  8 13:46:37.289: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784356][LEG_INCINIT(1)][Cause(0)]
173235: Dec  8 13:46:37.289: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173236: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: END
173237: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
173238: Dec  8 13:46:37.289: //784356//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1952376032 ---> TclModule_0x14E540A8_2_1952376032
173239: Dec  8 13:46:37.289: //784356//AFW_:/AFW_M_TclModule_Action:
173240: Dec  8 13:46:37.289: //784356//AFW_:/AFW_TclModule_DefaultEvHandling:
173241: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_CheckIncomingCallBlock:
173242: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_SettlementValidateCall: target=, tokenp=0x0
173243: Dec  8 13:46:37.289: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_IncomingTranslate:
173244: Dec  8 13:46:37.289: //-1//AFW_:/AFW_Leg_IncomingTranslate: Tag(74001) calling[05342992223] redirect[] called[08507227400]
173245: Dec  8 13:46:37.289: //784356//AFW_:/AFW_FSM_Drive: ACTION BEGIN: ------(CALL_INIT[1],ev_setup_indication[34])---[act_Media]------
173246: Dec  8 13:46:37.289: //784356//TCL :/tcl_InfotagObjCmd:  infotag get leg_dnis
173247: Dec  8 13:46:37.289: //784356//TCL :/tcl_InfotagGetObjCmd: infotag get leg_dnis
173248: Dec  8 13:46:37.289: //784356//AFW_:/vtr_lg_dnis: argc 2 argindex 2
173249: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegObjCmd:  leg setupack leg_incoming
173250: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegSetupAckObjCmd: setupack leg_incoming
173251: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: argc 2
173252: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: Legs [784356 ]
173253: Dec  8 13:46:37.293: //784356//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
173254: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegObjCmd:  leg proceeding leg_incoming
173255: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegProceedObjCmd: proceeding leg_incoming
173256: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: argc 2
173257: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: Legs [784356 ]
173258: Dec  8 13:46:37.293: //784356//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
173259: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegObjCmd:  leg connect leg_incoming
173260: Dec  8 13:46:37.293: //784356//TCL :/tcl_LegConnectObjCmd: connect leg_incoming
173261: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: argc 2
173262: Dec  8 13:46:37.293: //784356//AFW_:/vtd_lg_incoming: Legs [784356 ]
173263: Dec  8 13:46:37.293: //784356//Tcl :/tcl_parseCallID_vartagObj: VARTAG Translation Leg Count=1
173264: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_Connect: prog_ind=0, ccRawMsgInfo_t=0x18755A04, cData=0
173265: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 147AF type 1
173266: Dec  8 13:46:37.293: //784356//AFW_:/AFW_FSM_Drive: Tcl_Eval to drive FSM inside Tcl modulespace. code=1 code=ERROR
173267: Dec  8 13:46:37.293: TCL script failure
        Result:
                         can't read "prompt1": no such variable
173268: Dec  8 13:46:37.293:    TCL script failure errorInfo:
    while executing
"media play leg_incoming $prompt1"
    (procedure "act_Media" line 13)
    invoked from within
"act_Media"
173269: Dec  8 13:46:37.293: //784356//AFW_:/AFW_FSM_Drive: ACTION END: -------------(PLAYPROMPT[5])---------------
173270: Dec  8 13:46:37.293: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 1
173271: Dec  8 13:46:37.293: //-1//AFW_:/AFW_ExecEnv_CallClose:  Terminating ExecEnv's root module
173272: Dec  8 13:46:37.293: //784356//AFW_:/AFW_Module_Terminate:  Terminating Module: TclModule_0x14E540A8_2_1952376032
173273: Dec  8 13:46:37.293: //784356//AFW_:/AFW_M_TclModule_Terminate:  Module is in the state: ACTIVE
173274: Dec  8 13:46:37.293: //784356//AFW_:/AFW_TclModule_Cleaner: lastFailureCause 0
173275: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_784356
173276: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_Disconnect: Disconnecting Leg: LEG_784356, Cause 16
173277: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_Leg_UpdateStats: Updating stats for ID 147AF type 2
173278: Dec  8 13:46:37.293: //784356//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1952376032 ---> TclModule_0x14E540A8_2_1952376032
173279: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/AFW_:/AFW_M_Event_Free:
173280: Dec  8 13:46:37.293: //784356//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 1
173281: Dec  8 13:46:37.293: //784356/6D9BB0F8A103/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
To: "08507227400" <sip:08507227400@10.40.11.5:5060;user=phone>;tag=745EE4E4-260F
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <sip:08507227400@10.1.174.2:5060>
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Disposition: session;handling=required
Content-Length: 265
v=0
o=CiscoSystemsSIP-GW-UserAgent 9476 6791 IN IP4 10.1.174.2
s=SIP Call
c=IN IP4 10.1.174.2
t=0 0
m=audio 25688 RTP/AVP 0 13 101
c=IN IP4 10.1.174.2
a=rtpmap:0 PCMU/8000
a=rtpmap:13 CN/8000
a=fmtp:101 0-16
a=ptime:20
173282: Dec  8 13:46:37.301: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:08507227400@10.1.174.2:5060 SIP/2.0
Max-Forwards: 19
CSeq: 1 ACK
Allow: PUBLISH,MESSAGE,UPDATE,SUBSCRIBE,REFER,INFO,NOTIFY,REGISTER,OPTIONS,BYE,INVITE,ACK,CANCEL
Via: SIP/2.0/UDP 10.235.4.5:5060;branch=z9hG4bK7e338b79f264aa275031d2ce57594c46
Content-Length: 0
173283: Dec  8 13:46:37.305: //784356/6D9BB0F8A103/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:05342992223@10.235.4.5:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.174.2:5060;branch=z9hG4bK279F825D9
From: "08507227400" <sip:08507227400@10.40.11.5:5060;user=phone>;tag=745EE4E4-260F
To: <sip:05342992223@isnetkrmsl.net>;tag=3690182919-529273
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M6a
Max-Forwards: 70
Timestamp: 1481193997
CSeq: 101 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=0,OS=0,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
173284: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 BYE
Content-Length: 0
173285: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173286: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Process_GetCcqEvent: Received
173287: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetCcqEvent:   Event[CC_EV_CALL_DISCONNECT_DONE(21)] {
173288: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetCcqEvent:     EXECENV[0x14E51E34][play2connect]
173289: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetCcqEvent:     LEG[784356][LEG_INCDISCONNECTING(6)][Cause(16)]
173290: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetCcqEvent:   }
173291: Dec  8 13:46:37.309: //-1//SSIN:/AFW_SS_MapEvent: No mapping required
173292: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Object_WalkListeners:
173293: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: START
173294: Dec  8 13:46:37.309: //-1//AFW_:/AFW_M_Object_ShowListeners:   MOD[TclModule_0x14E540A8_2_1952376032]  (
173295: Dec  8 13:46:37.309: //-1//AFW_:/AFW_M_Object_ShowListeners:     LEG[784356][LEG_DISCONNECTED(12)][Cause(16)]
173296: Dec  8 13:46:37.309: //-1//AFW_:/AFW_M_Object_ShowListeners:   )
173297: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: END
173298: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Object_WalkListeners: Entering Module : TclModule
173299: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Object_RemoveListener:
173300: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Module_UnListen:  NumObjects: 0
173301: Dec  8 13:46:37.309: //784356//AFW_:/AFW_ExecEnv_SetModuleScope: NULL ---> TclModule_0x14E540A8_2_1952376032
173302: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_TclModule_Action:
173303: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_TclModule_Action: Module is Terminating
173304: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Event_New: Event ID: ev_module_done(257)
173305: Dec  8 13:46:37.309: //784356//AFW_:/AFW_TclModule_ReturnIfDone:  Sending Out APP_EV_TCLMODULE_DONE event
173306: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Module_ReturnArgEv:
173307: Dec  8 13:46:37.309: //784356//AFW_:/AFW_ExecEnv_SetModuleScope: TclModule_0x14E540A8_2_1952376032 ---> NULL
173308: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Object_WalkListeners:
173309: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: START
173310: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Object_ShowListeners: END
173311: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Event_Free:
173312: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Event_Free:  CC_EV_CALL_DISCONNECT_DONE for a Leg: LEG_784356
173313: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_Object_RemoveAllListener:
173314: Dec  8 13:46:37.309: //784356//AFW_:/AFW_ExecEnv_DecrNPendingCmd:  PendingCmdCount: 0
173315: Dec  8 13:46:37.309: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 1, CmdPending 0
173316: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Event_Free: ExecEnv objCount: 1
173317: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Leg_Free:
173318: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/AFW_M_Leg_Free: LEG[784356 ][LEG_DISCONNECTED(12)][Cause(16)]
173319: Dec  8 13:46:37.309: //784356/6D9BB0F8A103/AFW_:/decrementDialPeerCallStats: Decrementing call-stat to [0], dial-peer [74001]
173320: Dec  8 13:46:37.309: //784356//AFW_:/AFW_ExecEnv_CloseIfDone: Cmd Count: 0
173321: Dec  8 13:46:37.309: //-1//AFW_:/AFW_ExecEnv_CallClose:  Exec Env state: 3
173322: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Event_IsOk: AppEventOk Success - timestamp MATCHED
173323: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Process_GetPriorityQEvent: Received
173324: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   Event[APP_EV_TCLMODULE_DONE(257)] {
173325: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     EXECENV[0x14E51E34][play2connect]
173326: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     MOD[TclModule_0x14E540A8_2_1952376032]  (
173327: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetPriorityQEvent:     )
173328: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_GetPriorityQEvent:   }
173329: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_TclModule_EventPreProcess:
173330: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Object_WalkListeners:
173331: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_Object_ShowListeners: START
173332: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_Object_ShowListeners: END
173333: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_Event_Free:
173334: Dec  8 13:46:37.309: //784356//AFW_:/AFW_M_Event_Free:  MODULEDONEEVENT for a Module: TclModule_0x14E540A8_2_1952376032
173335: Dec  8 13:46:37.309: //784356//AFW_:/AFW_Object_RemoveAllListener:
173336: Dec  8 13:46:37.309: //-1//AFW_:/AFW_M_Object_UnSetExecEnv: ObjCount: 0, CmdPending 0
173337: Dec  8 13:46:37.309: //-1//AFW_:HN745EE4E0:/AFW_M_Event_Free: ExecEnv objCount: 0
173338: Dec  8 13:46:37.309: //-1//SERV:/AFW_Service_ReleaseExecEnv: Script Name = play2connect cache = true calls = 0
173339: Dec  8 13:46:37.309: //784356//AFW_:/AFW_ExecEnv_UnSetRoot: Execenv = 0x14E51E34
173340: Dec  8 13:46:37.309: //-1//AFW_:/AFW_Process_UnLock: pProcess(0xB553DCC)=0
173341: Dec  8 13:46:37.309: //-1//SCRI:/cam_sa_stopped: Instance: [] ExecEnv: 0x14E51E34
173342: Dec  8 13:46:37.313: //-1//AFW_:/AFW_Event_New: Event ID: ev_any_event(0)
173343: Dec  8 13:46:37.313: //-1//AFW_:/AFW_M_Event_Free:
173344: Dec  8 13:46:37.313: //-1//AFW_:/AFW_M_Event_Free: Null or invalid event context: for event APP_EV_NULL
File name is kisa.au,  how can I check compability with G711ulaw and G729
Prompt param configured wrongly, it should be prompt-1 please try as below
  param prompt-1 flash:kisa2.au
Raghavendra
I tested it  below config its  failure again.
service play2connect play_message_2_calling_then_connect.tcl
  param mode listen-first
I noticed that previous log  display below. Does it related kisa2.au codec ?
Result:
    while executing
    invoked from within
"act_Media"
I changed your  suggested configuration but one test is working second one is not working.
If I make 6 test  call , 3 call is working 3 call not.
P.S : Every first  test call is not working.
Error related param config issue. Below is the correct way to configure, you need to mention location of tcl file and audio file.
hope you copied both files to flash.
service play2connect flash:play_message_2_calling_then_connect.tcl
Raghavendra
Here is my last config;
service seskayit app_fax_detect.2.1.2.2.tcl  (This is for pots dial-peer)
  param prompt flash:kisa2.au
service play2connect flash:play_message_2_calling_then_connect.tcl  (this is related for voip dial-peer)
Every first call is failed but seconda calls play annouce before ringing.
I don't understand why you are using 2 scripts here, only play2connect is enough. You don't need param mode for play2connect.
Raghavendra
