Showing results forĀ
Search instead forĀ
Did you mean:Ā
CSCux28865 - CUIC sets ansi warnings and nulls off, breaks linked server queries
sherrerogon
For a custom report, we are trying to get some information from a table that is placed in a Database in a server different from AW. We have tried to use a linked server and a view and we both methods we get an error.
The error is:   Heterogeneous queries require the ANSI_NULLS and ANSI_WARNINGS options to be set for the connection. This ensures consistent query semantics. Enable these options and then reissue your query.
com.microsoft.sqlserver.jdbc.SQLServerException: Heterogeneous queries require the ANSI_NULLS and ANSI_WARNINGS options to be set for the connection
We have enabled those options at the beginning of the report, but the error is still there (image1.png)
Has someone find a solution?
Gerry O'Rourke
I found setting these at the database level and restarting SQL server fixed this issue for me.
In SQL Studio - right Click the database -> Properties - > Options
Set ANSI_NULLS and ANSI_WARNING to True.
Gerry
