CSCvf28304 - Drain of unprocessed events from Unified Low Priority Events (priority_2_events)
I am having the same symptoms of this bug in version 6.1.0.5. It only happens when the Disk Manager peaks one of the CPU's. Can I get confirmation that this is also a bug for 6.1.0.5?
ccc-vendors1
I'm observing the same symptoms in 6.1.0.4. I see the same error "Drain of unprocessed events from Unified Low Priority Events." Upon checking the Disk Usage and CPU. everything found normal and running in optimal state.
hunnymonster
Having this in 6.4.0.1
I have is in 6.4.0.4
Dear Cisco - fix your buggy code!!
I have it in version 6.4.0.9.
