12-14-2021 09:35 AM
Are Shockwave/Fury/Cyclops internal code names for DNAC releases? Would you please provide version numbers as well, so I have something to compare against my installed version? Thanks!
Solved! Go to Solution.
12-14-2021 10:25 AM
Known Affected Releases (4)
DNAC-Cyclops (2.1.2.0, 2.1.2.3, 2.1.2.4, 2.1.2.5, 2.1.2.6, 2.1.2.7)
DNAC-Fury (2.2.2.0, 2.2.2.1, 2.2.2.3, 2.2.2.4, 2.2.2.5, 2.2.2.6, 2.2.2.7)
DNAC-Shockwave (2.2.3.0, 2.2.3.3)
DNAC-Frey (2.3.2.0)
DNAC-Guardian (not available yet and not versioned)
Updates will be refreshed here:
Vulnerability in Apache Log4j Library Affecting Cisco Products: December 2021
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-apache-log4j-qRuKNEbd?s=09
Cisco DNA Center (CSCwa47322)
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwa47322
12-14-2021 10:25 AM
DNAC-Frey (2.3.2.0)
12-23-2021 06:35 AM
@Tomas de LeonDNAC2.2.2.8 is marked both as Affected and Fixed release.
Can you please confirm if this release is affected or not?
Thanks.
Sylvain.
12-23-2021 07:09 AM
Sylvain,
That is a glitch in the reporting and is to be fixed.
Please refer to:
Release Notes for Cisco DNA Center, Release 2.2.2.x
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-2-2/release_notes/b_cisco_dna_center_rn_2_2_2.html#Cisco_Concept.dita_1aac2b20-6a07-4b8c-b77e-0e8a218d50a3
CSCwa47322 - Evaluation of enterprise_sdn for Log4j RCE (Log4Shell) Vulnerability vulnerability
12-29-2021 06:07 PM
Hi guys,
I got DNAC box running 1.3.3.7
can someone pls confirm if this version affected as well? It seems no stated in the affected list.
12-29-2021 07:18 PM
Yes, 1.3.3.x is affected.
A would suggest planning your maintenance windows so that you can upgrade to either versions 2.2.2.8 or 2.2.3.4.
