Failed to register Smart License through transport gateway mode
Simon Ko
Prime Infrastructure can no longer register using Smartnet portal or satellite.
This is unacceptable mishandling of upgrade process.
Cisco is asking me to revert back to Traditional Licensing.
Does anyone know how to go from SmartNet to Traditional?
CSCvy55255 -
10 Replies 10
This is version 3.10 and this cert method still fails to send registration.
Thanks for the info,
mark-daniel
I have a customer who has just upgraded from 3.8 to 3.10 (update1) and matched this but as they get the error message "unable to register to the smart licensing protal".
As they have a VM version they can spin back up the original version of 3.8.
My query is that there is "no workaround" or fix for.
Do we know when Cisco maybe reviewing this issue and what timescales are we to expect for a fix?
lukeee
I have the same issue with several customers and different Versions (3.9 latest patch & 3.10 latest patch)
Smart Licensing is not working...
Connectivity can be successfully tested, but registration is failing "Registration failed due to Communication send error."
Neither with a direct connection nor via proxy.
My customer now has this issue resolved.
I raised this with TAC and the assigned engineer appeared to be aware of the issue.
The problem appears to be with the "call_home_ca" certificates.
Cisco TAC provided a replacement file which was basically several certificates merged together like a .PEM
The instructions were OK but TAC actually applied the file on behalf of my customer over WebEX.
Backup the existing call_home_ca file, then replace the replacement call home file to the existing one located at /opt/CSCOlumos/licenses/ location  update the file permission as below and restart the ncs services
(chmod 755 call_home_ca & chown prime:gadmin call_home_ca)
-rwxrwxr-x. 1 prime gadmin 19812 Feb 17 20:29 call_home_ca
many thanks mark-daniel! (btw: my case is unsolved since 2 weeks...)
it seems, that I could fix it with your information.
I've edited the file "call_home_ca" within /opt/CSCOlumos/licenses/
1) I've deleted all text
2) I added:
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
 3) saved it.
4) no reboot or sth. like that.
5) tried to start registering again - and it's working...
6) maybe it is enough to add only the new certificate... I will test it.
thanks again.
Lukas
it's me again:
updated procedure:
1) go to /opt/CSCOlumos/licenses/ and make a backup of "call_home_ca"
2) edit original file and insert on the top of the file:
3) save
4) register your PI (no reboot / service restart necessary)
Thanks again mark-daniel!
BR
Lukas
Lukas
Hi Lukas,
I have followed your steps by adding to the file and tried registering. This has failed. Then I restarted the Prime services and I was able to register after that. Below are the steps I followed.
3) save
4) Stop and Start the Prime Services
      ncs stop
      ncs start
Thanks for the helpful tips.
Cheers
Saj
dmiramont
I had the same issue (running Prime 3.10) and unfortunatly the previous method didn't work. I will provide you what worked for me.
TAC assisted me and I was able to make the registration working. This is how the we proceeded :
  1. Go in shell mode and type the following commands :
  2. cd /opt/CSCOlumos/licenses/
  3. cp /opt/CSCOlumos/licenses/call_home_ca /opt/CSCOlumos/licenses/call_home_ca.bak
  4. > call_home_ca
  5. Copy and paste the content of the "CA certificate.txt" file into the call_home_ca
    1. vi call_home_ca
    2. Type "i" to enter the insert mode
    3. Paste the content of the file
    4. Type :wq to exit and save the file
  6. chmod 755 call_home_ca
  7. chown prime:gadmin call_home_ca
  8. sudo su admin
  9. ncs stop
  10. ncs start
After that it should work !
Donatien
Changing all call_home_ca forked for me. Thanks.
