CBD Access to swtiches located in another VLAN
Ciscorudy
I'm asking you because I can see all my switches located in the same VLAN as the one where CBD is installed. But I can't see the switches located in another VLAN.
However in the configuration I added the subnetwork associated with the switches of the other VLAN in the discovery option of CBD.
Namely VLAN of the CBD with the switches seen 172.20.1.0/27.
VLAN other switches 172.20.20.0/27
But it does not work.
I join you a picture of the network addresses seen by CBD. I do not understand why it sees 198.168.200.2/24 when I have not configured this range.
How can I add in the networks section OVERVIEW - Subnet my VLAN networks for the other Switches.
For information section VLAN :
VLAN2 = Network of process switches + CBD (works well 21 switches of overdraft)
VLAN10 = Network of other switches (Not functional CBD does not see the switches of this VLAN).
I have the impression that the discovery of equipment located in another VLAN than the CBD one does not work properly.
Thanks in advance
17 Replies 17
Now everything is working properly. Thank you very much
You're most welcome
Many thank
