07-07-2023 06:20 AM
We have CBD (trail version) in use. An SG300 was added manually, but in CBD the switch is not listed as "Online". And the auto-discovery does not work either, although according to the "Managed Device Support Matrix" the 300 series is supported.
I need help to bring the switch correctly "online" in CBD and to scan all switches in the network automatically.
Who can help us?
Volkan
07-07-2023 07:26 AM
Hi @Volkan Dag
Which version software is your switch?
07-10-2023 12:23 AM
Hello Flavio,
thx for your answer!
V. 1.3.0.62
best regards
07-10-2023 04:42 AM - edited 07-10-2023 04:42 AM
You should consider upgrade the switch. On the documentation for CBD, you can read this statement below
A firmware version of 1.4.2.x or higher is recommended for 200, 300, and 500 series switches.
07-13-2023 11:14 PM
Tried that, but it doesn't work. Error message: Illegal software format. Tried directly via ssh and GUI both do not work.
best regards
