12-01-2020 07:26 AM
I've downloaded both the Dashboard and Probe files for Hyper-V and both contain ubuntu-xenial in the path names inside.
Can't see anywhere else to post this bug so here it is.
12-01-2020 01:33 PM
Hi Michael,
Are you seeing ubuntu-xenial anywhere other than the zip file names and the folders that are created when those are unzipped? And if not, is this causing any problems or is it just a change that you noticed? The filename change is deliberate, but if it is causing problems, we can revisit it.
Cheers,
Dave.
12-01-2020 07:36 PM
Hi Dave
It only causes confusion as I thought it was the wrong files at first.
The VM files inside were accepted by Hyper-V just fine.
Thanks Michael
12-01-2020 08:26 PM
Ok, thanks.
