NOt able to add CBS350 in Cisco Dashboard
Hello All,
Having really tough time to add new cisco switch CBS350 into newly setup dashborad, also not seeing enough document around it. Please help.. seeing below error
Dashboard Status: Disconnected ( certificate-error - application verification failure )
Mark Fang
Have you imported the CBD's root certificate to the CBS350? You can check the Quick Start Guide. https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/cisco-business-dashboard/qsg/b_CBD_QSG.html
What's your CBD and CBS350 version? I suggest you to upgrade the CBD to 2.6.0 and CBS350 to 3.3.0.16, both the latest version. With the latest version, there is a [Online with Web Browser] Connection Setup option on the CBS350's CBD Settings GUI. If you use this option to connect the CBS350 to CBD, you don't need to import the certificate manually, all will be done automatically in the wizard.
