Blogs versus Documents
Philip D'Ath
I don't really get the different between these two.  They seem to accomplish the same task.
Why would you choose to create one versus the other?
7 Replies 7
Dan Lukes
Blog is Document with revision log. As far as I know it's the only difference.
Dan Lukes
P.S. I consider your biography great idea. Fortunately, despite you are interested in cryptography, you didn't encrypted it ;-)
Haha, well done.  I needed to leave it in a form that could be recognised and obfuscation does not sound as sexy.  I think you are the first person to work it out.
Yes he did! It's been encrypted with two rounds of ROT13
GTG
Please rate all helpful posts.
V fhfcrpg bayl 1% bs gur zrzoref jvyy haqrefgnaq ubj shaal gur wbxr lbh whfg znqr vf.
I consider your estimation rather high.
Well, we are just off-topic in Feedback Forum. Even worse, deviation from topic has been caused by moderator. I'm guilty, sorry for it.
I has moved this thread to Cisco Cafe.
Actually it's not up to me what posts say or don't say, and it shouldn't be, so please just ignore previous post.
Jon
