Automation and Assurance services have been temporarily disrupted
OrkhanRustamli
Hi All,
I have updated software successfully on DNAC and wanted to update all applications but failed as visible in below screenshot. Update almost longed for one day and at the end it failed.
Capture.PNGI clicked Update all, but still some of application hangs in 20%. How to recover?
ERROR:  UPGRADE_ERROR - Exception in package: access-control-application, kind: ServiceBundleGroup, name: aca-ise - Shell command timed out after 1266.4731613820186 seconds of inactivity: /srv/maglev/replicated_storage//fusion/plugin_type_catalog/model/7.1.75.60446/install UPGRADE
May it be related to ISE? 2 days ago I extended ISE system certificates (All except pxgrid). May it be caused by that?
7 Replies 7
Preston Chilcote
Please open a case with TAC.
sergey.dibrov
you solved this issue?
Yeap, this is bug confirmed by Cisco. You need to open TAC case so that developers can fix it inline.
Dan Rowe
Hey OrkhanRustamli,
As Preston mentioned, please proceed with opening a TAC case. You are hitting defect CSCvr82062. There is a known workaround which requires you to execute several commands in the Postgres database. TAC will be able to execute this workaround for you in order to allow you to upgrade successfully to 1.3.1.4.
Best Regards,
Which type of command they run in tac ? I would like to resolve the problem by myself
Yeremy07
Hi OrkhanRustamli ,
I solved this issue updating packet by packet. I press in All Update Bottom, then detail packet and uncheck just leave one on a check mark.  In the end you can have the DNA completely updated
AminRamadan
Excuse me, do you have any idea about how to solve the problem ?
