Basic Radius Configuration on Cisco Catalyst Switch
zhir
Dear Community, i want to integrate DaloRadius with a switch, i have troubles authenticating. and after I set up the radius there won't be any ping between the radius server and the switch, this is what i applied on the switch:
radius-server host 11.11.11.10 auth-port 1812 acct-port 1813 key **********
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius if-authenticated
aaa accounting exec default start-stop group radius
interface range fa0/1 - 48
dot1x pae authenticator
dot1x port-control auto
exit
Your Assistance is appreciated.
8 Replies 8
You need to solve first ping between SW and radius
Show ip route
Check if the SW have IP or radius or default route in routing table
MHM
Before applying the radius config, I had ping!
zhir
Additionally every port i try to connect to stays in orange light
That can explain little if I am correct
The uplink must not config with dot1x it secure link.
Remove dot1x config from link toward radius server try ping then do
Show aaa server
See if server is appear and UP
MHM
Thanks dear, Will do
Dear,
I am using a Catalyst 3750 V2 switch and have successfully connected to the DaloRadius server. I can log into the switch with the users I created in the Radius server without any problems. Here is my current configuration:
*Mar 1 03:00:41.369: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan100, changed state to up
Switch>en
Switch#conf
Switch#sh run
Switch#sh running-config
Building configuration...
Current configuration : 5057 bytes
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
username admin password 0 Nexus@2022
aaa new-model
aaa session-id common
switch 1 provision ws-c3750v2-48ps
system mtu routing 1500
ip subnet-zero
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 100
switchport mode access
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface FastEthernet1/0/25
interface FastEthernet1/0/26
interface FastEthernet1/0/27
interface FastEthernet1/0/28
interface FastEthernet1/0/29
interface FastEthernet1/0/30
interface FastEthernet1/0/31
interface FastEthernet1/0/32
interface FastEthernet1/0/33
interface FastEthernet1/0/34
interface FastEthernet1/0/35
interface FastEthernet1/0/36
interface FastEthernet1/0/37
interface FastEthernet1/0/38
interface FastEthernet1/0/39
interface FastEthernet1/0/40
interface FastEthernet1/0/41
interface FastEthernet1/0/42
interface FastEthernet1/0/43
interface FastEthernet1/0/44
interface FastEthernet1/0/45
interface FastEthernet1/0/46
interface FastEthernet1/0/47
interface FastEthernet1/0/48
interface GigabitEthernet1/0/1
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface Vlan1
no ip address
interface Vlan100
ip address 11.11.11.13 255.255.255.0
ip access-group INTERNET-ACCESS in
ip classless
ip http server
ip http secure-server
radius-server host 11.11.11.10 auth-port 1812 acct-port 1813 key ZhirZhir@@
control-plane
line con 0
line vty 5 15
end
Switch#
Switch>en
Switch#conf
Switch#sh run
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
aaa new-model
ip subnet-zero
interface Vlan1
no ip address
interface Vlan100
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
Now, I want to grant or restrict access to the end users connected to the same switch. I really have no idea where to begin. Essentially, I want any user (or an AP) that is connected to this switch to have their access controlled by the Radius server, similar to how ISPs or hotels operate.
Thank you for your assistance, it is greatly appreciated.
balaji.bandi
couple of things not clear ?
what Cisco device is this ?
what IOS code running ?
are you trying dot1.x deploying using Dalo radius ?
or is this for device authentication ?
I have used opensource freeradius before it works find most of the switches of cisco - depends on what you looking achieve :
https://www.cisco.com/c/en/us/support/docs/security-vpn/remote-authentication-dial-user-service-radius/116291-configure-freeradius-00.html
Freeradius have good examples :
https://wiki.freeradius.org/vendor/Cisco
BB
Dear,
Switch>en
Switch#conf
Switch#sh run
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
aaa new-model
ip subnet-zero
interface Vlan1
no ip address
interface Vlan100
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
Switch>en
Switch#conf
Switch#sh run
version 12.2
no service pad
hostname Switch
boot-start-marker
boot-end-marker
aaa new-model
ip subnet-zero
interface Vlan1
no ip address
interface Vlan100
ip classless
ip http server
control-plane
line con 0
line vty 5 15
end
Switch#
