Building DNAC server - Need help with answers to questions
I have a need to build a DNAC server for my lab.
I have a UCS-C220-M5 that I use for my primary lab R&S, SD-WAN, but I need a DNAC server and my job won't be adding a cluster until the last quarter 2023. So my hands-on is severely limited to just Cisco practice labs for DNAC SD-Access.
Questions:
Does the requirement of 44cores reference actual CPU cores or vCPU's?
What is the minimum CPU core\vCPU that can run DNAC?
Does it matter if the UCS C-Series platform is a 10-SFF or 4-LFF?
Is the DNAC virtual available now or is it still in development?
Thank you in advance.
  I believe this video will help you
https://www.youtube.com/watch?v=K_y8T_x2VKw
Yes, it is.
