06-12-2024 11:20 PM
Hi Team,
Is it possible that I can use Catalyst 9300 for StackWise, StackWise Virtual and VSS?
06-12-2024 11:46 PM
StackWise Virtual and VSS are the same.
The only difference between the two is the OS. Stackwise Virtual is IOS-XE and VSS is classic IOS.
06-12-2024 11:52 PM
The thing is that both StackWise Virtual and VSS are not supporting Catalyst 9300. They're supporting 9400,9500&9600 for StackWise Virtual and 6500 & 6800 for VSS.
06-12-2024 11:58 PM
Chassis based (4500, 6500/6800, 9400, 9500 & 9600) support VSS/SVL.
3750, 3650/3850, 9200/9300 support stacking.
06-12-2024 11:56 PM
You can refer below guide how you can do :
both are same - cisco marketing term different. VSS was on IOS code, SVL on IOS XE code
Cat 9300 do not support, only Cat 9500, 9400, 9600 support these features (required advantage License to build )
06-13-2024 12:43 AM
Only stackwise (not virtual) support in 9200/9300.
MHM
