03-05-2025 08:05 AM
I was hoping to get some clarification with respect to the Cisco DNA subscrption licensing. Specifically, the matrix (see below), shows the with the "Network Essentials", L3 Route Access is supported. Does that mean that with this type of licesning, L3 and routing is supported and dynamic routing (EIGPR), Static, and L3 VLAN are supported?
Thanks in advance.
\~zK
Solved! Go to Solution.
03-06-2025 12:48 AM
Hello @ZK916
Yes, I can help clarify this for you. Based on the Cisco DNA subscription licensing matrix, the "Network Essentials" tier does indeed support Layer 3 (L3) routing access. However, it's important to understand what is included in "L3 Route Access" under the "Network Essentials" license.
If your network requires full dynamic routing protocol support (e.g., full EIGRP, OSPF, or BGP), you would need to consider the "Network Advantage" license instead of "Network Essentials."
For the most accurate and up-to-date information, I recommend reviewing the Cisco DNA subscription matrix directly on the Cisco website (the link you provided) or consulting with a Cisco representative.
AshSe
03-06-2025 12:48 AM
Hello @ZK916
AshSe
03-06-2025 01:28 AM
