Catalyst center integration with ISE
erick.mephon
I'm starting a DNAC lab, have a few switches available (C9300 & C3850).
I did the ISE integration, it shows as active :
Despite the succesful integration, I'm still unable to see the SGT menu on DNAC, in fact, my policy tab is almost empty :
So I was wondering, when does this tab appear ? Do I have to have switches in my fabric ? Or created some group tags ?
Torbjørn
I believe you need to install the SDA application under software management for this. It might also be a separate application named something with "policy" - I currently don't have a blank Cat-C to check this on.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Torbjørn
That may be correct :
right now I'm receiving an error when trying to install it but I will work on that and post a conclusion here.
erick.mephon
That was the missing part. I could not install it immediately due to an error but after fixing the other issue, I installed it and I now can see the SGT menu in the policy tab
