Cisco Access Points and DNA Center
DAVID
Level 3
Level 3
I have a Cisco 5520 Controller that is in the inventory in DNAC but I do not have the access points that are in the WLC showing up in DNAC.
WLC 5520= 8.2.190
APs= 9130, 1815
DNAC= 2.3.5.5-72026
ammahend
your WLC code doesn't seem compatible, minimum version should be AireOS 8.5.135.0 for DNAC and AirOS 8.10.X for 9130 support
check the compatibility matrix here
-hope this helps-
balaji.bandi
5520 is not compatable - so suggest to uplift to Cat 9800 for better visibility with DNAC
#check the matrix :
https://www.cisco.com/c/dam/en/us/td/docs/Website/enterprise/dnac_compatibility_matrix/index.html
BB
Preston Chilcote
@balaji.bandi 5520 is compatible, you just need to select the "Upgrade" radio button in the compatibility matrix.
Leo Laohoo
@DAVID wrote:
WLC 5520= 8.2.190
APs= 9130
This info is incorrect.
9130 is supported from 8.10.X.X
Is the WLC on 8.10.190.0?
