Bookmark
Subscribe
857
Cisco Catalyst Center Virtual Appliance sizing
talasgair
Is it possible to run Catalyst Center in a VM smaller than the requirements here:
https://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/dna-center/cat-center-2-3-7-virtual-app-vmware-esxi-ds.html#VirtualApplianceonVMwareESXirequirements
For a small wireless only deployment with 200 APs is such a powerful machine really required for the management?
marce1000
         - It isn't ,
 M.
Hi Marce, thanks for the answer. Do we get any issues if the hardware ressources are reduced after the installation?
Yes. This used to be possible (for lab purposes) in previous releases, but if you attempt it on 2.3.7.6 it will not function well at all.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
     - Yes , you will probably have issues,
  M.
