Cisco connection between two networks
dieter-thomas
Hello!
I have the following problem: My computers can not ping to each other (either local or different networks). Normally from what I've seen in the ccna video of Network Chuck, when Ron tries to ping Malfoy, Ron must send an ARP package to find out Malfoy's MAC adress and then he must receive an ICMP package.
In my case, the ARP package is sent from the switch0 to the router and when the router tries to send the package to the switch1 of the other network, the ARP package becomes an STP package and they never reach the recipient.
My second problem is that I can not reset the simulation so that all the packages from the previous simulation get deleted.
Can you help me through my two problems?
 Something is wrong with your Layer 3 design. If you host is 1010.10.2, you gateway can not be 10.0.0.9, unless you are using 255.0.0.0 as mask, which I believe you are not.
Also, the router should create two network:  One segment for Ron and another for Malfoy. Then, they can´t have the same Gateway.
 Try this:
 On router Interface to Ron, put the IP address 10.10.10.1.  Same mask as host.
  On router interface to Malfoy, put ip address 192.0.0.1. Same mask as host
Then, test.
About the error on Pacektracer, I have no idea.
